    Pytrack and Pysense Libraries Release 1.0.0
    pytrackpysenselibrary
    41 Posts 14 Posters 20.8k Views 15 Watching
      robert-hh @gertjanvanhethof
      @gertjanvanhethof The USB-support in virtual machine is mediocre, to be polite. Simple devices like a memory stick work most of the time, complicated ones like smartphones, Pyboard, ... almost never. Better grab an old computer and install linux there. Even a 10 year old will give you good performance with an window manager like XFCE. Try for instance Xubuntu or Mint Xfce.
        gertjanvanhethof Pybytes Beta @robert-hh
        @robert-hh @jmarcelino @Pajarraco I switched to a system without virtualbox and problem solved. Thanks for your help!
          johncaipa
          Anyone know how to get the battery voltage in the code from these boards?
            Camot @johncaipa
            @johncaipa
            from pysense import Pysense
            py = Pysense()
            volt_float = py.read_battery_voltage()
              mqlopes @Camot
              @Camot Hello. I have both a Pysense and a Pytrack. I'm trying to read the battery voltage using "py.read_battery_voltage()", but I keep receiving the same values when the boards are connected to USB (with the batteries attached). For Pysense: 0.1203943 and for Pytrack 0.06017921. Thanks for your help.
              C papasmurphP 2 Replies Last reply Reply Quote 0
                Camot @mqlopes
                @mqlopes
                I am not sure I understand your point. Why do you expect a changing battery voltage when you board is USB powered? Unplug USB and you see the voltage decreasing slowly.
                • papasmurphP Offline
                  papasmurph @mqlopes
                  @mqlopes When USB is connected the voltage is stable 3.3 Volts, while the battery is being charged. What you are asking about would require hooking into the battery itself, which is not the case.
                  M J 2 Replies Last reply Reply Quote 0
                    mqlopes @Camot
                    @Camot Tks for your advice.
                      mqlopes @papasmurph
                      @papasmurph Ok, I see. Thanks for your support.
                        Jiemde Pybytes Beta @papasmurph
                        Hi @papasmurph
                        What I understand is that it's the 3.3 volts who is tested with this function not the voltage of the battery ? Am I right ?
                        Jiemde
                          papasmurph @Jiemde
                          @Jiemde As far as I understand it's the driving voltage, so if connected to USB it's measuring the stable 3.3 Volt from the power supply, that then also charges the battery.
                          • IplookyI Offline
                            Iplooky
                            What am I missing ?
                              it should be:
                              Note the capital P in the class name.
                              IplookyI 1 Reply Last reply Reply Quote 0
                              • IplookyI Offline
                                Iplooky @daniel
                                @daniel It has the same result in all the 4 combinations : pysense Pysense, pp, Pp and PP (it doesn't find the module pysense, if i delete it then it will not recognise the module LIS2HH12 and so on..). It is enough just to put the libraries in the same folder and then declare them in the code ?
                                  How does your file system on the module look like? By default libraries are only searched inside the lib folder. Are you putting it there or somewhere else?
                                  If you want to add other folder to the system path, you can do for example:
                                  import sys
                                  sys.path.append('/flash/my_folder')
                                  • IplookyI Offline
                                    Iplooky @daniel
                                    @daniel you where right, I had all the libraries outside the lib folder and that's why it did not work.
                                    still:
                                    import sys
                                    helped me a lot! Thank you!
                                    • 2 / 3
