WDT not available
@Thosch42
look here - same topic
https://forum.pycom.io/topic/1098/lopy-wdt -
But mine IS a WiPy, so it should be implemented, isn't it?
Otherwise, please correct the documentation. It's so frustrating to try out things, try to find the failure, and then get told that it's simply not implemented.
@Thosch42
Please precise
Wipy1 or Wipi2
I assume that Wipi2 because you have software version1.6.12.b1And python modules are same for all boards
with some exception like Lora, Sigfox, LTE-M specific
Then link is valid for you -
Same error, and I have a WiPy 2.0. Livius I'm not clear from your answer if you're saying this is an issue also on the WiPy 2.0, yes?
@BetterAuto
Yes, if WDT is not avaiable (now) it is not avaiable on all boards, Wipy2, Lopy... -
Then I concur with the OP and request that the docs be updated.
Does this mean there is no watchdog running in the background either, just not at all functional?
FYI I plan to work around this issue by using one of the two alarms on a DS3231 RTC. It has an alarm with a resolution of one second; So to keep the system from staying locked up I'll constantly reset the alarm to 10 (or some number) seconds in the future. If the alarm ever fires it'll hit the WiPy reset.
I updated my WiPy 2.0 late last week and there still does not seem to be a WDT available.
My workaround was to put all the code in a 'Try/Except' and have a machine.reset() in the 'Except'.
@smssms
According to the log the WDT module only became available this past Friday in version 1.7.2.
