BLE and Wifi interference?
Hi to everyone!
I noticeed a possible issue using, at the same time, BLE and wifi.
Once created a bluetooth object, if services are exposed, i can't make a socket connection, and also the ftp server has communication problem.
Instead if a bluetooth object is created without services no issue is arised.
In the following code i try to create 3 bluetooth services and after that, i try to make a mqtt broker connection.wlan = WLAN() wlan.init(mode = WLAN.STA, antenna = WLAN.EXT_ANT, channel = 11) bt = Bluetooth() id = str(ubinascii.hexlify(machine.unique_id(), ':'), 'utf-8') bt.set_advertisement(name = 'X-DOM - '+id[9:17].upper()) bt.advertise(True) bt.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=conn_cb) srv_reset = bt.service(uuid=0x77777777, isprimary=True, nbr_chars=2, start=True) reset = srv_reset.characteristic(uuid = 0x11111111, properties = Bluetooth.PROP_WRITE, value = 0) password = srv_reset.characteristic(uuid = 0x22222222, properties = Bluetooth.PROP_WRITE, value = 0) password.callback(trigger=Bluetooth.CHAR_WRITE_EVENT,handler= func_password) reset.callback(trigger=Bluetooth.CHAR_WRITE_EVENT,handler= func_reset) srv_refresh = bt.service(uuid=0x88888888, isprimary=True, nbr_chars=1, start=True) refresh = srv_refresh.characteristic(uuid = 0x33333333, properties = Bluetooth.PROP_WRITE, value = 0) refresh.callback(trigger=Bluetooth.CHAR_WRITE_EVENT,handler= func_refresh) srv_config = bt.service(uuid=0x99999999, isprimary=True, nbr_chars=4, start=True) ch_nets = srv_config.characteristic(uuid=0x44444444, properties = Bluetooth.PROP_READ, value = 0) ch_nets.callback(trigger=Bluetooth.CHAR_READ_EVENT, handler=func_scanning) net_config = srv_config.characteristic(uuid=0x55555555, properties = Bluetooth.PROP_WRITE, value = 0) net_config.callback(trigger=Bluetooth.CHAR_WRITE_EVENT, handler=func_net_cf) mqtt_config = srv_config.characteristic(uuid=0x66666666, properties = Bluetooth.PROP_WRITE, value = 0) mqtt_config.callback(trigger=Bluetooth.CHAR_WRITE_EVENT, handler=func_mqtt_cf) notify_config = srv_config.characteristic(uuid=0x12345678, properties = Bluetooth.PROP_WRITE, value = 0) notify_config.callback(trigger=Bluetooth.CHAR_WRITE_EVENT, handler=func_notify_cf) client = MQTTClient(CLIENT_ID,server="projectxdom.co.uk",user=uid,password=pwd_mqtt) client.set_callback(sub_cb) if not client.connect(clean_session = True): client.subscribe('/rgbled/color') client.subscribe('PippoBaudo')In the client.connect() the wipy return the error code
OSError: -76Instead the following code works fine
wlan = WLAN() wlan.init(mode = WLAN.STA, antenna = WLAN.EXT_ANT, channel = 11) bt = Bluetooth() id = str(ubinascii.hexlify(machine.unique_id(), ':'), 'utf-8') bt.set_advertisement(name = 'X-DOM - '+id[9:17].upper()) bt.advertise(True) bt.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=conn_cb) client = MQTTClient(CLIENT_ID,server="projectxdom.co.uk",user=uid,password=pwd_mqtt) client.set_callback(sub_cb) if not client.connect(clean_session = True): client.subscribe('/rgbled/color') client.subscribe('PippoBaudo')Is it a bug, or my mistake?
Tnx -
@Paco88 I think that the INTERNAL ANTENNA and the EXTERNAL ANTENNA are too close and this can cause an interference.
This may be a real problem...
@Paco88 Someone like @robert-hh, @jmarcelino or @bucknall maybe know some other motivation
Hi @Paco88
WiFi and BLE are on the same antenna and ESP32 controls access via coexistence (hardware or software).
I see that you are explicitly enabling external antenna. What happens if you try with the onboard antenna ?Claudio
@duffo64
Hi!
No difference with internal or external antenna. -
Even with an External Antenna the BLE seems to have quite some problems. Sometimes it doesnt find anyhting at all.
