    Pytrack and Pysense firmware release 0.0.2
    firmwarepytrackpysense
    27 Posts 9 Posters 12.6k Views 9 Watching
      jmarcelino @livius
      @livius
      Does the Pysense after update appear as a USB serial device using the usbser driver?
        livius @jmarcelino
        @jmarcelino said in Pytrack and Pysense firmware release 0.0.2:
        Not sure how many checks the DFU stuff uses (would think it was reliable since it's a USB.org standard) but maybe try flashing it again?
        I have tried before 5 times before written here
        also with different cable on different USB port - no difference
        and with really short cable (used for near everythin programing)
        e.g. white cable below
        0_1497120825859_upload-0244a2c0-5595-4f1e-b223-ccfb034a6530
        yes
        0_1497120892968_upload-a5383b83-7006-438e-b27a-1284065bc70b
          jmarcelino @livius
          @livius
          Sorry should have figured you'd have done that already :-)
          Not sure what it can be, but if pressing reset works I guess it's the WiPy crashing and not the Pysense shutting it off. Sounds like that was the question Daniel had.
            livius @jmarcelino
            for us we can assume this always ;-)
              Pajarraco @livius
              @livius @jmarcelino In my case I was obtaining the same error:
              dfu-util(-static).exe -D pytrack_0.0.2.dfu
              Cannot open DFU device 04d8:f014
              No DFU capable USB device available
              However, running the same with this option finally flashed the Pytrack!
              dfu-util-static.exe --device 04d8:f014 -D pytrack_0.0.2.dfu
              Hope that this can help to whom have the same problem!
              Edit: I should add that before running that command I installed the driver packages which provided @jmarcelino and it didnt work after several attempts.
                titi974
                Hello, I followed every steps, both on windows or mac and I can't upgrade my pysense...
                So, to be clear, I'll only speak about the mac part.
                I installed dfu-util with brew, so I've the latest version (0.9).
                If I try to upload the firmware without specifying the device ID, I get :
                "dfu-util: No DFU capable USB device available"
                When I use dfu-util -l to see dfu capable devices plugged in my mac, I see two devices :
                "Found Runtime: [05ac:8290] ver=0146, devnum=6, cfg=1, intf=5, path="20-8", alt=0, name="UNKNOWN", serial="UNKNOWN"
                Found Runtime: [1209:2002] ver=0001, devnum=14, cfg=1, intf=0, path="20-5", alt=0, name="UNKNOWN", serial="UNKNOWN""
                The second one is pysense since it disappears when I unplug it.
                So I tried to force the device with "dfu-util --device 1209:2002 -D pysense_0.0.2.dfu" and this is what I get :
                "dfu-util 0.9
                Copyright 2010-2016 Tormod Volden and Stefan Schmidt
                Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
                ID 1209:2002
                Determining device status: state = dfuIDLE, status = 0
                dfu-util: WARNING: Runtime device already in DFU state ?!?
                Claiming USB DFU Interface...
                Setting Alternate Setting #0 ...
                dfuIDLE, continuing
                DFU mode device DFU version 0100
                Device returned transfer size 64
                dfu-util: Error: File ID 04d8:f011 does not match device (1209:2002 or 1209:2002)"
                It seems like my pysense doesn't have the good ideas... what should I do ?
                  Pajarraco @titi974
                  @titi974 Wel, if you are in Windows and you press the push buttom while you plug in, and then you maintein your finger one second more, you could see when you run the first command Cannot open device (id) DFU or something like that. By the way, if you run it correctly, you can heard the sound when a device is pluged in, and 7 seconds laters the sound that something has pluged out(despite that maybe it's still pluged in)
                  If that doesnt work, you have to repeat the process sometimes. (plug in while pressing the buttom and running the first command)To me it didnt work the first attempts but I could obtain an output different than "dfu-util: No DFU capable USB device available"
                    titi974 @Pajarraco
                    @Pajarraco so, if you have read the entire thing, I've said that my problem is not that it's not recognised, it's that the IDs do not match...
                    And, on windows I get the exact same results as I've had on mac (see my first answer to understand the thing about device IDs that do not match). And yes I'm doing the procedure that you described.
                    I've been trying to make this work with my colleague since this morning so I think we've tried every possible way to launch it ahah and on different pcs and macs too.
                    P J 2 Replies Last reply Reply Quote 0
                      Pajarraco @titi974
                      @titi974 yes, I read that you have followed every steps... Well, maybe you can try to install the drivers which @jmarcelino has provided some posts bellow and retry the procedure
                        jmarcelino @titi974
                        @titi974
                        There is something very weird with your Pysense.
                        1209:2002 is the USB ID for the PIC16F1-USB-DFU-Bootloader project which sounds like what Pycom used here.
                        However the firmware image and indeed the boards I've seen all use 04d8:f011. I wonder if yours is a very early version or if something slipped through production. Can you post your serial number? (sticker underneath)
                        Maybe someone from Pycom can chime in on this, it's a head scratcher.
                          titi974 @jmarcelino
                          @jmarcelino s/n is "1713000002"
                          @Pajarraco sorry I should have said that I already used those drivers... but strangely, I had to manually select the drivers as the device appeared as "unknown device" and windows 10 didn't ask me to choose what to do automatically
                          • 2 / 2
