Downgrade SiPy firmware
  • Re: Downgrading firmware (advanced users)
    Hello all.
    I want to do a downgrade to the previous version my SiPy module, but
    on the forum I can find only LoPy and WiPy old firmware.
    Where can I find the SiPy old firmware?
    Thankyou.
    Best Regards.
  • @livius
    As previous I intend SiPy-1.6.7.b1.tar
    I can post you the entire code, but this could be used only with our device connected to the UART serial port.
    Anyway, I post you the code used to handle sockets, because I suspect that the issue could be
    related to this task:
    import _thread
    import tracingfunction
    # Global array for rx data from serial port
    SerialRxPacketsLock = _thread.allocate_lock()
    # this value define the max number of parallel socket!
    # Don't configure a value grather than the maximum allowable connections
    # on uart device!! (see the define MAX_SOCK_NUM in the uart device project)
    MaxNumActiveSockets = 6
    # this arry is used by the task serialport to request a close on the relative socket
    KillRequestSocketList = bytearray(MaxNumActiveSockets)
    # this mutex is used to avoid thread conflicts in th access of the list of packets and socket
    SocketListLock = _thread.allocate_lock()
    # list of packets that must be sent on a particular socket
    rxPacketsFromSerialPortList = []
    # list of enabled sockets
    socketList = []
    # list of id related to the socket!
    socketUniqueIdList = bytearray(MaxNumActiveSockets)
    pycom.heartbeat(False)
    currentRGBLed = 0x007f00
    # this function return the number of current active sockets
    def GetNumOfActiveSocketList():
        global SocketListLock
        global socketList
        global MaxNumActiveSockets
        idx=0
        totalActiveSocket=0
        SocketListLock.acquire()
        while(idx<MaxNumActiveSockets):
            if(socketList[idx]!=None):
                totalActiveSocket=totalActiveSocket + 1
            idx = idx + 1
        SocketListLock.release()
        return totalActiveSocket
    # this function return the position of the first free socket slot
    def ObtainSocketListPosition():
        idx=0
            if(socketList[idx]==None):
                break
            idx = idx + 1
        if(idx==MaxNumActiveSockets):
            idx=-1
        return idx
    def toggleRGBLed():
        global currentRGBLed
        if(currentRGBLed==0x007f00):
            currentRGBLed=0
            currentRGBLed=0x007f00
        pycom.rgbled(currentRGBLed)
    # socketThread
    # This task is responsible to handle data from/to the socket
    def socketThread(voidPar):
        import stuffingfunctions
        global socketList
        global SerialRxPacketsLock
        global rxPacketsFromSerialPortList
        global KillRequestSocketList
        # we print on the terminal that the thread started
        print ("socketThread Started")
        # set counters and ids to zero
        idxSocketToCheck = 0
        aliveCounter = 0
        pycom.rgbled(0x00007f)
        # infinite loop!
            # increase the alive counter
            aliveCounter = aliveCounter + 1
            # if the alive counter reachs 15000, print on the
            # terminal that this thread is alive
            if(aliveCounter>15000):
                aliveCounter = 0
                print("socketThread alive!!")
            # assign the thread socket position
            threadIdPos = idxSocketToCheck
            # if there is a kill request, the buffer is empty and the socket is valid, close the socket
            if(KillRequestSocketList[threadIdPos]==1) and (socketList[threadIdPos]!=None) and (rxPacketsFromSerialPortList[threadIdPos]==None):
                socketList[threadIdPos].close()
                socketList[threadIdPos]=None
                KillRequestSocketList[threadIdPos]=0
                print("Socket " + str(threadIdPos) + " killed!")
