Firmware release 1.7.1.b1
@daniel Thanks for the prompt action on the NTP sync. looking forward to the new build.
could you clarify where the firmware versions are archived as the link on the web says page not found when following the link on quick start page.
@Strevens the updater tool is located here: https://www.pycom.io/downloads/
You can use the following link to the the latest release:
https://software.pycom.io/downloads/LoPy_868-1.7.1.b2.tar.gz
If you want a different version, just replace the version number/name on the link accordingly.
Daniel -
@daniel Thanks for the update and great you found the issue with ntp_sync.
P9 on the Lopy is labeld SD_DATA2 that is why I thought it might somehow be involved. I know it is not connected on the expansion board.
Sorry about P14 should read Pin 14, GPIO25 or P22.
I have a test going on and will report back if changeing the CS pin to that pin solved the issue with the freeze.
@daniel Thanks!
@daniel Analyzing the output of today I see tree different stack traces.
At least once I still got a freeze even with the CS pin switched to P22. I have the subjective feeling that freezing occurs less frequently with the CS pin on P22 rather than P9 but that could be just my imagination.
sometimes I see strange behavior, that when the python interpreter freezes I can advance it by updating in the ftp window. So it looks like an ftp request to the lopy does advance the python interpreter...
I do observe this by looking at the serial output which shows debug messages of my app.So the following is about issue 2 which indeed seem to be another 3 different issues as I get 3 different stack traces.
All the following errors occur near flushing data to the sd-cardGuru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x400875b9 PS : 0x00060033 A0 : 0x40088c47 A1 : 0x3ffbd5d0 A2 : 0x00050023 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x3ffc3dc8 A6 : 0x000ee81c A7 : 0x3ffc0df4 A8 : 0x00000005 A9 : 0x00000001 A10 : 0x3ffc3e34 A11 : 0x00000000 A12 : 0x3ffc3e34 A13 : 0x00000000 A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000016 EXCCAUSE: 0x0000001c EXCVADDR: 0x00000048 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Backtrace: 0x400875b9:0x3ffbd5d0 0x40088c47:0x3ffbd5f0 0x40088c01:0x3ffbd630 0x4013d1d7:0x000ee81c 0x400875b9: vTaskSwitchContext at /Users/danicampora/Code/Espressif/IDF/esp-idf-20170527/components/freertos/./tasks.c:4873 0x40088c47: _frxt_dispatch at ??:? 0x40088c01: _frxt_int_exit at ??:? 0x4013d1d7: lwip_accept_r at /Users/danicampora/Code/Espressif/IDF/esp-idf-20170527/components/lwip/api/sockets.c:3235Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x40087eb9 PS : 0x00060031 A0 : 0x80086722 A1 : 0x3ffc07b0 A2 : 0x00000001 A3 : 0x00000001 A4 : 0x000d6f4f A5 : 0x00000006 A6 : 0x000002aa A7 : 0x3ffc5fa0 A8 : 0x3ffc3fbc A9 : 0x3ffc0790 A10 : 0x3ffc3e40 A11 : 0x00000001 A12 : 0x00000004 A13 : 0x00000000 A14 : 0x000000aa A15 : 0x3ffc5f00 SAR : 0x00000016 EXCCAUSE: 0x0000001c EXCVADDR: 0x00000009 LBEG : 0x400f3178 LEND : 0x400f3180 LCOUNT : 0x00000000 Backtrace: 0x40087eb9:0x3ffc07b0 0x40086722:0x3ffc07d0 0x40088c1c:0x3ffc07f0 0x40081861:0x3ffc0800 0x40087eb9: xTaskIncrementTick at /Users/danicampora/Code/Espressif/IDF/esp-idf-20170527/components/freertos/./tasks.c:4873 0x40086722: xPortSysTickHandler at /Users/danicampora/Code/Espressif/IDF/esp-idf-20170527/components/freertos/./port.c:420 0x40088c1c: _frxt_timer_int at ??:? 0x40081861: _xt_lowint1 at xtensa_vectors.o:?Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x40148aec PS : 0x00060a30 A0 : 0x8013d9d4 A1 : 0x3ffc5ce0 A2 : 0x4013d894 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x3ffc5e88 A6 : 0x3ffc5d50 A7 : 0x00000d5e A8 : 0x3ffb483c A9 : 0x3fff8b50 A10 : 0x00000002 A11 : 0x00000004 A12 : 0x3ffc6a40 A13 : 0x3ffc5e60 A14 : 0x00000002 A15 : 0x3ffc5e40 SAR : 0x00000020 EXCCAUSE: 0x0000001c EXCVADDR: 0x0000000a LBEG : 0x400f7ae2 LEND : 0x400f7aeb LCOUNT : 0x00000000 0x40148aec: sys_untimeout at /Users/danicampora/Code/Espressif/IDF/esp-idf-20170527/components/lwip/core/timers.c:429 0x4013d9d4: sntp_stop at /Users/danicampora/Code/Espressif/IDF/esp-idf-20170527/components/lwip/apps/sntp/sntp.c:681 0x400dd879: mach_rtc_ntp_sync at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/mods/machrtc.c:55 0x400ef371: fun_builtin_var_call