    Firmware Update Fails
    wipy 2.0debianupdate failed
    41 Posts 7 Posters 21.0k Views 7 Watching
      livius @mike632t
      @mike632t
      For XP you can fiund drivers too - but on XP (laptop) i have UART TTL -> USB converter and work ok
      I do not know if the same will be for drivers for expansion board
        bucknall @jmarcelino
        Thanks @jmarcelino!
        I believe the Linux Firmware Updater should be working correctly now!
        @mike632t I'd suggest a couple of things:
        1. Ensure all the headers on the expansion board are connected
        2. Try changing USB port on your computer
        3. Do you have the jumper cable connected across pins GND and G23 on the expansion board? (I know it's been asked but this is normally the cause!)
        Developer Evangelist - Pycom
          mike632t @bucknall
          @bucknall
          1. Yes they are
          2. Tried that makes no difference
          3. Yes and the initial serial communication to detect the type of device works.
          Serial communication with the 'console' works on all the ports I've tried, and the script is able to communicate with the board to discover what type of device it is but it exits when it checks the contents of the temporary file that it tried to download from the web using curl.
          Mike T.
          Mike T.
            bucknall @mike632t
            @mike632t Hmm odd, let me check this internally! Will get back to you ASAP!
              robmarkcole
              Is it possible to update without the USB? I only have wifi connection to my Wipy and using the iOS app failed..
                livius @robmarkcole
                @robmarkcole
                at this time no - only RS232 (or UART TTL -> USB converter)
                R 2 Replies Last reply Reply Quote 0
                  robmarkcole @livius
                  @livius thanks :)
                    robmarkcole @livius
                    @livius I saw a youtube video yesterday where the guy used a nodeMCU to provide the UDB-sserial connection for a Lopy, is there a guide? I have a nodeMCY (bricked), raspberry pi and a particle photon available..
                      robert-hh
                      I would assume that they simply used the USB/Serial chip on the NondeMCU for that purpose, connecting RX-RX and TX-TX of the two devices. The nodemcu board has to be powered for that purpose. The problem is to get the TX pin of the NodeMCU to high impedance and have the NodeMCU to be silent. One guess would be to keep in in reset (pull reset low).
                      A similar approach is sometimes told with an Arduino.
                        robmarkcole @robert-hh
                        @robert-hh Thanks for the info, if I get it working I will make a post :)
                          szatmari60
                          I have the same issue with two WiPy 2.0 boards ,
                          ( (sysname='WiPy', nodename='WiPy', release='1.6.3.b1', version='v1.8.6-463-g468b9d27 on 2017-02-16', machine='WiPy with ESP32')
                          and
                          (sysname='WiPy', nodename='WiPy', release='1.6.3.b1', version='v1.8.6-463-g468b9d27 on 2017-02-16', machine='WiPy with ESP32') ) ,
                          the the first one I manage to upgrade maybe a month ago !
                          I can connect to my boards using FTDI , I am a linux user, except this issue everything is OK!
                          The updater fails to connect and throw an error : "Something failed trying to connect to the device"
                          Can anybody help ...
                            robert-hh
                            Hello @szatmari60, if you get an REPL prompt using USB, then the basic communication works. Do you know, which interface is used for the REPL prompt. The same is needed for the update. The updater changed in that it fetches the image directly from the Pycom web site during update. So be sure that a connection is possible. I do not know whether mike632t finally succeeded. The was no response during the last three days. If you look in the board for the downgrade instructions, you'll see a method to upload the file locally. From these instructions you can easily guess the names of the most recent files, which are available too.
                              mike632t @szatmari60
                              @szatmari60
                              That seeme like the error I got before I installed the python-serial package.
                              Mike T.
                                szatmari60 @robert-hh
                                Hello, and thank you!