            # acquire the mutex
            SerialRxPacketsLock.acquire()
            if (socketList[threadIdPos]!=None):
                # if the current socket is alive
                if(rxPacketsFromSerialPortList[threadIdPos]==None):
                    # if there is no data to send, do nothing
                    pass
                    # if there is data to send, try to send it
                    try:
                        print("Writing data into socket " + str(threadIdPos))
                        socketList[threadIdPos].send(rxPacketsFromSerialPortList[threadIdPos])
                        print("Write data ok")
                        rxPacketsFromSerialPortList[threadIdPos]=None
                        toggleRGBLed()
                        # pycom.rgbled(0x007f00)
                    except:
                        # in case of exception, trace on file and close the socket
                        print("Exception sending data " + str(threadIdPos))
                        tracingfunction.TraceLine("Exception sending data to the socket!")
                        stuffingfunctions.WriteStuffingSerialPort(None, 0,threadIdPos, 1, socketUniqueIdList[threadIdPos])
                # if the current socket is not alive, drop the data...
            # release the mutex
            SerialRxPacketsLock.release()
                # set partialData to None
                partialData=None
                    try:
                        data=None
                        #Receiving from client
                        data = socketList[threadIdPos].recv(1460)
                        if not data:
                            # if we have not received anitying
                            if (partialData!=None):
                                # in this case, if we have partial data != none, the data is only in the partialData array
                                data=partialData
                                print("Received data from socket " + str(threadIdPos) + " Len: " + str(len(data)))
                                stuffingfunctions.WriteStuffingSerialPort(data, len(data),threadIdPos, 0 , socketUniqueIdList[threadIdPos])
                                toggleRGBLed()
                                # pycom.rgbled(0x00007f)
                            break
                            if(len(data)>0):
                                # if we have received something
                                if(len(data)==1024):
                                    # in this case, there are probably many bytes to read (python slices packets greather than 1024 in multiple packets)
                                    # we save this data in the partialData and we issue a new read request...
                                    partialData=data
                                    time.sleep(0.002)
                                    continue
                                        # in this case, if we have partial data != none, we compose the full packet
                                        partialData = partialData + data
                                        data = partialData
                                        # in this case, the data is only in the data array
                                        pass
                                    # we pass the packet to the serial port!
                                    toggleRGBLed()
                                    break
                            break
                    except socket.timeout:
                        if data:
                            if(len(data)>0):
                                # added 30/03/2017 10.17 ----->
                                    data = partialData
                                    pass
                                # added 30/03/2017 10.17 <-----
                                print("Received data from socket " + str(threadIdPos))
                                toggleRGBLed()
                        break
                    except socket.error:
                        # in case of error exception, we close the socket
                        print("Closing socket thread " + str(threadIdPos))
                        if(socketList[threadIdPos]!=None):
                            stuffingfunctions.WriteStuffingSerialPort(None, 0,threadIdPos, 1 , socketUniqueIdList[threadIdPos])
                        break
            # we increase the socket idx
            idxSocketToCheck = idxSocketToCheck + 1
            # eache time we parse all sockets, we do a pause of 2 ms
            if idxSocketToCheck==MaxNumActiveSockets:
                time.sleep(0.002)
        # we should never reach this point
        print ("ThreadRx " + str(threadIdPos) + " terminated!")
  • @sriboli
    As previus do you mean 1.6.9?
    And any chance to see sample code to reproduce problem?
  • @livius
    My usage is a sort of "proxy http server".
    Substantially my module waits for socket connections on the port 80 (up to 6 parallel
    sockets to download the web page elements simultaneously).
    Any data sent by the client to the module is forwarded through the UART port, and then
    all replies from the serial port are forwarded to the client.
    The problem is that my project works only with the previous version. With the lastest version, the client can't load all elements of the web page (some images and javascript are not loaded correctly or are not loaded at all).
    Thankyou.
    Regards.
    p.s. (just downgraded the firmware and all it works ok again)
  • @sriboli
    will be good to know what is the reason?
  • @sriboli Just use for downloading the images URL which are properly written, like:
    https://software.pycom.io/downloads/SiPy-1.6.0.b1.tar.gz
    Change the version number accordingly and just give it a try,
2 out of 6
