    New firmware release 1.6.9.b1 (frozen code support and framebuf)
    firmware
    29 Posts 9 Posters 11.6k Views 9 Watching
      Guys, I found the bug, I'll push to github and we'll release again tomorrow.
        Here's the fix: https://github.com/pycom/pycom-micropython-sigfox/commit/195813d432d9f41314ef9923104b21db1282edf8
          livius
          Now i2c work for me back in 1.6.9 :)
            arneme @daniel
            @daniel While trying to do some rudimentary testing of the Bluetooth functionality in version 1.6.9.b1 I noticed something strange. The adv.mac seems to be incomplete (i.e. in the print("Try to connect to the H7 with mac:", adv.mac) line only a few of the bytes in the mac is printed out) and thus I am not able to connect to discovered peripherals.
            from network import Bluetooth
            bt = Bluetooth()
            bt.start_scan(-1)
            # Code to connect to Polar H7 Bluetooth heartrate sensor
            # The detected Heartrate is "published" over the LoRaWAN network
                adv = bt.get_adv()
                if adv:
                    name = bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL)
                    if name is not None:
                        if name.startswith("Polar H7"):
                            print ("Found: " + name)
                            bt.stop_scan()
                            try:
                                conn = bt.connect(adv.mac)
                                print("Connected...")
                                services = conn.services()
                                print("Got services...")
                                for service in services:
                                    time.sleep(0.05)
                                    # According to specification from Polar, service.uuid = 0x180D is Heart Rate and char.uuid = 2a37 is value in beats per minutes
                                    if service.uuid() == 0x180D:
                                        print('Reading from service %x' % service.uuid())
                                        chars = service.characteristics()
                                        print("Print chars found")
                                        for char in chars:
                                            print('char %x' % char.uuid())
                            except Exception as ex:
                                print("Exception caught...")
                                print(ex)
              jmarcelino @arneme
              @arneme
              Can you post an example of your print() result please?
              For example I get:
              MAC: b'\x14X\x02\x00\x00\xa9'
              MAC: b'gFb\xd0\xc1\xf5'
              MAC: b'\x14X\x00\x03\x01k'
              MAC: b"\xc2f\xf7'\xec\xc0"
              all 6 bytes long, though difficult to read because print only shows hex for non-printable characters.
                arneme @jmarcelino
                @jmarcelino My bad, the bytes are all there when printing like this:
                print("Try to connect to the H7 with mac:", binascii.hexlify(bytes(adv.mac)))
                Still not able to connect though.
                  rdixey @jmarcelino
                  @jmarcelino Interesting! Using P21 for SCL does work, and I2C Init does assign P21 with alt=-1. P9 still gets assigned with alt=198 but works okay for SDA. After I install Daniels next update I'll revert back to using P8 for SCL to see if it works again.
                  Thanks for the advice!
                  >>> i2c = I2C(0, I2C.MASTER, baudrate=400000, pins=("P9", "P21"))
                  >>> i2c.scan()
                  [96, 112]
                  >>> Pin.exp_board.G8
                  Pin('P21', mode=Pin.OPEN_DRAIN, pull=Pin.PULL_UP, alt=-1)
                  >>> Pin.exp_board.G16
                  Pin('P9', mode=Pin.OPEN_DRAIN, pull=Pin.PULL_UP, alt=198)
                  >>> Pin.exp_board.G15
                  Pin('P8', mode=Pin.OPEN_DRAIN, pull=Pin.PULL_UP, alt=198)
                  Running SI1145.py  <<----- I2C UV Light Sensor
                  memfree 39392
                  Vis: 263
                  IR: 287
                  Prox: 256
                  UV: 3
                  UVIndex: 0.03
                  memfree 39072
                    jmarcelino @arneme
                    @arneme
                    I happen to have a Polar H7 HR monitor and can confirm that the connection gets dropped almost immediately after establishing, there's no chance to retrieve services so the code terminates with a 'connection already closed'
                    I don't have my BLE sniffer setup at the moment but did a quick trace of a typical connection using another BLE tool (http://pastebin.com/HwDsWffG) and can see the H7 may expect some features the LoPy isn't ready for yet. If the H7 gets anything it doesn't expect (like a rejection for it's request to update connection parameters) it simply drops the connection - that may be what's happening.
                    If you have a BLE sniffer you may be able to see it. I'll try to return to this when I get some time. I suspect once BLE supports pairing this would also resolve itself, but that may be further out.
                    • N Offline
                      nevercast
                      @daniel Missing branch 'github' in the URL for Frozen code. Should probably be 'master'
                      https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/README.md
                        Shaun @daniel
                        @daniel
                        Evening Daniel.
                        I would also like to report that this revision is sending all REPL text to UART0 as well, even though I have not configured it this way in my boot.py file. I have always been using UART 0 for my application and using Telnet over WiFi for my REPL interface.
                          Hi @shaun you can override that by putting this inside your boot.py:
                          os.dupterm(None)
                          Let me know if that's OK in your case.
                          The idea behind the new behaviour is to make the UART REPL accessible during safe boot.
                            Shaun @daniel
                            @daniel Thanks, that corrected the behavior. All previous revisions had this disabled by default. Why the change?
                            O wait, I see the answer existed before my question in your post below. :-)
                            This revision still keeps freezing solid after some time though.
                            I hope you can find the issue before the new release tomorrow.
                              Butch @daniel
                              @daniel said in New firmware release 1.6.9.b1 (frozen code support and framebuf):
                              @Butch, this firmware release is pretty much the same as before 1.6.8.b2 only that it adds 8KB of extra heap. Can you try a safe boot, format the file system of the problematic LoPy and put the scripts back again after a normal reset?
                              Is it possible to revert to the earlier version? This version seems to be not very useful right now, and I need to get back to making progress. I'd really like to go back to 1.6.8b2.
                                robert-hh @Butch
                                @Butch See this link about downgrade: https://forum.pycom.io/topic/517/downgrading-firmware-advanced-users
                                V1.6.8b2 links are canonically derived according to the list:
                                https://software.pycom.io/downloads/LoPy_868-1.6.8.b2.tar.gz or
                                https://software.pycom.io/downloads/LoPy_915-1.6.8.b2.tar.gz or
                                https://software.pycom.io/downloads/WiPy-1.6.8.b1.tar.gz
                                • 2 / 2