                                YES I get a REPL prompt using USB (FTDI chip FT232RL), the basic communication works with Pymkr, screen, ESPlorer, I also can upload files with "ftp"
                                Booting process:
                                ets Jun 8 2016 00:22:57
                                configsip: 0, SPIWP:0x00
                                mode:QIO, clock div:2
                                load:0x3fff9010,len:8
                                load:0x3fff9018,len:248
                                load:0x40078000,len:4056
                                load:0x4009fc00,len:920
                                entry 0x4009fde4
                                I (1577) wifi: frc2_timer_task_hdl:3ffd4a2c, prio:22, stack:2048
                                I (1592) wifi: Init lldesc rx mblock:10
                                I (1593) wifi: Init lldesc rx ampdu len mblock:7
                                I (1593) wifi: Init lldesc rx ampdu entry mblock:4
                                I (1594) wifi: pp_task_hdl : 3ffdbb68, prio:23, stack:8192
                                I (1599) wifi: sleep disable
                                I (2588) wifi: mode : softAP (24:0a:c4:00:b4:93)
                                MicroPython v1.8.6-463-g468b9d27 on 2017-02-16; WiPy with ESP32
                                ">>>import os
                                ">>>os.uname().release
                                ">>>'1.6.3.b1'
                                But the "uploader" cannot communicate with WiPy 2.0. I tried to run manualy on terminal "updater.py" file.
                                This is the result:
                                ...:~/pyupgrade$ ./bin/updater.py --port "/dev/ttyUSB0 --speed 19200 wmac
                                Connecting...........................................
                                Exception: Failed to connect to ESP32: Invalid head of packet ('\x08'), on line 161
                                I am runnig out of ideas !!
                                  robert-hh @szatmari60
                                  @szatmari60 Even with the manual updater, have you installed the wire between GND and GP23, and Reset after that?
                                    Hello Robert!
                                    YES! And I managed to upgrade my another WiPy 2.0 two or three weaks ago. On original firmware I do not get working ADC.
                                    Upgraded one booting:
                                    PORT OPEN 115200
                                    Communication with MCU..Got answer! Communication with MCU established.
                                    AutoDetect firmware...
                                    Can't autodetect firmware, because proper answer not received (may be unknown firmware).
                                    Please, reset module or continue.
                                    Jun 8 2016 00:22:57
                                    entry 0x4009fde4
                                    I (1515) wifi: wifi firmware version: 90b1b8b
                                    I (1516) wifi: config NVS flash: disabled
                                    I (1516) wifi: config nano formating: disabled
                                    I (1531) wifi: Init dynamic tx buffer num: 32
                                    I (1532) wifi: wifi driver task: 3ffbd714, prio:23, stack:3584
                                    I (1532) wifi: Init static rx buffer num: 10
                                    I (1534) wifi: Init dynamic rx buffer num: 0
                                    I (1538) wifi: Init rx ampdu len mblock:7
                                    I (1542) wifi: Init lldesc rx ampdu entry mblock:4
                                    I (1546) wifi: wifi power manager task: 0x3ffd99a8 prio: 21 stack: 2560
                                    I (1553) wifi: sleep disable
                                    I (2542) wifi: wifi timer task: 3ffdaa3c, prio:22, stack:3584
                                    I (2559) wifi: Init ampdu: 0
                                    I (2559) wifi: mode : softAP (24:0a:c4:00:68:b1)
                                    MicroPython v1.8.6-504-gff1098f6 on 2017-03-13; WiPy with ESP32
                                    os.uname().release
                                    '1.6.8.b1'
                                      jmarcelino @szatmari60
                                      @szatmari60
                                      You should not be getting those messages if you really have GND and G23 connected.
                                      When you have GND+G23 the board goes into a special loader mode. In this mode if you use a terminal program on that port (at 115200) you'll see:
                                      rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
                                      waiting for download
                                      Make sure your connections are OK, maybe even replace the jumper cable to make sure there is a connection.
                                      Also make sure there is nothing else connected to the other pins on the board.
                                      S 2 Replies Last reply Reply Quote 0
                                        szatmari60 @jmarcelino
                                        Hello jmarcelino !
                                        I checked and rechecked and rechecked with may two board, I folloed the regulations, no cure in may case until now.
                                        J S 2 Replies Last reply Reply Quote 0
                                          @szatmari60
                                          Are you sure the jumper cable connecting G23 and GND is working? Can you check continuity or try another one. I had a broken jumper cable last week in prototype - it was a nightmare.
                                          I'm just saying that if you do have G23 and GND connected and nothing else it's nearly impossible that you are getting those regular boot messages. It's a really low level feature of the chip.
                                            szatmari60 @szatmari60
                                            @szatmari60
                                            What "terminal program" can I us to detect if the P 23 is actually "DOWN" ?
                                            I change the wires, also the bredboard...
                                            • 1 / 3
