    Arduino sends data seriell, how to get them into WiPy ? **SOLVED**
    wipyseriellarduinorxtxsolved
    13 Posts 5 Posters 4.5k Views 5 Watching
      robert-hh
      You can use UART and connect TX-RX, RX-TX and GND. Please check first whether the two devices runs at the same supply range of 3.3 V. Arduino devices often run at 5V. If yes, use a level shifter. On WiPy, you can use the UART class for communication, which can be freely configured. If you use the standard UART port, whci is also served by the REPL prompt, you can also sys.stdin.read(), sys.stdin.readline() and sys.stdout.write() at 115200 baud.
      For debugging you could send whatever you get on serial to a socket.
      You could also try implement the sensor code on the WiPy.
      • H Offline
        Hotzenwald @robert-hh
        @robert-hh thanks for your fast answer. I use a couple of shields at the arduino R3 and will not be able to convert this for WiPy.
        • H Offline
          Hotzenwald @RobTuDelft
          @RobTuDelft had a look at i2C and think this is what i should try. Thanks
          • H Offline
            @RobTuDelft sorry, i am not that familiar with WiPy. I get this Error:
            ImportError: cannot import name I2C
            This is just example code i found
            rom network import WLAN
            from machine import I2C
            #configure the I2C bus
            i2c.scan() # returns list of slave addresses
            print('I2C ist aktiviert')
            Do i have to prepare something else ?
              robert-hh
              I tested that code snippet on my LoPy and it works.
              What kind of WiPy and MP version are you using?
              Look at the output of:
              import uos
              uos.uname()
              • H Offline
                @robert-hh Thanks. Managed to do a firmware update and now works.
                (sysname='WiPy', nodename='WiPy', release='1.6.8.b1', version='v1.8.6-504-gff1098f6 on 2017-03-13', machine='WiPy with ESP32')
                • V Offline
                  vruizvil @Hotzenwald
                  @Hotzenwald
                  My code to read Arduino Serial port, works fine for me.
                  #initialize serial port on P3 P4 (Tx Rx)
                  uart1=machine.UART(1, 115200)
                  def serialrecv(uartport):
                    #read the length of the data, letter by letter until we reach EOL
                    length_str = ''
                    char = uartport.read(1)
                    while char.decode() != '\r':
                       length_str += char.decode()
                    return length_str
                  while (True):
                      #read the serial message
                      serialdata=serialrecv(uart1)
                      print(serialdata)
                    livius @Hotzenwald
                    @Hotzenwald
                    woow 1.6.8?
                    @daniel i do not see any info about this?
                    • V Offline
                      @Hotzenwald Hi!!
                      I use Lopy. In my project, connecting from lopy P3(TX1) to arduino PIN0(RX) and lopy P4(RX1) to arduino uno PIN1(TX) it works. You need initialize uart1 whit the same baud rate than arduino.
                      Here my arduino code to read DHT11 temperature sensor.
                      #ARDUINO CODE TO READ DHT11 VALUES AND SEND IT TO SERIAL ON JSON FORMAT
                      include <SimpleDHT.h>
                      // for DHT11,
                      //      VCC: 5V or 3V
                      //      GND: GND
                      //      DATA: 2
                      int pinDHT11 = 2;
                      SimpleDHT11 dht11;
                      void setup() {
                        Serial.begin(115200);
                      void loop() {
                         byte temperature = 0;
                        byte humidity = 0;
                        if (dht11.read(pinDHT11, &temperature, &humidity, NULL)) {
                          Serial.print("Read DHT11 failed.");
                          return;
                        Serial.print("{\"T\":"); Serial.print((int)temperature); Serial.print(",");
                        Serial.print("\"H\":"); Serial.print((int)humidity); Serial.println("}");
                        // DHT11 sampling rate is 2HZ.
                        delay(2000);
                      • RobTuDelftR Offline
                        RobTuDelft
                        I think indeed a communication through UART is the best option. Also see the tutorial I wrote here: https://forum.pycom.io/topic/978/lopy-arduino-serial-communication.
                        Hope that helps.
                        Hackster | About me
                        • H Offline
                          Hotzenwald @Hotzenwald
                          solved.
                          The problems i had has been level shifter dependend. I used another one and UART started to work.
                          Another trap has been a misunderstanding in PIN numbering and PIN layout. When i just looked at WiPy pinout without paying attention to expansion board i noticed, that i used the wrong PINs. Now i count from left side, starting with 0 and figured out which PINs i do have to use.
                          Now it works like a charm.
                          Thanks for all your help !
