    SiPy Sigfox Antenna link quality
    sigfoxsipy
    15 Posts 4 Posters 4.7k Views 4 Watching
    • I Offline
      iotmaker
      let me first find out where the closest antenna is..
      i will report more today since i will be going to houston downtown today, sigfox coverage should be better there.
        @iotmaker I think your issues might be related with the config word. What Sigfox config word are you using on the Atmel dev kit? Perhaps setting this same config word on the SiPy will lead you to having the same results. The config word configures the channels that are used for the uplinks, which might explain the you only received 2 messages from the SiPy during your initial side by side comparison.
        On the SiPy:
        from network import Sigfox
        sfx = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ2)
        sfx.config()
        Can you find out how to get the config word from the Atmel module?
        I see that this is not documented yet so I'll make sure to fix that.
        • I Offline
          iotmaker
          i dont see any documentation about .config() on the pycom website
          • I Offline
            iotmaker
            I run the config and go this
            and according to atmel the default frequencies are the same
            what does the 511 mean on the sigfox device
            • I Offline
              iotmaker
              still having issues here in Houston. Could you check the signal integrity here in houston, or how many antennas they have.. i have not been able to get that information from them. but you guys have more leverage.
                jmarcelino @iotmaker
                @iotmaker
                Have you tried querying the Sigfox coverage API?
                A new API is available to provide coverage levels for any location in all public territories.
                This API api/coverages/global/predictions uses both GET and POST methods.
                For each input location (x,y), API results contain radio margin value in dB for the three best serving cells.
                Through this API, power efficient business applications can be developed such as coverage checker interface or object/solution deployment planning.
                Please check API documentation for full description.
                • I Offline
                  iotmaker @jmarcelino
                  @jmarcelino
                  thanks i just saw the documentation. i will try it out, because i did put the coordinates but i was not able to make it work.. do you know what format the latitud and longitude need to be... ?
                  • I Offline
                    iotmaker
                    well something might be wrong but the api shows as redundancy 0 an Global Coverage API (Single point) show 0
                    i dont think is updated for north america
                    • N Offline
                      nicolsc
                      Hi @iotmaker
                      I'm forwarding your feedback regarding the API to the team
                      It's most likely a bug along the lines of "devkit is registered on Sigfox France and cannot see Sigfox US network coverage" + says zero instead of a proper warning
                      Developer Relations @Sigfox
                        First of all apologies for the long delay with this. We have solved this problem with the latest firmware (1.6.13.b1). The issue is a bit complex and it's not because of a firmware bug, it's more because of an undocumented characteristic of the Sigfox network in RCZ2 and RCZ4:
                        There are 9 macro-channels with 2 micro-channels on each of of those 2 zones. However (and this is the undocumented part), only the first macro-channel is actually usable (for the time being). The Sigfox library itself behaves in a way that only the packets sent on the first macro-channel are transmitted properly (and the Sigfox library is a blackbox to anyone outside of Sigfox). The solution to this is to either call sigfox.reset() after every 2 transmissions and then wait 20s before transmitting again in order to comply with FCC regulations, or, as we have implemented it, handle this delay internally and only apply the amount of delay (if any) needed in order to comply. This latter approach is the one that we have preferred and therefore there's nothing to do at user code level besides knowing that more than 2 consecutive transmissions will have a delay in between. This is now documented in: https://docs.pycom.io/pycom_esp32/library/network.Sigfox.html
                        This characteristics of the Sigfox network are not tested during the Sigfox certification phase and also not very well documented, which is why it took us so long to fix it.
