    Send data requests http post. **SOLVED**
    http postpostrequest.pyurequest.pyubidots
    40 Posts 7 Posters 22.9k Views 7 Watching
      danielm
      Hi, try this urequests.py library, I modified it recently to make it work on LoPy with SSL. Unfortunately I did not comment my changes.
      https://drive.google.com/file/d/0B2mvAuXuxQ6BOW5Sa210Wm9SWkk
      S W 2 Replies Last reply Reply Quote 0
        scg94 @danielm
        @danielm Hi,
        Do you have any examples of using your library?
          danielm
          @scg94
          response = urequests.post("https://<url>", auth=("user", "pass"), headers={"Content-Type": "application/xxx+json", "Accept": "application/xxx+json"}, data='{"id": "%s"}' % myID)
          The response will have several properties like response.text, response.status_code, ....
          As you probably know you can list them via dir(response).
          It is not my library, I just modified it to make it work on my LoPy :)
            RadioTek
            Digging deeper after much time, I find that,
            addr = socket.getaddrinfo('www.google.com', 80)[0][-1]
            print(addr)
            always returns the the same ip address "200.249.64.63"
            From lookup on the web this address appears to be registered in Brazil.
            Does not matter what URL I use or what DNS address I set in the WIFI
            configuration. I have a connection and this is what is returned as the
            looked up IP
              jmarcelino @RadioTek
              @RadioTek
              Can you post the result of
              print(WLAN().ifconfig())
              Also any chance you can try it on a completely different WiFi network? or maybe check the DNS result from another computer on the same network?
                RadioTek @jmarcelino
                @jmarcelino Hi ,
                The result of print(wlan.ifconfig()) is ('10.1.1.37','255.255.255.0','10.1.1.1','8.8.4.4')
                I have set the WIFI to a static address. I have tried 10.1.1.1, 8.8.8.8, 8.8.4.4, and
                my providers DNS address, and all return the same result.
                addr = socket.getaddrinfo('http://www.checkthat.com.au', 80)[0][-1]
                print(addr) # returns ('200.249.64.63',80')
                Then entering the known IP address for "www.checkthat.com.au"
                addr = ('116.0.20.2',80)
                print(addr) # returns ('116.0.20.2',80)
                sa = socket.socket()
                sa.connect(addr)
                sa.send(b'GET / HTTP/1.1\r\nHost: checkthat.com.au\r\n\r\n')
                data = sa.recv(1000)
                sa.close()
                print(data) # returns the header information of the page
                I have tried this on my mobile network as well, with alternate IP address's
                wlan.ifconfig(config=('192.168.43.10', '255.255.255.0', '192.168.43.1', '192.168.43.1')) and it has behaved exactly the same way.
                Thanks from Alex
                  @RadioTek
                  Thank you for posting those. Just to be sure you're running the latest firmware on the LoPy?
                  os.uname()
                  Also when you connected to the mobile network was that using a mobile phone as the WiFi AP?
                    @jmarcelino said in Send data requests http post.:
                    os.uname()
                    (sysname='LoPy', nodename='LoPy', release='1.6.10.b1', version='v1.8.6-556-g989d5ac9 on 2017-03-30', machine='LoPy with ESP32', lorawan='1.0.0'
                    Yes connection to my mobile network was via WIFI using phone as AP
                    My Laptop "as using now" is worked through my office WIFI network back in to ADSL2. DNS functioning of all computers on the network seems perfect.
                    Regards Alex
                      scg94 @bucknall
                      @bucknall @RadioTek @jmarcelino
                      Hello everyone,
                      I keep trying to send the requests but I still can not, I want you to see this that came out...
                      I do not know how to send requests, I even tried connecting the LoPy to the Raspberry through Tx and Rx but I also did not find positive result.
                      I really need help! Thank you...
                        scg94 @bucknall
                        @bucknall Hello again,
                        I think I'm slowly solving things, what I did was change the domain name by IP, and now it works, but I have an error again with the library, this time it speaks of: "TypeError: object with buffer protocol required"...
                        Do you know what it is about?
                          livius @scg94
                          @scg94
                          cast data as bytes
                          urequest.request("POST", url, bytes([your_data])
                          or create it at start as buffered
                            scg94 @livius
                            @livius Hi,
                            I tried with this and look at the result ...
