    Firmware upgrade 0.9.2.b2
    11 Posts 6 Posters 2.8k Views 6 Watching
      AgriKinetics
      @abilio Still fails for me on a Windows 7 machine. Doesn't fail immediately as with 0.9.2.b1, but takes about 30 seconds or so. The fix as described by @Xykon - https://forum.pycom.io/topic/88/how-to-solve-the-firmware-update-failures works well though.
      • X Offline
        Xykon administrators
        Same here... upgrade fails and after a reset there is a flash read err, 1000.
        I admit though that I'm currently using native esp32 code to map the pinout of the LoPy and just re-flashed the stock image I took before experimenting with esptool for the first time.
        I'll give this another try later as I really want to finish the pin mapping first. Not sure when I'll get around to it as I'm playing Golf early tomorrow morning and I have a Halloween party tomorrow night.
        Christian Ehlers
          abilio @AgriKinetics
          @AgriKinetics Are you using an expansion board?
            livius
            The same failed - but i have Windows 10 and WiPy2.0
            Steeps by Xykon work - but tool not
              AgriKinetics
              @abilio Yes, we are using the expansion boards jump G23 (Blue LED at top - 4th pin down on left) to GND (2nd pin down on right)
                livius
                and it does not start also in self mode
                1 Reply Last reply Reply Quote -1
                  LoneTech
                  Thanks for the update. I'm kind of hoping we won't need to keep overwriting the bootloader in the future.. also, you didn't bump the version number in the Linux update script. It surprised me by placing 0.9.2.b1 in the factory partition.
                    digsatman
                    WIndows standalone did not work from GUI but Xykon method using command line work fine. Also used the same method to update my Wipy2's - Pleased that all my LoPy and Wipy2 devices now running latest software. Also pleased that docs are slowly improving. Look forward to being able to use the MicroSD card on the expansion board at some stage although I expect there are more important things to fix/implement first., Hope to test out some I2C over the weekend.
                      abilio
                      This has been checked. A new tool is about to be published, expect it in a few minutes.
                        abilio
                        An errata for this release has been published. Please check https://forum.pycom.io/topic/131/firmware-upgrade-errata-v-0-9-2-b2 for more information.
