Local file system access while connected to the home router
  • Hello,
    will I have an access to a local file system on WiPy via FTP when WiPy will be connected to the home router?
  • @michalt38 to do this you need run Wipy in mode
    WLAN.STA_AP
    but for me it can connect to router but i can not connect to it as AP.
    But i do not tested this in the current firmware - maybe it work now
  • I do it in the same way like Robert. I have this section in my main.py--perhaps it is better in boot.py ?--to connect to the local WiFi
    # WiFi configuration
    from network import WLAN
    # configure the WLAN subsystem in station mode (the default is AP)
    wlan = WLAN(mode=WLAN.STA)
    # go for fixed IP settings (IP, Subnet, Gateway, DNS)
    #wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
    wlan.scan()     # scan for available networks
    wlan.connect(ssid='your_ssid', auth=(WLAN.WPA2, 'your_password'))
    while not wlan.isconnected():
        pass
    print(wlan.ifconfig())
    I did not configure a static IP, but after the first connection to the WiFi network I specified "use always the same IP" in the DHCP configuraion of my Fritz box router.
  • That's right. Here is the little script snippet I run on startup:
    import network
    # setup as a station
    wlan.connect(ssid='my_ssid', auth=(network.WLAN.WPA2, 'my-passwd'))
        time.sleep_ms(50)
    wlan.ifconfig(config=("10.0.0.141", "255.255.255.0", "10.0.0.240", "192.168.44.66"))
    That sets the IP to 10.0.0.141
  • How can I set the WiPy IP address? In this command: wlan.ifconfig(config=('192.168.0.4', '255.255.255.0', '192.168.0.1', '8.8.8.8')) the first address is a WiPy's IP?
  • That's how I configured my WiPy and LoPy. They run in STA mode, and either get their IP address from the router, or I set fixed addresses from the router's network. Using that IP address, I can access them with ftp. They act just as a server on your LAN.
3 out of 6
