    firmware
    113 Posts 34 Posters 90.2k Views 32 Watching
      rskoniec @gas
      @gas Here is my TTN config:
      Gateway should be packet forwarder type.
        gas @jmarcelino
        @jmarcelino
        your right i was using the Gateway not the packet forwarder
        now it is connected cool
        but the exampe of otaa is wrong
        lora.join don't se deveui
        my node is connected over my Lopy LoRaWAN nanaGW OTAA
        github should be updated
          @gas, yes, the example force the deveui to some value, I'll update the code on githb to clarify that. Thanks!
            gas @daniel
            @daniel
            Great Job any and impressive both micropython and Pycom
            now let me try the range with my sample code of GPS ...
              @thanks! keep us posted about your results :-)
                Colateral @robert-hh
                @robert-hh I tried Windows10 ftp in browser as ftp://micro:python@192.168.4.1
                  ThatStudentGuy
                  After upgrading to the latest firmware i'm no longer able to send using raw Lora mode. I'm running the same code as i did before the weekend and it worked then. The code is basically the LoPy to LoPy code for sending and receiving. I did the firmware update. I tried to play around with the public parameter as told earlier but with no result.
                  Anyone else experiencing the same problem?
                    Clemens @ThatStudentGuy
                    @ThatStudentGuy The public parameter is for talking from LoPy to RFMs necessary. Your problem is related to theat but not the public variable. Unfortunately there was a major change in the LoRa specification section, you have to set parameter expicitly now, see
                    https://forum.pycom.io/topic/770/lora-receiving-only-b
                    It's a bit annoying that now all defailt examples here in the forum and also on git no more working, from y perspectiv a no go and very frustrating for new users. You are tolde that you have to update your board but the "simplest code you can get" is not working, see my comments about that under:
                    https://forum.pycom.io/topic/770/lora-receiving-only-b/4
                    In case there is a need for this heavily change it must be documented on a prominent location or the next release must have a kind of change or fix. Just my 2 cents! ;-)
                      ThatStudentGuy @Clemens
                      @Clemens
                      Thanks for your answer. That was indeed the problem.
                        Movsun
                        I have successfully connect the LoPy to TTN. But when I try the ABP and OTAA code on other LoPy I don't see data in TTN device. and device status is never connect. I use "binascii.hexlify(lora.mac()).upper().decode('utf-8')" to get my device EUI to register my device in TTN. and use the key they generate to put in the example code.
                        I have already update the to device to 1.6.7.b1. What should I try to find the problem?
                          @Movsun if you look at the OTAA example, you'll see that we are hardcoding the DEV_EUI:
                          # join a network using OTAA
                          Do the join like this in order to use the MAC address of the LoPy as EUI:
                            livius @daniel
                            @daniel
                            It looks like STA_AP mode work ok
                            and there is some issue with Windows10 system not Wipy itself
                            fixed by tip from @Colateral
                            https://forum.pycom.io/topic/679/ap-sta-mode/5
                            And another +
                            on 1.6.7 i do not see corruption of files compared to 1.6.3 version :)
                              rskoniec
                              Sometimes I see series of W (xxxxxxxxx) wifi: post pm rx bcn failed messages on my LoRaWAN Nano Gateway:
                              Push ack
                              Push ack
                              Push ack
                              W (147750288) wifi: post pm rx bcn failed
                              Pull ack
                              Pull ack
                              Pull ack
                              and Downlink timestamp error!, t_us: xxxxxxxxxx messages:
                              Push ack
                              Downlink timestamp error!, t_us: 4295216794
                              Pull rsp
                              Push ack
                              Downlink timestamp error!, t_us: 4295288926
                              Pull rsp
                              Pull ack
                              Push ack
                              Downlink timestamp error!, t_us: 4295280463
                              Pull rsp
                              Push ack
                              Pull ack
                              I would like to know a little bit more about these.
                              Thank you in advance.
                                @rskoniec I'm also seeing those and I'm investigating the cause together with Espressif.
                                  Movsun @daniel
                                  @daniel Thank you, And if I want to use 250 khz bandwidth. which code should I modify in both the gateway and node?
                                    rskoniec @daniel
                                    @daniel said in New firmware release 1.6.7.b1 (LoRaWAN Nano Gateway with TTN example!!):
                                    OK, thank you @daniel I hope you'll find the cause of those.
                                      daniel @Movsun
                                      @Movsun just change the bandwidth (to make it 250 KHz) argument in the LoRa constructor for both LoPy's.
                                        jomifo Pybytes Beta @daniel
                                        @daniel +1 to see code adapted for US frequencies.
                                          Colateral
                                          Hello Daniel,
                                          You promised weeks ago (around build 1.3.0) that you will enable frozen bytecode. When this will happen?
                                            johncaipa
                                            Is there anyone who has tested how many nodes could be received in practice with the nano-gateway?
                                            • 5
                                            • 6
                                            • 3 / 6
