PySense Expansion Board
Is there any more information available other than the spec sheet - there isn't much there regarding the pins that are used or the interfaces.
HI @mike632t,
I'm writing up the documentation for both the Pysense and the Pytrack as I'm typing this now! It will go up once the device arrives!
I can however confirm that all the sensors are connected on the I2C bus via pins P22 (SDA) and P21 (SCL).
Hope this helps!
