Pytrack and Pysense firmware release 0.0.2
@jmarcelino said in Pytrack and Pysense firmware release 0.0.2:
@livius
dfu-util is also available for windows http://dfu-util.sourceforge.net/releases/dfu-util-0.9-win64.zip
Should be really similar to use (from command line)
The pysense is recognised by my Windows 10 as Serial USB device.
However, when I plug it in with the button pressed it says unknown device, no driver available.
Hence the update fails
PS C:\Users\.....\Pycom\dfu-util-0.9-win64> .\dfu-util.exe -D .\pysense_0.0.2.dfu dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to http://sourceforge.net/p/dfu-util/tickets/ Match vendor ID from file: 04d8 Match product ID from file: f011 Cannot open DFU device 04d8:f011 No DFU capable USB device available -
I have tried it before i asked ;-)
But it say unknown vendor for meI have tried also -s
dfu-util.exe -s COM4 -D pysense_0.0.2.dfuBut have not tried much. In the evening i will try more
@livius
Ha sorry I see Windows needs a DFU driver! No problem, libUSBk to the rescue.Try installing the driver package I generated:
[now old, see above]or install libusbK and make your own using the inf-wizard :-)
Once that's done
dfu-util -D pysense_0.0.2.dfuwill work (remember you only have about 7 seconds to run it after releasing the button, so install the driver first)DFU-UTIL has to be >= version 0.8
Tested with PyTrack not sure if the PySense uses the same ID, will try it up later. -
@jmarcelino thanks for the Windows instructions and the driver package!
PySense and PyTrack DFU use different USB IDs so I generated two driver packages for Windows using libusbK (I don't know how to make a single one...)
PySense: http://metavurt.net/software/drivers/PySense_DFU.zip
PyTrack: http://metavurt.net/software/drivers/PyTrack_DFU.zipAfter installing the driver you need download dfu-util for Windows from http://dfu-util.sourceforge.net/releases/dfu-util-0.8-binaries/win32-mingw32/ , I recommend the static compiled binary to avoid any library issues, you only need one executable: dfu-util-static.exe
Place the executable and the dfu firmware from Pycom together and get ready to run:
dfu-util-static.exe -D pysense_0.0.2.dfuor
dfu-util-static.exe -D pytrack_0.0.2.dfudepending on your firmware and boardThen connect the board with the button pressed down, release the button after one second and run the command above - remember you only have 7 seconds to do so!
The process will look like this
@joe2612
on macbook pro :
I advice to specify device since another device is in dfu modedfu-util -l dfu-util 0.7 Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2012 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org Found Runtime: [05ac:8289] devnum=0, cfg=1, intf=3, alt=0, name="UNDEFINED" Found Runtime: [04d8:f011] devnum=0, cfg=1, intf=0, alt=0, name="UNDEFINED"so i advice to specify device :
dfu-util --device 04d8:f011 -D pysense_0.0.2.dfu dfu-util 0.7 Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2012 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org Filter on vendor = 0x04d8 product = 0xf011 Opening DFU capable USB device... ID 04d8:f011 Run-time device DFU version 0100 Claiming USB DFU Runtime Interface... Determining device status: state = dfuIDLE, status = 0 WARNING: Runtime device already in DFU state ?!? Found Runtime: [04d8:f011] devnum=0, cfg=1, intf=0, alt=0, name="UNDEFINED" Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0100 Device returned transfer size 64 Dfu suffix version 100 bytes_per_hash=327 Copying data from PC to DFU device Starting download: [##################################################] finished! state(2) = dfuIDLE, status(0) = No error condition is present Done! ``` -
@jobbyworld
If you update to dfu-util version 0.8 or later it should pick up the correct ids from the file to filter on -
@jmarcelino thanks for the instructions!
@daniel where can we find examples and libraries?
