    Lopy GPS/DHT/RFiD
    dht gps mqtt
    11 Posts 5 Posters 4.3k Views 6 Watching
      johnmcdnz
      I have connected the DHT22 sensor and had working very well. My code and description is here. Pay attention to the sample size change I made and that I had to adjust the bit sampling. Using the print statements to debug and understanding the one wire protocol can help in fine tuning the data conversion. Hope this helps.
      https://github.com/johnmcdnz/LoPy-DHT-transmission
      • affoltepA Offline
        affoltep @gas
        @gas I wrote a minimalistic NMEA parser, based on micropyGPS, which parses just the GPGGA messages. This message delivers lon, lat, alt, hdop and UTC. Feel free to use it.
        #Minimalistic NMEA-0183 message parser, based on micropyGPS
        #Version 0.1 - January 2017
        #Autor: Peter Affolter
        import utime
        class NmeaParser(object):
            """NMEA Sentence Parser. Creates object that stores all relevant GPS data and statistics.
            Parses sentences using update(). """
            def __init__(self):
                """Setup GPS Object Status Flags, Internal Data Registers, etc"""
                # Data From Sentences
                # Time
                self.utc = (0)
                # Object Status Flags
                self.fix_time = 0
                self.valid_sentence = False
                # Position/Motion
                self.latitude = 0.0
                self.longitude = 0.0
                self.altitude = 0.0
                # GPS Info
                self.satellites_in_use = 0
                self.hdop = 0.0
                self.fix_stat = 0
                #raw data segments
                self.nmea_segments = []
            def update(self,  sentence):
                self.nmea_segments = str(sentence).split(',')
                #Parse GPGGA
                if (self.nmea_segments[0] == "b'$GPGGA"):
                    self.valid_sentence = True
                    try:
                        # UTC Timestamp
                         utc_string = self.nmea_segments[1]
                        # Skip timestamp if receiver doesn't have on yet
                         if utc_string:
                            hours = int(utc_string[0:2])
                            minutes = int(utc_string[2:4])
                            seconds = float(utc_string[4:])
                            hours = 0
                            minutes = 0
                            seconds = 0.0
                         # Number of Satellites in Use
                         satellites_in_use = int(self.nmea_segments[7])
                         # Horizontal Dilution of Precision
                         hdop = float(self.nmea_segments[8])
                         # Get Fix Status
                         fix_stat = int(self.nmea_segments[6])
                    except ValueError:
                        return False
                 # Process Location and Speed Data if Fix is GOOD
                    if fix_stat:
                        # Longitude / Latitude
                        try:
                            # Latitude
                            l_string = self.nmea_segments[2]
                            lat_degs = float(l_string[0:2])
                            lat_mins = float(l_string[2:])
                            # Longitude
                            l_string = self.nmea_segments[4]
                            lon_degs = float(l_string[0:3])
                            lon_mins = float(l_string[3:])
                        except ValueError:
                            return False
                        # Altitude / Height Above Geoid
                        try:
                            altitude = float(self.nmea_segments[9])
                            geoid_height = float(self.nmea_segments[11])
                        except ValueError:
                            return False
                        # Update Object Data
                        self.latitude = lat_degs + (lat_mins/60)
                        self.longitude = lon_degs + (lon_mins/60)
                        self.altitude = altitude
                        self.geoid_height = geoid_height
                    self.timestamp = (hours, minutes, seconds)
                    self.satellites_in_use = satellites_in_use
                    self.hdop = hdop
                    self.fix_stat = fix_stat
                    # If Fix is GOOD, update fix timestamp
                    if fix_stat:
                        self.fix_time = utime.time()
                    return True
        J 1 2 Replies Last reply Reply Quote 0
          Movsun @johnmcdnz
          @johnmcdnz
          Hello, I look into your github repository. But I count not find DHT22RinusW.py file.
          Where can I find the file? Thank you in advance.
            gas
            I never got the dht working I get always 28025 which is the zero values
            not sure id there are other action or I'm missing soemthing from teh library DHT itself
            >>> import DHT
            >>> dht_pin=Pin('P19', Pin.OPEN_DRAIN)
            >>> dht_pin(1)
            >>> temp, hum = DHT.DHT11(dht_pin)
            >>> temp_str = '{}.2{}'.format(temp//10,temp%10)
            >>> hum_str = '{}.2{}'.format(hum//10,hum%10)
            >>> print("sending Temp/Hum : %s/%s" % (temp_str,hum_str))
            sending Temp/Hum : 280.25/280.25
              johnmcdnz @Movsun
              @Movsun I changed the name to DHT22RinusW-call.py. Described in the readme.
                johnmcdnz @affoltep
                @affoltep The NmeaParser codes works really well (almost) :-)
                I've been using it this weekend, and discovered a minor flaw, and have fix for you.
                The code ignores the S/W hemispheres, so will only be correct for 1/4 of the planet.
                This change provides the correction
                if lat_hemi == 'S':
                self.latitude = -self.latitude
                if lon_hemi == 'W':
                self.longitude = -self.longitude
                Good job I can test in the Southern hemisphere and spot the problem!
                Once I have my project working I'll post on github.
                • affoltepA Offline
                  affoltep
                  @johnmcdnz Cool, thanks - in case it still doesn't work, feel free to come to this quarter, spring is starting here ;o)
                    gas
                    Cool the GPS part work well
                    Beside DHT11 that is reading all the time zero all the other are working well
                    PIR, RFId, GPS, Distnace , all this with Lora working to send the messages
                    Next is accelerometer MPU 92/65
                    • 1 Offline
                      100rabhh @affoltep
                      @affoltep Hi, How can i use it with my code?
                      Here is my simple receive code for Adafruit Ultimate Breakout GPS----
                      from machine import Pin
                      from machine import UART
                      #Interface definitons for GPS
                      gps_pps = Pin('P23', mode = Pin.IN)
                      gps_enable = Pin('P8', mode=Pin.OUT)
                      gps_enable(False)
                      #gps_uart = UART(2, 9600)
                      #gps_uart.init(9600, bits=8, parity=None, stop=1)
                      gps_uart = UART(2, baudrate=9600, bits=8, parity=None, stop=1, pins=('P10', 'P11'))
                      uart.write('abs')
                      gps_enable(True)
                      if gps_uart.any():
                      print(gps_uart.readline())
                      Here i am simply reading the strings from GPS Rx. Now how do i implement in your code to parse it? Please help...
                      • affoltepA Offline
                        affoltep
                        @100rabhh : Just put these lines to your code:
                        from nmeaParser import NmeaParser
                        #Create NMEA structure
                        nmea = NmeaParser()
                        #..then send your uart input to the library
                         if gps_uart.any():
                                nmea.update(gps_uart.readline())
                        #...then you can access your data by
                        print ('Latitude: ' + str(nmea.latitude))
                        print ('Longitude: ' + str(nmea.longitude))
                        print('Altitude:'+ str(nmea.altitude))
                        #...there are several other data available, just check the parser code for more info
