    pysense: lots of invalid temp/hum values
    pysensetemperaturehumidity
    30 Posts 11 Posters 10.9k Views 13 Watching
      bucknall @thomas
      @thomas Thanks! I'll let you know if I need any help! :)
      Developer Evangelist - Pycom
        albert_c
        I have the same thing here!
        I just received my pySense and use it out-of-the box. I upgraded my WiPy firmware to 1.7.4.1b and use the code samples from github (same as thomas above).
          albert_c
          The Problem persists after update the pySense firmware with pysense_0.0.2.dfu.
            bucknall @albert_c
            Hi @albert_c,
            I've made some changes to the micropython libraries which should increase stability. Could you try them again from https://github.com/pycom/pycom-libraries/tree/master/pysense and let me know if you're still having the same issues?
              albert_c
              I did an overnight test: no errors. Works perfectly!
              Thanks a lot for the quick fix.
                bucknall @albert_c
                @albert_c Fantastic! Excited to hear about what you're working on!
                  albert_c @bucknall
                  @bucknall Currently I'm evaluating my first WiPy's / PySenses around my house and garden. I am a Geologist in Germany and work in a small company focused on environmental measurements. We always check promising new products. The PyCom product family seems like a dream come true. Easy to use, cheap, if it now turns out to be also reliable we will certainly use Pycoms for our business. I wish you success!
                  Btw: a great thing to have would be a MicroPython Modbus library (in case you have spare time and dont know what to do with it :-) ).
                  B L 2 Replies Last reply Reply Quote 0
                    bucknall @albert_c
                    @albert_c That's great to hear! We're pleased you're enjoying using our devices! :)
                    We have a MicroPython Modbus library on the roadmap for internal development; many people in the community have been requesting this library!
                    M C 2 Replies Last reply Reply Quote 0
                      livius @albert_c
                      @albert_c
                      As start point - here is modbus python(not micro python) lib
                      https://github.com/riptideio/pymodbus/tree/master/pymodbus
                      Maybe this can help somehow
                        thomas @bucknall
                        Hi @bucknall,
                        I've just tested and it's also much better: no more errors so far. Only thing is a ~7° offset with the actual temperature. Any idea ?
                        Thanks anyway for the quick changes, great products, great team !
                        Thomas
                        B A 2 Replies Last reply Reply Quote 1
                          bucknall @thomas
                          Hi @thomas,
                          This is expected as the temp sensor on the pysense is picking up the temperature of lopy as well. We're working on using the LoPy's internal temp sensor to use as an offset for pysense to give you the real world external temperature (One of the issues with having such a small PCB + package!).
                          This is in the works and should be arriving soon!
                          T S 2 Replies Last reply Reply Quote 0
                            thomas @bucknall
                            Ok, thanks @bucknall for the feedback.
                              albert_c @livius
                              @livius
                              Thank you for the hint.
                              In fact we work with pymodbus, or I should say we use it. I'm not very deep in Modbus and new to Micropython, this is why I currently do not want to go into it deeper. But there are quite a few devices that talk modbus.
                                albert_c @thomas
                                @thomas, @bucknall
                                Thanks Thomas for checking thoroughly, thanks Bucknall for explaining the cause.
                                I managed reduce the offset to < 1 °C by just putting my WiPy on Break-away headers like this one.
                                The distance is makes clearly a difference. I did the test outdoor, without housing or enclosure, and compared to my simple outdoor thermometer. If you need exact values you certainly should elaborate more, but for my simple need +- 1° is good enough.
                                  mbriarg @bucknall
                                  @bucknall Hi Alex.Do you have any librery scheduled?
                                  Just to know if it's matter of weeks or months.
                                    bucknall @mbriarg
                                    Hi @mbriarg,
                                    What are you referring to? Are you asking about the internal temperature sensor and offset that I mentioned below?
                                      chumelnicu @bucknall
                                      @bucknall Hi . Any news about micropthyton mbus lib?
                                      Thank you!
                                        syncope @bucknall
                                        @bucknall said in pysense: lots of invalid temp/hum values:
                                        do you have any news about the offset?
                                          bucknall @chumelnicu
                                          @chumelnicu This is on the roadmap but unfortunately I can't give you an estimate of when it will arrive as we have a number of important firmware features/changes that are taking priority.
                                          Thanks for your patience!
                                            bucknall @syncope
                                            @syncope Unfortunately not yet, we're still to implement the internal temperature sensor from Espressif so are waiting to implement that code before releasing a library for the offset!
                                            Thanks for your patience,
                                            Alex
