    Does deepsleep work at all
    deepsleep
    83 Posts 20 Posters 52.5k Views 23 Watching
      adam_IoTK @bucknall
      @bucknall Found it in https://forum.pycom.io/topic/929/deepsleep-stops-execution-of-main
      Sorry for the confusion, and thanks for your patience.
      adam
        @adam_IoTK waking from deepsleep starts execution from the same point as when you power up the board. There are a few patches coming soon that will allow to:
        1. Detect the reset reason, so you can know if you come from a power-on reset or deepsleep, then act accordingly.
        2. Do not start-up WiFi by default on boot. This will speed up boot times dramatically and reduce power consumption.
        3. Keep the RTC running during deepsleep.
        • RobTuDelftR Offline
          RobTuDelft
          Is it currently possible to wake from deepsleep, e.g. on sensor reading?
          Hackster | About me
            @RobTuDelft it is, but not yet. The ULP coprocessor from the ESP32 has to be used for that, but we haven't enabled support for it yet.
              jmarcelino @RobTuDelft
              @RobTuDelft
              Some sensors have an "alarm" pin when values go below/over some threshold, with the deep sleep shield you could (in theory, I don't have it yet) connect those to either P17 or P18 and enable_wake_on_fall (or rise).
                chumelnicu @daniel
                @daniel Do deepsleep working ? I try to put my lopy after s.send(data) in lorawan config and after wake up 2 time from deepsleep the program is stop execution.
                Any solutions for that ?
                BTW ....I did try deepsleep from machine and alsi try with deepsleep board and DeepSleep from deepsleep.py library, same result
                  @chumelnicu deep sleep works... Can you be more specific around the way your program stops execution? A code example and the REPL output would help us understand your issue. Thanks.
                  C C 2 Replies Last reply Reply Quote 0
                    chumelnicu @daniel
                    @daniel Thx
                    Was about reading HR-04 Ultrasonic Sensor and send data over lorawan.
                    First i did connect Echo to Pin11 and Trigger to Pin12
                    I just move it to Pin21 and Pin22 and seems all is ok
                    Solved ! Thx Daniel
                      Camot @daniel
                      @daniel said in Does deepsleep work at all:
                      Sure? Libs and Lopy updated today. Lopy attached to the DeepSleep board. Not even the first line of the example from Github or documentation works without an error
                      >>> os.chdir('lib')
                      >>> os.listdir()
                      ['LIS2HH12.py', 'LTR329ALS01.py', 'MPL3115A2.py', 'pysense.py', 'SI7006A20.py', 'dth.py', 'bme280.py', 'deepsleep.py']
                      >>> from deepsleep import DeepSleep
                      Traceback (most recent call last):
                        File "<stdin>", line 1, in <module>
                      ImportError: cannot import name DeepSleep
                      >>> os.uname()
                      (sysname='LoPy', nodename='LoPy', release='1.7.8.b1', version='v1.8.6-724-g2b9ed601 on 2017-07-28', machine='LoPy with E
                      SP32', lorawan='1.0.0')
                        jmarcelino @Camot
                        @Camot said in Does deepsleep work at all:
                        Do you happen to have another file named deepsleep.py in your LoPy root folder by any chance?
                          Camot @jmarcelino
                          @jmarcelino said in Does deepsleep work at all:
                          oops, thank you! How embarrassing :/ . It was still there from my pysense experiments. Anyway, still not working
                            File "<stdin>", line 7, in <module>
                            File "/flash/lib/deepsleep.py", line 145, in get_wake_status
                            File "/flash/lib/deepsleep.py", line 76, in peek
                          IndexError: bytes index out of range
                          MicroPython v1.8.6-724-g2b9ed601 on 2017-07-28; LoPy with ESP32
                          Type "help()" for more information.
                            jmarcelino @Camot
                            @Camot
                            Setting aside the get_wake_status() example for now does a straight up
                            ds = DeepSleep()
                            ds.go_to_sleep(30)
                            put the board into deep sleep for 30 seconds?
                              @Camot do you have anything connected to P10? That's the pin used between the LoPy and the deepsleep shield for communication...
                                Camot @jmarcelino
                                @Camot
                                ds = DeepSleep()
                                ds.go_to_sleep(30)
                                don't think so, the board become unresponsive for 50 seconds but heartbeat continues and then it reports
                                >>> ds.go_to_sleep(30)
                                  File "/flash/lib/deepsleep.py", line 156, in go_to_sleep
                                  File "/flash/lib/deepsleep.py", line 105, in calibrate
                                IndexError: list index out of range
                                Repeated it 3 times with ds.go_to_sleep(30), alway 50 seconds unresponsive :/
                                @daniel
                                no, only the Lopy, the deepsleep shield, the antenna and power with a 3.3V Step-Up/Down Regulator on the Lopy 3.3V pin.
                                  jmarcelino @Camot
                                  That's the problem then, the deep sleep shield only controls - and is powered by - the Vin (labelled 5V) pin not the 3.3V.
                                  Try applying your 3.3V to the Vin pin instead, the LoPy regulator should enter bypass mode and hopefully the PIC10 and extra circuitry shouldn't be affected too much.
                                    Camot @jmarcelino
                                    Oh, I have not read it anywhere yet. Thank you @jmarcelino
                                    It works with 3.3V on the 5V pin at the DS shield. The power consumption goes down to 0.4mA during deep sleep....but more than I have expected. Besides the high deep sleep current, I found something else that's odd. If I put 5v to the 5v pin, the Lopy does nothing. If I put in 3.3v at the same 5v pin, it is starting. And yes, I am using the 5v pin ....first pin right to the heartbeat.
                                      jmarcelino @Camot
                                      Can you explain it a bit better please? Where are you supplying 5V from? Is this with the LoPy inserted into the Deep Sleep shield?
                                        Camot @jmarcelino
                                          @Camot the deepsleep shield has a battery protection mechanism (LiPo batteries get damaged if you discharge them completely), therefore when the input voltage falls close to 3.3V, the deepsleep shield will disconnect power to protect the battery. This threshold voltage can be increased with the set_min_voltage_limit() and enable_auto_poweroff() methods from the deepsleep library. In any case trying to power it with a voltage that is too low won't damage anything.
                                          What do you mean with so many hardware bugs? Besides the deepsleep problem that we already acknowledged, and we did our best to compensate with the deepsleep shield, what other hardware issues have you found?
                                            Thosch42
                                            Hi all!
                                            I recognized a similar behaviour with my Lopy. The DS-shields arrived yesterdayand I start to work with them. My hardware setup is pretty simple: Expansionboard V2.1A, DS shield V1.0, LoPy, 2000mAh LiPo, attached to the Expansionboard and powered by USB.
                                            I start with upgrading a OTAA LoRaWAN node. It work for a while, then it stopped working with:
                                            Joined yet!!!
                                            File "main.py", line 75, in <module>
                                            File "deepsleep.py", line 156, in go_to_sleep
                                            File "deepsleep.py", line 105, in calibrate
                                            Thomas
                                            • 5
                                            • 1 / 5
