    Pymakr USB connection
    pymakr
    8 Posts 3 Posters 3.6k Views 4 Watching
      Lateralleap
      Hi, I am trying to setup Pymakr as an Atom plugin using a USB connection on Windows 10. I cannot get the Pycom console to connect. I have tried various formats for the serial connection in the Pymakr settings. Does anyone know how you should enter the connection setting for COM6. Is it /dev/USB Serial Port (COM6). This does not work BTW. Thanks
      • B Offline
        bucknall @Lateralleap
        Hi @Lateralleap, I believe it should just be "COM6" - I'm using a Mac currently, but I'll jump over to a Windows 10 machine to test this for you!
        I'll message back in a few minutes -
        Cheers,
        Alex
        Developer Evangelist - Pycom
        • B Offline
          bucknall
          @Lateralleap It seems that the COM port isn't giving any acknowledgement when it actually connects. You just need to type:
          COM6
          Into the settings and it will connect. I suggest that once you've done, press the reset button on the device and you'll see the restart information (confirming that the device is connected!).
          Let me know how you get on,
          Cheers!
          Alex
            Lateralleap
            That's really kind of you. Thanks so much. I will give that a try
              Lateralleap @bucknall
              @bucknall That worked. I had tried many combinations including (COM6) and I thought I had tried just "COM6" but obviously not
              Many thanks for your help
              @PyCom Would be worth including a complete example of the Windows syntax in the documentation
              • B Offline
                @Lateralleap I wrote up the docs for Pymakr, so I'll make sure that I update this to make it a little bit more clear!
                  @bucknall Thanks. If it helps, what is confusing is that in the section that talks about a USB connection under Windows, it has an image of the settings field that is populated with a sample entry for a Mac. Just changing that image to show COM6 (say) would really help. Thanks again
                  • R Offline
                    Ralph
                    Good to hear this is solved. For your information: we're planning a new feature soon that auto detects the available comports for you. That should solve these confusions in the future.
