    [SOLVED] WiPy firmware to a standard WROOM-32?
    esp32
    38 Posts 7 Posters 17.2k Views 7 Watching
      BetterAuto Pybytes Beta
      Is that possible?
      I tried it and the Windows tool said the flash was successful but the board is resetting with some error (that I don't have handy at the moment, sorry, but I can get it on request) . The same FTDI and breadboard power supply were then used to flash a genuine WiPy and it was successful. Not sure if that's my WROOM or if it just can't be done.
      L robert-hhR 2 Replies Last reply Reply Quote 0
        livius @BetterAuto
        @BetterAuto
        What do you mean? You try to flash Wipy2 with WROOM rom?
        If yes then not it is not compatibile
          BetterAuto Pybytes Beta @livius
          Other way around. WiPy firmware to a WROOM-32. I thought they are both ESP32 under the hood?
            I had asked the same question on Twitter and was informed by Pycom that it is possible. So maybe my WROOM is bad.
            https://twitter.com/pycomIOT/status/863669914992877568
            FYI here's the error I'm getting on my WROOM-32. I'm going to buy another one and try again.
            configsip: 0, SPIWP:0x00
            mode:QIO, clock div:2
            load:0x3fff9010,len:8
            load:0xffffffff,len:-1
            ets Jun 8 2016 00:22:57
              jmarcelino @BetterAuto
              @BetterAuto
              how are you powering it?
                BetterAuto Pybytes Beta @jmarcelino
                @jmarcelino 3.3V breadboard supply. Keep in mind both chips are using the same supply and the Pycom board works.
                I just bought this one and should get it in two days so I can confirm it's really a damaged WROOM. Made by Espressif.
                https://smile.amazon.com/gp/product/B01N0SB08Q/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
                  @BetterAuto
                  OK but is the Pycom board also powered from 3.3V or is it 5V? How much current can the breadboard power source ? Do you have a link?
                  I'm not sure you can just assume it's sufficient just because Pycom works with it.
                    robert-hh @BetterAuto
                    @BetterAuto Alternative boards are "sparkfun esp32 thing", "Huzzah32" or "wemos lolin32". While the first one is a custom layout, the Wemos and Huzzah devices just use the wroom-32 as module, and as always, the Wemos device is unbeatable in price. But it looks as if the first batch was sold out immediately. I tried the sparkfun device, and waiting for the wemos device to be delivered. That may take a while with the slow boat from china.
                      @jmarcelino The Pycom board is powered from 3.3V. The breadboard power supply is an MB102 variant like this which claims to do 700mA. I'm using a bare WROOM-32 which uses even less than the Pycom board so if anything the Pycom should not work. I suspect a dead chip and will be able to confirm that tomorrow with the arrival of the Espressif-built dev board.
                      @robert-hh I started to buy a Sparkfun but then saw it does not have a WROOM-32 on it as you noted. Went direct to the manufacturer for their dev board. If that doesn't work then I don't know what to do :-D
                        @BetterAuto I see that the Wemos Lolin32 is available at aliexpress:
                        https://www.aliexpress.com/item/WEMOS-LOLIN32-V1-0-0-wifi-bluetooth-board-based-ESP-32-4MB-FLASH/32808551116.html?spm=2114.01010208.3.2.DXyahW&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_436_10136_10157_10137_10060_10138_10155_10062_10156_10154_10056_10055_10054_10059_100032_100033_100031_10099_10103_10102_10101_10096_10147_10052_10053_10050_10107_10142_10051_10084_10083_10080_10082_10081_10177_10110_10111_10112_10113_10114_10181_10180_10183_10182_10185_10184_10078_10079_10073_10186_10123,searchweb201603_2,ppcSwitch_5&btsid=f83eac71-efb8-450c-9b60-df678e0e9263&algo_expid=b986c6e2-8366-45d3-87e4-a86052471d35-0&algo_pvid=b986c6e2-8366-45d3-87e4-a86052471d35
                          Same error on the Espressif-built dev board. It flashes just fine but loops this on boot.
                            A comment in the IRC chat is I should try flashing in DIO mode. Since the flasher tool does not include the binary firmware is there somewhere I can just download it?
                              @BetterAuto You can fimnd them here.
                              https://software.pycom.io/downloads/WiPy-1.6.13.b1.tar.gz
                              For the other versions, just change the version number in the link.
                              See also https://forum.pycom.io/topic/517/downgrading-firmware-advanced-users
                                Thank you!
                                Found that I can do it with the standard firmware updater. I edited C:\Program Files (x86)\Pycom\Pycom Firmware Update\Upgrader\bin\updater.py, changed qio to dio.
                                  Several pins are unusable on the ESP-WROOM-32. GPIO16, 7, 32, 33, 25, 26, 27, and 13.
                                  Anyone know of a way to remap the pins? Probably have to recompile the firmware is my guess.
                                  J L 2 Replies Last reply Reply Quote 0
                                    @BetterAuto
                                    Change pins.csv https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/boards/WIPY/pins.csv perhaps?
                                      livius @BetterAuto
                                      @BetterAuto
                                      https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/boards/make-pins.py
                                      and @jmarcelino below answer
                                        crankshaft
                                        Hi;
                                        This thread is marked as solved, but there does not appear to be a solution ?
                                        I have flashed the firmware to an esp32-wroom, however I get the RTCWDT_RTC_RESET reboot.
                                        I have seen this before with the micropython port and the cause was related to the flash size, type and speed which is now included in the application (wipy) binary file.
                                        If there is a solution, would someone mind sharing it as the esp-32 port looks like it is constrained by lack of resources and is moving extremely slowly.
                                        Many Thanks
                                          BetterAuto Pybytes Beta @crankshaft
                                          @crankshaft I'm the one who marked my own thread solved because except for the pinouts still needing to be modified, I can boot successfully on an ESP-WROOM-32 from Espressif. Both the individual module and on the Espressif breakout board. I had to modify the flasher program as stated above but that's what I needed to do. I didn't get the error you're getting, so I marked it as solved.
                                          Sorry that I don't know the answer to your question, but perhaps someone else does. Perhaps try exactly the same modules I tried?
                                          https://smile.amazon.com/gp/product/B01MU8LL47/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
                                          https://smile.amazon.com/gp/product/B01N0SB08Q/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
                                          C 2 Replies Last reply Reply Quote 0
                                            crankshaft @BetterAuto
                                            @BetterAuto - thanks, can you elaborate on what you mean by modify the flasher ?
                                            Is it possible you canalso let me know what you modified in the pins to save me re-inventing the wheel !