regards -
@daniel
for me pysense + wipy2 hangs after few secondsupgrade was ok
dfu-util-static.exe -D pysense_0.0.2.dfu dfu-util 0.8 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2014 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org Match vendor ID from file: 04d8 Match product ID from file: f011 Opening DFU capable USB device... ID 04d8:f011 Run-time device DFU version 0100 Claiming USB DFU Runtime Interface... Determining device status: state = dfuIDLE, status = 0 WARNING: Runtime device already in DFU state ?!? Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0100 Device returned transfer size 64 Copying data from PC to DFU device Download [=========================] 100% 16384 bytes Download done. state(2) = dfuIDLE, status(0) = No error condition is present Done!wipy2 after fresh
os.mkfs('/flash')with current firmware
1.7.2.b1(official build)i put 6 times
os.uname()but only first 2 i get response and then it hang totally
all interfaces go down - wifi and uart
no info on COM/response on any command and no outputrst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT) ets Jun 8 2016 00:22:57 rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0x00 clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:QIO, clock div:2 load:0x3fff9010,len:12 ho 0 tail 12 room 4 load:0x3fff9020,len:388 load:0x40078000,len:11412 load:0x4009fc00,len:848 entry 0x4009fd9c MicroPython v1.8.6-650-g9bacbbd4 on 2017-06-09; WiPy with ESP32 Type "help()" for more information. >>> os.uname() (sysname='WiPy', nodename='WiPy', release='1.7.2.b1', version='v1.8.6-650-g9bacbbd4 on 2017-06-09', machine='WiPy with ESP32') >>> os.uname() (sysname='WiPy', nodename='WiPy', release='1.7.2.b1', version='v1.8.6-650-g9bacbbd4 on 2017-06-09', machine='WiPy with ESP32') >>>i moved this wipy to expansion board and it work without any problem
@livius after it hangs, does it revive by resetting the WiPy 2, or do you have to power cycle the pysense?
@daniel
it revive by pressing reset button on Wipy2
and back hangUPDATE
pytrack is ok only pysense is affected -
@livius
Does the Pysense after update appear as a USB serial device using the usbser driver?
Not sure how many checks the DFU stuff uses (would think it was reliable since it's a USB.org standard) but maybe try flashing it again?
I have tried before 5 times before written here
also with different cable on different USB port - no difference
and with really short cable (used for near everythin programing)
e.g. white cable below
yes
@livius
Sorry should have figured you'd have done that already :-)Not sure what it can be, but if pressing reset works I guess it's the WiPy crashing and not the Pysense shutting it off. Sounds like that was the question Daniel had.
for us we can assume this always ;-)
@livius @jmarcelino In my case I was obtaining the same error:
dfu-util(-static).exe -D pytrack_0.0.2.dfu
Cannot open DFU device 04d8:f014
No DFU capable USB device availableHowever, running the same with this option finally flashed the Pytrack!
dfu-util-static.exe --device 04d8:f014 -D pytrack_0.0.2.dfu
Hope that this can help to whom have the same problem!
Edit: I should add that before running that command I installed the driver packages which provided @jmarcelino and it didnt work after several attempts.
Hello, I followed every steps, both on windows or mac and I can't upgrade my pysense...
So, to be clear, I'll only speak about the mac part.
I installed dfu-util with brew, so I've the latest version (0.9).
If I try to upload the firmware without specifying the device ID, I get :
"dfu-util: No DFU capable USB device available"When I use dfu-util -l to see dfu capable devices plugged in my mac, I see two devices :
"Found Runtime: [05ac:8290] ver=0146, devnum=6, cfg=1, intf=5, path="20-8", alt=0, name="UNKNOWN", serial="UNKNOWN"
Found Runtime: [1209:2002] ver=0001, devnum=14, cfg=1, intf=0, path="20-5", alt=0, name="UNKNOWN", serial="UNKNOWN""The second one is pysense since it disappears when I unplug it.
So I tried to force the device with "dfu-util --device 1209:2002 -D pysense_0.0.2.dfu" and this is what I get :
"dfu-util 0.9Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/Opening DFU capable USB device...
ID 1209:2002
dfu-util: WARNING: Runtime device already in DFU state ?!?
dfuIDLE, continuing
dfu-util: Error: File ID 04d8:f011 does not match device (1209:2002 or 1209:2002)"It seems like my pysense doesn't have the good ideas... what should I do ?
@titi974 Wel, if you are in Windows and you press the push buttom while you plug in, and then you maintein your finger one second more, you could see when you run the first command Cannot open device (id) DFU or something like that. By the way, if you run it correctly, you can heard the sound when a device is pluged in, and 7 seconds laters the sound that something has pluged out(despite that maybe it's still pluged in)
If that doesnt work, you have to repeat the process sometimes. (plug in while pressing the buttom and running the first command)To me it didnt work the first attempts but I could obtain an output different than "dfu-util: No DFU capable USB device available"
@Pajarraco so, if you have read the entire thing, I've said that my problem is not that it's not recognised, it's that the IDs do not match...
And, on windows I get the exact same results as I've had on mac (see my first answer to understand the thing about device IDs that do not match). And yes I'm doing the procedure that you described.
I've been trying to make this work with my colleague since this morning so I think we've tried every possible way to launch it ahah and on different pcs and macs too.
