    Root causes of high deep sleep current [LoPy1, WiPy2 and SiPy], all the new modules **do not have deepsleep issues**
    deepsleep
    127 Posts 48 Posters 113.5k Views 57 Watching
      robert-hh @daniel
      @daniel Thank you very much. Will you also publish the code for the PIC controller?
        @robert-hh yes, it will be open source too.
        • F Offline
          frankb
          What are the dimensions of the 'deep sleep shield'? Will it still fit in a standard housing together with the v1.0 expansion board?
            @frankb it's going to be around 12mm tall. It's not going to fit inside the Pycase, but it most likely will fit inside the IP67 case. We will confirm this shortly.
            • K Offline
              Kean @daniel
              @daniel any timeline for release of the PIC source? I should have all the parts to build one of these on protoboard so I can continue with a project evaluation, except the code. Even a beta code in a hex file I can program via a PICkit3/ICD3.
                @Kean I don't have precise timelines yet, we are still busy with the PIC code and we are not ready to share it yet. I should be able to share some more info next week.
                • K Offline
                  Kean @daniel
                  @daniel Thanks!
                  • F Offline
                    Fred administrators
                    Dear All,
                    A quick update on this topic to confirm we are currently testing the Pilot Run samples in Eindhoven. All going well and we expect to have shields to ship circa 2 to 3 weeks e.g. 5/6 June. Photo enclosed of first unit.
                    Best wishes Fred
                    1 Reply Last reply Reply Quote 4
                    • I Offline
                      irvinvp
                      Hi @Fred, There are any updates about the shields? Thanks
                        danielm
                        When can we expect that the shields will be shipped to us?
                        • _ Offline
                          _peter
                          Firmware and board will be available in early June?
                            jomifo Pybytes Beta
                            @Fred Considering getting a pysense and pysense case. Will this setup work with my Lopy+deep sleep shield?
                              bucknall @jomifo
                              Hi @jomifo,
                              If you use a Pysense or Pytrack, you do not need to use the deep sleep shield as the Pysense/track already have this feature built in!
                              Developer Evangelist - Pycom
                              • _ Offline
                                _peter
                                Unfortunately, the solution to an alternative expansion board is not good for me. I'll have to mount it on an ad hoc card. Question: The OEM Reference Board (https://www.pycom.io/product/oem-reference-board/) + L01 OEM Module (https://www.pycom.io/product/l01/) can solve the problem ? I saw this: https://www.pycom.io/l01-oem-module-deep-sleep-test/. The OEM reference board has the same Lopy pinout?
                                  bucknall @_peter
                                  @_peter The only modules affected by the deep sleep issue is the Development versions of the WiPy 2.0, LoPy and SiPy. All of the OEM modules are not affected by this issue as they do not use the same power regulation as found on the affected modules. This includes the OEM Reference Board.
                                  _ 1 Reply Last reply Reply Quote 0
                                  • _ Offline
                                    _peter @bucknall
                                    @bucknall Thank you, I apologize but I do not find any documentation on the OEM Reference Board. Do you know where to find it?
                                      bucknall @_peter
                                      @_peter We currently have the OEM baseboard reference design available here - https://docs.pycom.io/pycom_esp32/pycom_esp32/datasheets.html#oem-baseboard-reference-design
                                        danielm
                                        @bucknall
                                        When are you planning to ship deep sleep shields to your customers?
                                        B _ 2 Replies Last reply Reply Quote 1
                                          @_peter the OEM reference board does have the same LoPy pin out, with the only difference that P12 is also used there to drive the RF switch (you can see that on the schematics).
                                            bucknall @danielm
                                            @danielm The Deep Sleep Shields should be arriving in the 3rd week of June. We will ship them as soon as we receive them. Thanks for your patience!
                                            I 2 Replies Last reply Reply Quote 2
                                            • 5
                                            • 6
                                            • 7
                                            • 2 / 7