                            >>> datos={"temperatura_rpi": 500}
                            >>> data=bytes([datos])
                            TypeError: cant convert dict to int
                            >>> urequest.request("POST" ,"http://50.23.124.68/api/v1.6/devices/raspxxx?token=xxxxxxxxx",{"temperatura_rpi": bytes(500)})
                              File "/flash/lib/urequest.py", line 74, in request
                            Can you help me?? Thank u...
                              livius @scg94
                              @scg94 said in Send data requests http post.:
                              third parameter must be buffered
                              e.g. string or bytes
                              you can not send dictionary
                              do you try to send string?
                              if yes then concat it
                              '{"temperatura_rpi": 500}'
                              or if you have int variable
                              '{"temperatura_rpi": ' + str(int_var) + '}'
                                scg94 @livius
                                @livius
                                I already tried with both, look at the error...
                                >>> urequest.request("POST","http://50.23.124.68/api/v1.6/devices/rasxxxxx?token=xxxxxxxxxxx",'{"temperatura_rpi":' + str(500)+'}')
                                  File "/flash/lib/urequest.py", line 53, in request
                                OSError: 23
                                And in the line 53 in library urequest.py is:
                                s = usocket.socket()
                                Thanks for your help...
                                  livius @scg94
                                  @scg94
                                  which library do you finally use?
                                  I supposed that from first post @bucknall - but there is not line like you show
                                    scg94 @livius
                                    @livius I was confused on line 53, sorry, I already corrected it ...
                                    The library is https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
                                    And the error line 53 is:
                                      livius @scg94
                                      @scg94
                                      are you sure that you are connected to the router?
                                      And do you have OSError after first good try?
                                      If you try again after some error request it raise OSError
                                      for me library work - and i can send POST request
                                      did you tried
                                      urlpost.request("POST", "http://itstop.pl/testapi?kind=test&key=secret", '{"temperatura_rpi":' + str(500)+'}').text
                                      but library need some little correction to work with some errors responses
                                      but if you have good one it success always
                                        scg94 @livius
                                        @livius Okay, I want you to see this ...
                                        I was trying to send the data and I got a response:
                                        >>> urlpost.request("POST", "http://50.23.124.68/api/v1.6/devices/raspberry-pi?token=private")
                                        <Response object at 3ffe5870>
                                        >>> urlpost.request("POST", "http://50.23.124.68/api/v1.6/devices/raspberry-pi?token=private",'{"temperatura_rpi":'+str(500)+'}')
                                        <Response object at 3ffe6250>
                                        However he did not receive anything on the platform. From one moment to another I got an error:
                                        OSError: 23
                                        I have done well the connection with WLAN, because I could enter by FTP and because in the same console I have a response:
                                        >>> wlan.isconnected()
                                        True
                                        >>> wlan.ifconfig()
                                        ('192.168.1.103', '255.255.255.0', '192.168.1.254', 'Public_IP')
                                        I do not know what else to do...
                                          livius @scg94
                                          @scg94
                                          try first on e.g.
                                          https://requestb.in
                                          create bin and put url
                                          >>> urlpost.request("POST", "http://requestb.in/1kley5v1", '{"temperatura_rpi":' + str(500)+'}').text
                                          'ok'
                                          FORM/POST PARAMETERS
                                          None
                                          HEADERS
                                          Host: requestb.in
                                          X-Request-Id: b5ff3790-7279-4a4a-8237-b91ac4f26221
                                          Cf-Ipcountry: PL
                                          Cf-Ray: 34d8ea4990e56b01-WAW
                                          Via: 1.1 vegur
                                          Connection: close
                                          Total-Route-Time: 0
                                          Content-Length: 23
                                          Cf-Visitor: {"scheme":"http"}
                                          Cf-Connecting-Ip: XXXX
                                          Connect-Time: 10
                                          Accept-Encoding: gzip
                                          RAW BODY
                                          {"temperatura_rpi":500}
                                            scg94 @livius
                                            @livius
                                            Brother, I just saw the error more clearly...
                                            >>> urequest.request("POST","http://50.23.124.68/api/v1.6/devices/raspberry-pi?token=private",'{"temperatura_rpi":'+str(500)+'}').text
                                            '{"detail": "Unsupported media type \'\' in request."}'
                                            What is it????
                                            I did the same as you and this was the result:
                                            >>> urequest.request("POST", "http://requestb.in/1kley5v1", '{"temperatura_rpi":' + str(500)+'}').text
                                            'ok'
                                            >>> urequest.request("POST", "http://requestb.in/1kley5v1", '{"temperatura_rpi":500}').text
                                            'ok'
                                            • 2 / 2
