    New firmware release, version 1.6.0.b1
    72 Posts 13 Posters 40.7k Views 13 Watching
    • N Offline
      Neo @livius
      @livius Yes. One LoPy and one DS1b20... and empty output. As far as I remember this was happen also on Wipy 1.5.1b1 but I will check again
        Colateral @Pete
        @Pete said in New firmware release, version 1.6.0.b1:
        Which different brand of WiFi IoT module are you using?
          Pete @Colateral
          @Colateral I ordered some of these: LinkIt Smart 7688 at the same time as my WiPys. Similar form factor, but runs OpenWrt, a Linux distro originally developed for customising Linksys routers. They arrived at the start of this week. I haven't even opened the box yet, as I'd like to get the WiPy working if I can - my use case is pretty simple and I'd rather not have to admin a whole Linux if I can just write one Python script instead. From the point of view of attack surface if nothing else. But it's a second basket for my eggs if required.
          Pete
            livius
            @daniel
            i still have problem of corruption of files stored throught ftp :(
              We just released new firmware, version 1.6.2.b1. These are the changes:
              • Fix issue when trying to send empty strings via sockets.
              • Update the ESP-IDF.
              • Correct RCZ3 uplink frequency and integers overflow.
              • Implement ntp_sync for RTC. Add simple support for timezones. See: https://docs.pycom.io/pycom_esp32/library/machine.RTC.html#machine.rtc.ntp_sync
              • Correctly set the DNS server. Also disable and enable the right TCP adapter interface.
                daniel @livius
                I still have problem of corruption of files stored throught ftp :(
                @livius Really? We have been testing a lot during the last 2 weeks with large files and the issue seem resolved. Does it happen when you perform file operations in your script while at the same time the FTP server is busy with a transfer?
                  livius @daniel
                  @daniel
                  it is by copy file throught e.g. filezilla and without while true: loop
                    daniel @livius
                    @livius what's the size of the file?
                      daniel @livius
                      @livius could it be that your file system is corrupted from previous firmware versions? Could you try:
                      os.mkfs('/flash')
                      to format the file system and start from scratch...
                        livius @daniel
                        @daniel
                        3905 bytes
                        I will test with 1.6.2 and will see if something changed
                        I can erase all data - but i can back tomorrow with review
                          JF002 @daniel
                          @daniel With 1.6.1, I encountered some instabilities : the lopy hangs when trying to sync the project from Pymakr, and when I call gc.collect(). Are you aware of these issues? Is it possible that they are fixed in 1.6.2?
                            @livius can you show me an example of the gc.collect() crash?
                              JF002 @daniel
                              @daniel
                              import gc
                              gc.collect()
                              Just freeze my lopy. I noticed it when trying to fix another issue with ds1820 and mqtt : https://forum.pycom.io/topic/670/onewire-wifi-mqtt-crash/7
                                OK it happens, not always at the first time. I'm working on it... Wait for the 1.6.3.b1 coming a bit later...
                                  JF002 @daniel
                                  @daniel said in New firmware release, version 1.6.0.b1:
                                  Yeah, thank you! You're the best!
                                    1.6.3.b1 is out there. In my tests the gc.collect() problem is now fixed. @livius @JF002 please test and let me know... Thanks!
                                    N C 2 Replies Last reply Reply Quote 1
                                    • N Offline
                                      Neo @daniel
                                      @daniel Still hanging on LopY. In our script this is happening after wifi STA connect ... we have a gc.mem_free call. We removed all gc collect calls.
                                        Then it's not the gc anymore in your case. If you can share with me a piece of code that can reproduce it I'll get onto it.
                                        N 2 Replies Last reply Reply Quote 0
                                        • N Offline
                                          Neo @daniel
                                          @daniel Unfortunatelly the code is huge. I will try to reduce the area. I chekced also one auto tests only with LoRa initiation and Lora socket reading + gc.mem_free calls ... I saw that this test is hanging. I believe the real problem ties to memory leak /bad management. Here is the memory output at each second called soket recv and dump the mem_free:
                                          Memory 19264
                                          Memory 18656
                                          Memory 18080
                                          Memory 17504
                                          Memory 16928
                                          Memory 16352
                                          Memory 15776
                                          Memory 15200
                                          Memory 14624
                                          Memory 14048
                                          Memory 13472
                                          Memory 12896
                                          Memory 12320
                                          Memory 11744
                                          Memory 11168
                                          Memory 10592
                                          Memory 10016
                                          Memory 9440
                                          Memory 8864
                                          Memory 8288
                                          Memory 7712
                                          Memory 7136
                                          Memory 6560
                                          Memory 5984
                                          Memory 5408
                                          Memory 4832
                                          Memory 4256
                                          Memory 3680
                                          • N Offline
                                            Neo @daniel
                                            @daniel Here it is your memory leak script:
                                            def test2():
                                            from network import LoRa
                                            _lora = LoRa(mode=LoRa.LORA)
                                            _socket = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
                                            _socket.setblocking(False)
                                            import gc
                                            gc.enable()
                                                try:
                                                    bytes = self._socket.recv(512)
                                                    if len(bytes) > 0:
                                                        print(" %s RECV %s" %  (self, bytes))
                                                except Exception as e:
                                                        print("_recv", str(e))
                                                print('Memory %d' % (gc.mem_free()))
                                                utime.sleep(1)
                                            test2()
                                            • 3 / 4
