    MG996R + PWM 3V3 **SOLVED**
    wipiservopwm
    5 Posts 2 Posters 2.7k Views 2 Watching
      livius
      have someone connected succesfully servo MG996R?
      I try but without success.
      What i have tested already:
      1. separate power supply for Wipy and separate for servo (GND connected between)
      from machine import PWM
      pwm = PWM(0, frequency=50)   #50???
      pwm_c = pwm.channel(0, pin='P7', duty_cycle=0.5)
      1. tested direct driving pwm from wipy to servo
      2. tested with level shifting by 2N7000 on PWM signal
      i can not got succesfull :(
      With arduino it was so simple - i suppose that here should be same..
      and i think that i have missed something obvious
      RobTuDelftR 1 Reply Last reply Reply Quote 0
      • RobTuDelftR Offline
        RobTuDelft @livius
        @livius
        From the spec sheets:
        You seem to use a different duty cycle than is required?
        I believe duty cycle is only 10 or 20 %?
        Hackster | About me
          livius @RobTuDelft
          @RobTuDelft
          yes - thats it - i supposed that it is from 0 to 100%
          i have max right on
          pwm_c.duty_cycle(0.034)
          i have max left
          pwm_c.duty_cycle(0.127)
          thank you
            RobTuDelft @livius
            @livius Great! What voltage is the final PWM signal? Are you just using the raw pin output?
            Hackster | About me
              livius @RobTuDelft
              @RobTuDelft
              5V i use 2N7000 NMOSFET transistor for level shifting for testing
              for final i use smd BSS138
