    OTAA does not join for US config. using last firmware
    otaausalorattn gatewayjoin
    4 Posts 2 Posters 1.3k Views 3 Watching
      blackansible
      I changed frequencies as recommended.
      Changed dr_max=4 instead of 5
      Changed socket.SO_DR, 3
      But funciton lora.has_joined(): always send false
      With abp works without problem. Do you see an error in my code. I read all the post about OTAA and nothing. Somebody from pycom engineering.
      Best regards,
      from network import LoRa
      import binascii
      import struct
      # create an OTA authentication params
      dev_eui = binascii.unhexlify('70 B3 D5 49 9E A9 24 C0'.replace(' ',''))
      app_eui = binascii.unhexlify('70 B3 D5 7E F0 00 5A 3F'.replace(' ',''))
      app_key = binascii.unhexlify('36 AB 76 25 FE 77 77 68 81 68 3B 49 53 00 FF D6'.replace(' ',''))
      # remove channels
      for channel in range(0, 72):
          lora.remove_channel(channel)
      # set the default channel to the same frequency (must be before sending the OTAA join request)
      lora.add_channel(0, frequency=903900000, dr_min=0, dr_max=4)
      # join a network using OTAA
      while not lora.has_joined():
          time.sleep(2.5)
          print('Not joined yet...')
      # create a LoRa socket
      # set the LoRaWAN data rate
      # make the socket blocking
      s.setblocking(False)
      time.sleep(5.0)
      for i in range (200):
          s.send(b'PKT #' + bytes([i]))
          time.sleep(4)
          rx = s.recv(256)
          if rx:
              print(rx)
          time.sleep(6)
        jmarcelino @blackansible
        @blackansible
        What are you using as your LoRaWAN gateway?
          blackansible @jmarcelino
          @jmarcelino Lopy gateway
            @blackansible
            Try this modification in your nanogateway.py code:
            https://forum.pycom.io/post/8290
