    firmware
    113 Posts 34 Posters 92.0k Views 32 Watching
      rskoniec
      Sometimes I see series of W (xxxxxxxxx) wifi: post pm rx bcn failed messages on my LoRaWAN Nano Gateway:
      Push ack
      Push ack
      Push ack
      W (147750288) wifi: post pm rx bcn failed
      Pull ack
      Pull ack
      Pull ack
      and Downlink timestamp error!, t_us: xxxxxxxxxx messages:
      Push ack
      Downlink timestamp error!, t_us: 4295216794
      Pull rsp
      Push ack
      Downlink timestamp error!, t_us: 4295288926
      Pull rsp
      Pull ack
      Push ack
      Downlink timestamp error!, t_us: 4295280463
      Pull rsp
      Push ack
      Pull ack
      I would like to know a little bit more about these.
      Thank you in advance.
        @rskoniec I'm also seeing those and I'm investigating the cause together with Espressif.
          Movsun @daniel
          @daniel Thank you, And if I want to use 250 khz bandwidth. which code should I modify in both the gateway and node?
            rskoniec @daniel
            @daniel said in New firmware release 1.6.7.b1 (LoRaWAN Nano Gateway with TTN example!!):
            OK, thank you @daniel I hope you'll find the cause of those.
              daniel @Movsun
              @Movsun just change the bandwidth (to make it 250 KHz) argument in the LoRa constructor for both LoPy's.
                jomifo Pybytes Beta @daniel
                @daniel +1 to see code adapted for US frequencies.
                  Colateral
                  Hello Daniel,
                  You promised weeks ago (around build 1.3.0) that you will enable frozen bytecode. When this will happen?
                    johncaipa
                    Is there anyone who has tested how many nodes could be received in practice with the nano-gateway?
                      Colateral @johncaipa
                      @johncaipa So far we tested with 7 nodes .... but not with pycom nano-gw example.
                        gerkez
                        Hello Daniel,
                        The scripts look great, but I don't seem to get them working.
                        I have created a gateway in the TTN console, but the gateway doesn't connect.
                        I have a WiFi connection to my router, so that is not the problem.
                        In your config.py:
                        the GATEWAY_ID = '11aa334455bb7788'. Where did you get this ID?
                        I created my own ID when I registered a gateway at TTN console.
                        Can I leave the LORA_DR = "SF7BW125" # DR_5 unchanged?
                        In the nanogateway.py:
                        def stop(self):
                        # TODO: Check how to stop the NTP sync
                        # TODO: Create a cancel method for the alarm
                        # TODO: kill the UDP thread
                        self.sock.close()
                        I have no idea how to handle those TODO's.
                        Can you give some examples?
                        Hopefully you can help a newbee to get this working.
                        GerkeZ
                          @gerkez you can put there in the Gateway ID that you created when registering it to TTN.
                          Yes.
                          Don't worry about those TODO's, those will be taken care of on a future update of the nanogateway scripts.
                            jmarcelino @gerkez
                            @gerkez
                            also make sure you have selected the "packet forwarder" protocol when registering the gateway in TTN. I think your ID question may relate to this.
                              gerkez @daniel
                              @daniel
                              Thanks. I'll try it and let you know
                                gerkez @jmarcelino
                                @jmarcelino
                                Hi. Thanks.
                                I deleted my gateway and registered a new one with the "packet forwarder" protocol.
                                It generates a Gateway ID based on the EUI (eui-70b3d54991ae49e8).
                                I tried both ID's in the config.py.
                                eui-70b3d54991ae49e8: script runs but the console displays "not connected".
                                70b3d54991ae49e8 (without prefix eui-): script runs but restarts all the time.
                                Here is my config.py:
                                GATEWAY_ID = 'eui-70b3d54991ae49e8' (not working)
                                GATEWAY_ID = '70b3d54991ae49e8' (infinite loop, restart)
                                SERVER = 'bridge.eu.thethings.network'
                                PORT = 1883
                                NTP = "pool.ntp.org"
                                NTP_PERIOD_S = 3600
                                WIFI_SSID = 'my ssid'
                                WIFI_PASS = 'my passwd'
                                LORA_FREQUENCY = 868100000
                                  The correct gateway ID to use is: 70b3d54991ae49e8
                                  These 2 parameters are incorrect:
                                  PORT = 1883
                                  Please use the same as in the example, which are:
                                  SERVER = 'router.eu.thethings.network'
                                  PORT = 1700
                                    gerkez @daniel
                                    @daniel
                                    @jmarcelino
                                    Hi Guys,
                                    Thanks a lot for helping.
                                    I have a connection to TTN, but is seems that my lopy reboots all the time (every 30 -60 seconds).
                                    I hav put a red led for 3 seconds in main.py and I can see this red led light up all the time and than I lose my connection (wiFi as well).
                                    Hope you have an idea what's going wrong
                                    L S 2 Replies Last reply Reply Quote 0
                                      livius @gerkez
                                      @gerkez
                                      What you got on UART REPL?
                                      Put info here - there can be some usefull info
                                      G 2 Replies Last reply Reply Quote 0
                                        gerkez @livius
                                        @livius
                                        Hello Livius,
                                        My pymakr doesn't work. Connection errors.
                                        So I use Putty. Problem is that the device reboots all the time, so I don't see anything on the UART REPL
                                          livius @gerkez
                                          @gerkez
                                          Try Arduino IDE -> COM port monitor instead
                                          • Z Offline
                                            zmrzli @Colateral
                                            @Colateral
                                            My problem was that password was not long enough. Once I changed it, it worked fine. It would be better if some indication was given about a problem from WiPy, but no big deal, once understood...!
                                            • 5
                                            • 6
                                            • 4 / 6
