Connect LoPy LoRa with Semtech Board
  • Hello,
    I am trying to connect Semtech LoRa development board with LoPy. I am sending 9 bytes of payload from Semtech board each 2 seconds. Format of the packet that is sent from Semtech board is: first 4 bytes are unsigned int (used for packet ID), other 5 bytes are dummy.
    I am able to receive packets on LoPy, but with following problems:
    • Not able to receive each packet, but every second (packet loss is 50%)
    • Able to extract packet ID properly only if reading first two bytes: _LORA_PKG_FORMAT = "H" (unsigned short int, 2 bytes). If I put _LORA_PKG_FORMAT = "I" (unsigned int, 4 bytes), it is decoded as garbage.
    Code that I used for reception is given below:
    import struct
    from network import LoRa
    pycom.heartbeat(False)
    pycom.rgbled(0xffffff)
    lora = LoRa(mode=LoRa.LORA,
    frequency=868000000,
    power_mode=LoRa.ALWAYS_ON,
    tx_power=14,
    bandwidth=LoRa.BW_125KHZ,
    sf=10,
    preamble=8,
    coding_rate=LoRa.CODING_4_6,
    tx_iq=False,
    rx_iq=False,
    public=False)
    s.setblocking(False)
    rxBuf = s.recv(9)
    if (len(rxBuf) > 0)
    rxData = struct.unpack(_LORA_PKG_FORMAT, rxBuf)
    print(rxData)
    Does anyone have an idea what should be done to receive each packet and to properly decode all four bytes?
    Cheers, Nikola