at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/objfun.c:124 0x400eb850: mp_call_function_n_kw at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/runtime.c:562 0x400eb8b8: mp_call_method_n_kw at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/runtime.c:591 0x400f7430: mp_execute_bytecode at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/vm.c:980 0x400ef303: fun_bc_call at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/objfun.c:276 0x400eb850: mp_call_function_n_kw at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/runtime.c:562 0x400eb8b8: mp_call_method_n_kw at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/runtime.c:591 0x400f7430: mp_execute_bytecode at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/vm.c:980 0x400ef303: fun_bc_call at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/objfun.c:276 0x400eb850: mp_call_function_n_kw at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/runtime.c:562 0x400eb87d: mp_call_function_0 at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../py/runtime.c:562 0x400d9166: parse_compile_execute at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../lib/utils/pyexec.c:534 0x400d9435: pyexec_file at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/../lib/utils/pyexec.c:505 0x400d841c: TASK_Micropython at /builds/this-wiederkehr/pycom-micropython-sigfox/esp32/mptask.c:245I'll now stop the ntp_sync, ftp and telnet server and see if the app is still going to crash or freeze.
I also noticed that core dump is not working anymore this leads to multiple exceptions raised in a row all related to the not working core dump. I think this used to work in earlier versions ...
@daniel Hi, also the repository on github is updated to 1.7.1.b2?
I've cloned the new pycom-micropython-sigfox repository and the new pycom-esp-idf repository, but the firmware generated make my wipy board in a fault state (RED led permanently on).I must use this procedure in order to create a wipy firmware with some frozen module!
@Innocenzo please try erasing your flash memory first as there were changes in the partitions table. Another option is to flash the firmware via the updater tool and then flashing with your own built firmware.
@daniel what is the command to erase the flash memory?
Anyway I've update the wipy to 1.7.1.b2 using the updater tool and then I try to update my own firmware but the result doesn't change. Red Led ON.
@Innocenzo have you rebuilt the bootloader? The command is erase instead of flash
@Innocenzo I had the same trouble (see my posts below): After using the updater tool once, you have to erase the flash BEFORE you use you load youe own-built firmware. You can do that with:
make eraseHOWEVER, after doing that, the board does not run boot.py or main.py any more. It considers itself in the safeboot mode. This is a software fault.
I'm interested if that happes to you too? If yes, you could still call boot.py and main.py from frozen/_boot.py, which is called always. -
@daniel said in Firmware release 1.7.1.b1:
yes.
- I have erased the old repository ;
- I have downloaded the new pycom-micropython-sigfox and pycom-esp-idf;
- git submodule update --init in all repository
- in pycom-micropython-sigfox/mpy-cross make all
- in pycom-micropython-sigfox/esp32:
- make BOARD=WIPY TARGET=boot;
- make BOARD=WIPY TARGET=app;
- make BOARD=WIPY flash.
@robert-hh Yes. The boot.py and the main.py present in /flash/ dir, do not start after flashing my own firmware.
@Innocenzo Before the step:
you have to do:
make BOARD=WIPY erase
In order to erase the flash memory on the device. Obviously, all content on the device will be lost! -
@robert-hh Yes. I do it and now I can flash my own firmware, but the file main.py and boot.py do not start "on boot".
Issue with the safeboot fixed here: https://github.com/pycom/pycom-micropython-sigfox/commit/f29075e4b0a1f713af1d2579465ffd35e360eb12
This post is deleted! -
@daniel Thanks. That looks like the right place. I cannot check it before this evening, by innocenzo may do so.
@daniel: Any ideas why I get those LoadProhibited exceptions? Any hint where I should start searching. I'm just lost on these ...
The first two seem very low level which makes me wonder .... the third might be related to the issue with ntp_sync. -
@this.wiederkehr we are investigating this now.
@robert-hh I check it. Now It works.
