    firmware
    113 Posts 34 Posters 90.2k Views 32 Watching
      JF002
      I'll definitely try it as soon as possible !
      • V Offline
        vruizvil @daniel
        @daniel amazing news! lopy weekend, just in time!
          livius
          Hi @daniel congrats about success :)
          I do not have Lopy and i am interested if this release have something releated to Wipy2 too?
            @Clemens thanks. It was never my intention to create Hyperlinks, I just wanted to have then in bold, but somehow the forum treats then as such because of the .py extension, so I have removed that now.
              Clemens @daniel
              @daniel thx, you can avoid autolinking from *.py files by escape them as inline code
              Inline `code.py` has `back-ticks around` it.
              is
              Inline code.py has back-ticks around it.
              see the Markdown doc e.g. under https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#code
                bucknall
                Exciting to see this finally released! :D Let us know if you deploy your LoPy as a TTN (or other) Nano Gateway - would be cool to see it in use!
                Developer Evangelist - Pycom
                  this.wiederkehr
                  lora.rssi() is missing at least since 1.6.6.b1... could you fix please?
                  ah. for anyone wondering lora.rssi() seems to be deprecated in favor of lora.stats() this will output something like:
                  (timestamp=1502245986, rssi=-39, snr=29, sf=7)
                  documentation is as usual outdated...
                    @this-wiederkehr sorry, we haven't pushed the latest docs. There's a new method called stats, try:
                    lora.stats()
                    Which returns a namedtuple that contais the rssi, snr and other usefult data (from the last received packet).
                      jmarcelino
                      Wow, great development! :-) This is A LOT better than my simple gateway code, well done Pycom team. This will now run permanently on one of my LoPys.
                      Just a suggestion, there is a convention for Gateway IDs on TTN, they're usually the first 3 bytes of MAC address + FFFE + last 3 bytes of MAC address, so I added the following to config.py:
                      import binascii
                      CONVENTIONAL_EUI = binascii.hexlify(machine.unique_id()).upper()
                      CONVENTIONAL_EUI = CONVENTIONAL_EUI[:6] + "FFFE" + CONVENTIONAL_EUI[6:12]
                      # Set Gateway ID to the first 3 bytes of MAC address + 'FFFE' +  last 3 bytes of MAC address
                      GATEWAY_ID = CONVENTIONAL_EUI
                      # Alternatively uncomment and change this to your fixed Gateway EUI
                      # GATEWAY_ID = '11aa334455bb7788'
                      G 1 Reply Last reply Reply Quote 1
                      • Z Offline
                        zmrzli
                        I am not sure why there is no response to this problem... previously posted, so here it is again.
                        Am I the only trying to do this, or I am missing something obvious...?
                        Is is possible to change SSID of wipi in AP mode?
                        Following:
                        pycom.heartbeat(True)
                        uart = machine.UART(0, 115200) # disable these two lines if you don't want serial access
                        os.dupterm(uart)
                        from network import WLAN
                        wl = WLAN()
                        #trying to change AP properties:
                        original_ssid = "MyNode"
                        wl.ssid(original_ssid)
                        original_auth = (3,'bewell')
                        wl.init(mode=WLAN.AP, ssid=original_ssid, auth=original_auth, channel=6, antenna=WLAN.INT_ANT)
                        Does not change SSID visible on my iphone.
                        It remains wipy-wlan-xxx
                        Am I doing something wrong?
                        Or SSID is hardcoded regardless of what says in documentation:
                        "wlan.ssid([ssid])
                        Get or set the SSID when in AP mode.
                          robert-hh
                          Hello @zmrzli,
                          no idea what you did, but this sequence works for me:
                          wl = WLAN(AP)
                          wl.init(mode=wl.AP, ssid="My_lopy", auth=(wl.WPA2, "This is a Test"))
                          It takes a while before the change gets visible on the other devices, if these do not scan the networks frequently. Sometimes on cycling Wifi Off/On helps.
                            @zmrzli the answer from @robert-hh is correct, it just works like that, but some devices take a while to scan for networks again or to update the ssid if the MAC address is the same. Try switching the WiFi of your iPhone on and off as suggested.
                              @jmarcelino thanks for the suggestion! I'll include that on the next nano-gateway release along with the other planned improvements :-)
                                JF002
                                @daniel Congratulations for you and the whole team! I've just upgraded to 1.6.7.b1, and tried the examples (NanoGateway and OTAA node) and... it works like a charm! I'm currently sending my room temperature (from a DS18B20 sensor) on TTN using these examples!
                                For now, there is no TTN gateway at range at home, I have to move away from my home to find some signal. The possibility to create a "dev" nano-gateway that connects to TTN allows me to work on my projects from home, this is wonderful!
                                  johncaipa
                                  Very good news, we were expecting this !. Congratulations to the entire Pycom team.
                                    gertjanvanhethof Pybytes Beta
                                    This is really fantastic news. I immediately uploaded the code to by LoPy.
                                    TTN Dashboards shows gateway is connected!
                                    Now I have to test to send messages to it with my other LoPy.
                                      constantinos
                                      Daniel,
                                      I lost the functionality of receiving messages from RFM95. It was working with firmware version 1.2.2 and now is lost.
                                      I just receive nothing at all now.
                                        @constantinos please try playing with the public argument in the constructor:
                                        https://docs.pycom.io/pycom_esp32/library/network.LoRa.html#network.lora.init
                                        Before the last 2 releases the default of True for the public sync word was not being honoured, and now it is. Set this value to False and that will most likely make the LoPy work with the RFM95 again.
                                          constantinos @daniel
                                          @daniel Thanks! It works!
                                            rskoniec
                                            @daniel Really nice update! NanoGateway and OTAA node works like a charm! Thank you Pycom Dev Team! :)
                                            • 5
                                            • 6
                                            • 1 / 6
