    Problem with Sigfox Payload
    pytracksipysigfox
    21 Posts 3 Posters 8.0k Views 3 Watching
      Jiemde Pybytes Beta @livius
      @livius
      Yes the coordinates are right !
      When you take the 4 first bytes of the payload seeing in Sigfox for example " d5174d00" and you enter this part of payload in an "Lat=struct.unpack('i', b'\0xd5\0x17\0x4d\0x00') you will retreive the good Latitude.
      I think that teh code is sending the good coordinates, but I don't find how to configure the payload display in "device type" in the Sigfox backend !
      Regards
      jiemde
        livius @Jiemde
        @Jiemde
        now it is much cliear where you have the problem
        i do not know sigfox much but this format is valid?
        int1::4 int2::4
        i suppose you need
        int1:uint::4 int2:uint::4
          Jiemde Pybytes Beta @bucknall
          @bucknall
          The Sigfox backend display "d5174d0072b50800"
          The decoding payload "int1::4 int2::4", display 2 integer but not the good one!
          0_1499083800253_Capture d'écran 2017-07-03 14.06.17.png image url)
            livius @Jiemde
            @Jiemde
            sorry mistake
            int1:uint::32 int2:uint::32
              @livius
              Yes of course! :))
                @livius
                Had already tested this but not the good result.
                jiemde
                  livius @Jiemde
                  @Jiemde
                  what are results - maybe this hint something
                    @livius
                    Here is the printscreen
                      livius @Jiemde
                      @Jiemde
                      sadly i do not have sipy to test self but
                      looking at your values i see that you have variation on most significant bits
                      try then this:
                      int1:uint::32:little-endian int2:uint::32:little-endian
                      if this does not help then post output from corrds recived by pytrack + output packed
                      and what you got for this frames on sigfox
                        @livius
                        No change in the displaying data.
                        As I don't have my SiPy/Pytrack with me at my office, I will reply this evening to your other question.
                        best regards
                        jiemde
                          @livius
                          You will find the output you ask:
                          def sendtosigfox():
                          datatosend = struct.pack('ii', int(coords[0]*100000),  int(coords[1]*100000))
                          print('sigfox send: {}\n'.format(datatosend))
                          size1=struct.calcsize('i')
                          size2=struct.calcsize('ii')
                          print('calcsize: ', size1, size2)
                          sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
                          s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
                          s.setblocking(True)
                          s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
                          s.send(datatosend)
                          s.setblocking(False)
                          s.close()
                          acc = LIS2HH12(py)
                          roll = acc.roll()
                          print('X= ', roll)
                          pitch = acc.pitch()
                          print('Y= ', pitch)
                          yaw = acc.yaw()
                          print('Z= ', yaw)
                          time.sleep(1)
                          gps = L76GNSS(py)
                          coords = gps.coordinates()
                          print(coords)
                          sendtosigfox()
                          time.sleep(600)
                          The output in Atom/Pymakr:
                          The output in Sigfox backend
                          Regards
                          Jiemde
                          L 2 Replies Last reply Reply Quote 0
                            livius @Jiemde
                            @Jiemde
                            can you add before struct.pack
                            print(coords)
                            or
                            print(str(coords)) #if above not work cast first to string
                              livius @Jiemde
                              @Jiemde
                              is this really your position?
                              b'\xc8\x17M\x00k\xb5\x08\x00'
                              (5052360, 570731)
                              will be really helpfull to see
                              print(coords)
                              as mentioned below
                                @livius
                                Yes it 's my position !
                                The coords are displayed just before the "sigfox send: " on the output in Atom/pymakr picture.
                                (50.5236, 5.707314)
                                Jiemde
                                  livius @Jiemde
                                  @Jiemde
                                  Ahh i see :) I have missed it.
                                  and i see problem (previously i have thinked in opposite direction)
                                  try do this (one of this should do the trick)
                                  datatosend = struct.pack('>II', int(coords[0]*100000),  int(coords[1]*100000))
                                  or not and on sigfox backend (i do not know why little not do the job and suppose that only above line will work for you)
                                  int1:uint::32:big-endian int2:uint::32:big-endian
                                    @livius
                                    Hi livius, That's work!, now I need to understand how work the "format" of the "pack" function and specialy "little and big-endian.
                                    Best regards
                                    Jiemde
