    Pytrack and Pysense Libraries Release 1.0.0
    pytrackpysenselibrary
    41 Posts 14 Posters 20.2k Views 15 Watching
    • papasmurphP Offline
      papasmurph @bucknall
      @bucknall I don't use Github for other than complaining about things, so there's certainly some learning curve. It would have been much easier for me to just "zip" the things I changed and send it somehow. I hope that works. Otherwise this might take a few days due to other responsibilities.
        bucknall @papasmurph
        Hi @papasmurph, feel free to send it to me (alex@pycom.io) and I'll look into implementing it for you :)
        Developer Evangelist - Pycom
          livius @amartinez
          @amartinez said in Pytrack and Pysense Libraries Release 1.0.0:
          <LIS2HH12 object at 3ffe7690>
          <L76GNSS object at 3ffe7680>
          What issue? please describe it more..
            gertjanvanhethof Pybytes Beta
            dfu-util is not working somehow on my linux client.
            dfu-util 0.8
            Copyright 2010-2014 Tormod Volden and Stefan Schmidt
            Please report bugs to dfu-util@lists.gnumonks.org
            Match product ID from file: f011
            dfu-util: No DFU capable USB device available
            What is going wrong?
            papasmurphP J 2 Replies Last reply Reply Quote 0
              papasmurph @gertjanvanhethof
              @gertjanvanhethof Did you do the "press button before plugging in USB" bit?
                jmarcelino @gertjanvanhethof
                @gertjanvanhethof
                What @papasmurph said and you probably need to be root
                  Camot
                  I am not sure what the Pysense does, but it is not what I would expect. I am running the following code multiple times within a minute or so. Maybe someone could explain what the results mean. I have a BME280 here and it reports 24.7 C and a humidity of 47.06%. Temperature jumps between 31 and 4800, humidity between 48 and 2800. Pressure.temp is pretty stable but 5C off and why does the pressure sensor not Report pressure?. Ambient returns two values for Lux, both of them impossible during daylight.
                  from pysense import Pysense
                  from SI7006A20 import SI7006A20
                  from LTR329ALS01 import LTR329ALS01
                  from MPL3115A2 import MPL3115A2
                  py = Pysense()
                  pressure = MPL3115A2(py)
                  tempHum = SI7006A20(py)
                  ambientLight = LTR329ALS01(py)
                  print (tempHum.humidity())
                  print (tempHum.temp('C'))
                  print (pressure.temp())
                  print (ambientLight.lux())
                  I got the following results
                  2693.687
                  31.87222
                  30.5
                  (21, 27)
                  48.81235
                  4961.352
                  30.5
                  (8, 9)
                  51.28427
                  266.1942
                  30.0
                  (7, 9)
                  2849.983
                  4873.621
                  28.5625
                  (7, 7)
                  papasmurphP B 2 Replies Last reply Reply Quote 0
                    papasmurph @jmarcelino
                    @jmarcelino That might even be needed on a Mac.
                      papasmurph @Camot
                      @Camot I've sent Alex new code that should work better (no guarantees though), but temperature is off due to heating from the board. I changed the code to measure pressure instead of altitude.
                        bucknall @Camot
                        @Camot I'm investigating this today and will likely merge @papasmurph's code when I get a chance to review the changes
                          Pajarraco
                          Maybe its a fool question, but when I try to download the new version 1.0.0 here: https://docs.pycom.io/pycom_esp32/pycom_esp32/toolsandfeatures.html#updating-pysense-and-pytrack-firmware
                          The download file has the name pytrack/pysense_0.0.2.dfu and not 1.0.0.dfu or something like that.
                          By the way, I just got working the accelerometer in both pytrack and pysenses, but the humidity, temperature, or glonass sensors don't work :(. May i wait some days more or is something that I have done wrong?
                          Edit: well, seems that i misunderstood the concept of the version of the DFU and the version of the Pytrack/Pysense libraries...
                          Futhermore, in the case of the Pysense, i forgot to print the values...Thanks to @Camot I could obtain some values but indeed, they are a bit unstable. About the Pytrack,I cannot get the coords. I modified the read function in order to print what it reads and well, it doesn't appear the word GNGLL so it is stuck in an infinite loop. Any ideas?
                            livius @Pajarraco
                            @Pajarraco
                            Where do you have pytrack inside building? On it work for me.
                              Pajarraco @livius
                              @livius I was running next to a window and it didnt work for me. Now I have just peeped the Pytrack outside with one hand and running the script and I could obtain the coords outside and inside. A little strange but well, it works :)
                                gertjanvanhethof Pybytes Beta @papasmurph
                                @papasmurph @jmarcelino Yes, I pressed the button and did a sudo call.
                                Atom pymakr plugin is working fine so I'am able to communicate with the board. What could be wrong?
                                  @gertjanvanhethof Pressed the button and then inserted USB? Just checking :).
                                    @papasmurph Yes, pressed button on the pysense board and then inserting the USB.
                                    No problem to ask. You never now.
                                    Could it be a problem because I'am using linux from in virtualbox.
                                    As said Atom is working fine so port is working. But probably it takes more time to setup the serial connection through USB in that case, so causing the problem?
                                    Make that sense?
                                    P J robert-hhR 3 Replies Last reply Reply Quote 0
                                      Pajarraco @gertjanvanhethof
                                      @gertjanvanhethof Are you releasing the buttom 1 s once you plug in the USB wire? Maybe you can try instead of dfu-util, dfu-util-stable, and try to add --device (the device id when it cannot be opened). I think another option to see if it detects the Dfu devices is to show a list with the option -l
                                        @gertjanvanhethof
                                        Maybe virtualbox doesn't connect the DFU device automatically to Linux? The board appears as two different USB devices depending on if it's in DFU mode or not, not sure what Virtualbox does with that
                                          robert-hh @gertjanvanhethof
                                          @gertjanvanhethof The USB-support in virtual machine is mediocre, to be polite. Simple devices like a memory stick work most of the time, complicated ones like smartphones, Pyboard, ... almost never. Better grab an old computer and install linux there. Even a 10 year old will give you good performance with an window manager like XFCE. Try for instance Xubuntu or Mint Xfce.
                                            gertjanvanhethof Pybytes Beta @robert-hh
                                            @robert-hh @jmarcelino @Pajarraco I switched to a system without virtualbox and problem solved. Thanks for your help!
                                            • 1 / 3
