    IMPORTANT: New Firmware Update Tool Released (version 1.1.2.b1)
    firmware
    24 Posts 10 Posters 10.2k Views 9 Watching
      rdixey
      I deleted all previous versions of the Update Tool from my Ubuntu system. Then downloaded the New Firmware Update tool v1.1.2.b1 from pycom.io Pycom upgrader Linux link.
      When I run it as I have dozens of times in the past I get the messages:
      • Connecting to the device to get it's information, please wait.
      • Something failed trying to connect to the device.
      Looks like the .update bash script throws this message when updater.py can't establish the serial connection
      I'm using /dev/ttyUSB0 through which I routinely connect to the Lopy with Screen at 115200 baud.
      I don't understand why the new update tool can't establish the connection as it had so easily with the prior update tool?
        robert-hh @rdixey
        @rdixey Same here. It stops after changing the baud rate to 921600. Updating a self-built firmware with esptool.py initiated with "make flash" works.
        OS Debian 8
          @rdixey I just tried the Unix it on Mac OS. Works as normal. I'll try this on Ubuntu tomorrow, and see if there's an specific issue there.
          • FridaF Offline
            Frida
            Works ok here on Linux Mint 18.1 64 bit
            os.uname()
            (sysname='WiPy', nodename='WiPy', release='1.7.7.b1', version='v1.8.6-715-g5fa16c2c on 2017-07-20', machine='WiPy with ESP32')
              rdixey @daniel
              @daniel Did you find any specific issue with Update Tool 1.1.2.b1 on Ubuntu?
                b3da @robert-hh
                @robert-hh exactly the same for me on Ubuntu: Changing baud rate to 921600 - Failure!
                • E Offline
                  Emmanuel Goudot
                  Same issue on ubuntu: cannot update LoPy/SiPy anymore...
                    Hello everyone,
                    Thanks for reporting this issue with the linux updater. We haves just fixed it and released version 1.1.2.b2 for unix. It's available here:
                    https://software.pycom.io/findupgrade?product=pycom-firmware-updater&type=all&platform=unix&redirect=true
                    Apologies for the inconveniences...
                    robert-hhR R 2 Replies Last reply Reply Quote 0
                      robert-hh @daniel
                      @daniel tried it, got a little bit further, up to the message:
                      " Something failed trying to contact the server."
                        @robert-hh can you please try again? The issue reported before was caused because of the slow baudrate (38400) used before for the initial connection with the board. Increasing it to 57600 fixed it. We just trying again on our Ubuntu machines where it was failing before and now it's all fine.
                        @Emmanuel-Goudot @b3da @rdixey could you please try and let me know? Thanks!
                        robert-hhR E 2 Replies Last reply Reply Quote 0
                          rdixey @daniel
                          @daniel 1.1.2.b2 worked on my Ubuntu 16.04 Thanks....
                            robert-hh @daniel
                            @daniel Now it works.
                            • E Offline
                              Emmanuel Goudot @daniel
                              @daniel It works, report 1.7.7.b1
                              os.uname()
                              (sysname='LoPy', nodename='LoPy', release='1.7.7.b1', version='v1.8.6-715-g5fa16c2c on 2017-07-20', machine='LoPy with ESP32', lorawan='1.0.0')
                              • bmarkusB Offline
                                bmarkus
                                LoPy update fails on WIN10 (64-bit). Connecting to the device with a serial terminal using 115200 bit/s I see
                                rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
                                waiting for download
                                but the PyCom updater fails to connect.
                                Updater is just downloaded as 1.1.2.b1
                                Version number is not displayed in the updater and clicking on '?' in the upper right corner nothing happens. It looks like there is no way to get installer version.
                                • bmarkusB Offline
                                  bmarkus
                                  Update was succesful on another WIN10 machine.
                                    colinza
                                    Why doesn't the update tool support OTA updates, or at least make the firmware binaries available directly?
