    Root causes of high deep sleep current [LoPy1, WiPy2 and SiPy], all the new modules **do not have deepsleep issues**
    deepsleep
    127 Posts 48 Posters 112.5k Views 57 Watching
      daniel
      @robert-hh that's true. The redesigned expansion board (v3) will also include circuitry to shutoff that divider circuitry during deep sleep mode.
      • RobTuDelftR Offline
        RobTuDelft
        Glad the problem has been identified and that the Pycom team is dedicated to solving the issue.
        A 20 mA deepsleep current was just under the limit to power our sensor stations for around a week on battery, but still very high of course. We are now looking for a solar panel solution in the mean while.
        Without data you're just another person with an opinion.
        Hackster | About me
        • PiAirP Offline
          PiAir
          Quick question: for Kickstarter backers, with "order number" you mean "backer number" ?
          F 1 Reply Last reply Reply Quote 0
          • F Offline
            Fred administrators @PiAir
            @PiAir Absolutely! Well noted. Thanks Fred
            • E Offline
              exquisitus
              how would that work for customers who bought from a distriutor, in my case elmwood in toronto, canada? please advise. thanx.
              • F Offline
                Fred administrators @exquisitus
                @exquisitus Hi,
                We want to keep it simple so just register your details on the Link I quoted and we will send out the deep sleep shield. If you can simply include the invoice/order number relating to your purchase from Elmwood then we can take care of the rest. Thanks Fred
                  jasonriedy
                  For those of us who were hoping to just plug in a LiPo, what is needed to power via the 3V3 pin?
                  And the total deep sleep draw of the current expansion boards is a tad over 2.5 mA when powered via that pin?
                  (As a software person looking for a quick & easy gizmo for relaying sensor data, I really was hoping just to plug a big-ish LiPo into the expansion board.)
                    ssmith @Fred
                    @Fred
                    I'm in the process of designing an adapter board to use a LoPy module in a sensor application. Can you make the details of the shield board available to possibly be implemented in my adapter board?
                      constantinos @Fred
                      @Fred Very Nice! Can you provide us also a schematic of the solution in order to fix our custom boards?
                      Thanks in advance
                      Constantinos
                        daniel
                        @jasonriedy what you need to do is to plugin the LiPo and attach the deep sleep shield that we just announced. The LiPo battery on the expansion board powers the module via the VIN (3.6-5.5V) pin, not via the 3V3 pin. Deep sleep with the shield will work on a transparent way when you issue the machine.deep_sleep() instruction.
                          daniel
                          @ssmith @constantinos we will make the schematics available later today.
                          • F Offline
                            Fred administrators @constantinos
                            @constantinos Hi, I can confirm that we will be releasing the schematic later today. Thanks Fred
                              daniel
                              The schematics for the deep sleep shield are now available here: https://docs.pycom.io/pycom_esp32/_downloads/Deep-Sleep-Shield_Schematic.pdf
                              Cheers,
                              Daniel
                              robert-hhR 1 Reply Last reply Reply Quote 2
                                robert-hh @daniel
                                @daniel Thank you very much. Will you also publish the code for the PIC controller?
                                  daniel
                                  @robert-hh yes, it will be open source too.
                                  • F Offline
                                    frankb
                                    What are the dimensions of the 'deep sleep shield'? Will it still fit in a standard housing together with the v1.0 expansion board?
                                      daniel
                                      @frankb it's going to be around 12mm tall. It's not going to fit inside the Pycase, but it most likely will fit inside the IP67 case. We will confirm this shortly.
                                      • K Offline
                                        Kean @daniel
                                        @daniel any timeline for release of the PIC source? I should have all the parts to build one of these on protoboard so I can continue with a project evaluation, except the code. Even a beta code in a hex file I can program via a PICkit3/ICD3.
                                          daniel
                                          @Kean I don't have precise timelines yet, we are still busy with the PIC code and we are not ready to share it yet. I should be able to share some more info next week.
                                          • K Offline
                                            Kean @daniel
                                            @daniel Thanks!
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 5
                                            • 6
                                            • 7
                                            • 2 / 7
