    Does deepsleep work at all
    deepsleep
    83 Posts 20 Posters 52.6k Views 23 Watching
      adam_IoTK
      I am working with the SiPy board with extension board. A very simple setup - boot without any wifi commands (seems to boot wifi anyway?)
      read sensor values using uart commands
      use s.send(xxx) to send via sigfox
      deep.sleep (600000) = 10 min.
      It is powered through USB.
      Has any one any succes with deepsleep? I know about the power issues - but I am currently more concerned about the stability of the function. For me it wakes up and runs boot.py - and not as stated in the "getting started" - in the main script. This runs around 5-8 times and then stops. It might be in the main.py - but surely a lot of wifi stuff is going on every time it wakes up.
      Anyone had succes with deepsleep? Just a simple setup.
      Best regards, Adam
      • B Offline
        bucknall
        Hi @adam_IoTK,
        Please see this forum post for more information on this matter.
        https://forum.pycom.io/topic/1022/root-causes-of-high-deep-sleep-current
        Thanks,
        Alex
        Developer Evangelist - Pycom
          adam_IoTK @bucknall
          @bucknall I have read the post. What I did'nt understood was the point that the deepsleep function had two problems - the power consumption and the functionality as well. Can I expect the deepsleep function to wake up in the "program line" where I called deepsleep - or will It reset the board totally - when the deepsleep-quick-fix board arrives?
          Sorry for not understanding the very detailed description in the "deepsleep post".
          Adam
          B A 2 Replies Last reply Reply Quote 0
          • B Offline
            bucknall @adam_IoTK
            Apologies @adam_IoTK, misread your original question! Yes the stability issues are part of the coming firmware fix - they should help to resolve the waking up issues.
            Thanks,
            Alex
              adam_IoTK @adam_IoTK
                adam_IoTK @bucknall
                @bucknall Found it in https://forum.pycom.io/topic/929/deepsleep-stops-execution-of-main
                Sorry for the confusion, and thanks for your patience.
                adam
                  daniel
                  @adam_IoTK waking from deepsleep starts execution from the same point as when you power up the board. There are a few patches coming soon that will allow to:
                  1. Detect the reset reason, so you can know if you come from a power-on reset or deepsleep, then act accordingly.
                  2. Do not start-up WiFi by default on boot. This will speed up boot times dramatically and reduce power consumption.
                  3. Keep the RTC running during deepsleep.
                  • RobTuDelftR Offline
                    RobTuDelft
                    Is it currently possible to wake from deepsleep, e.g. on sensor reading?
                    Without data you're just another person with an opinion.
                    Hackster | About me
                      daniel
                      @RobTuDelft it is, but not yet. The ULP coprocessor from the ESP32 has to be used for that, but we haven't enabled support for it yet.
                        jmarcelino @RobTuDelft
                        @RobTuDelft
                        Some sensors have an "alarm" pin when values go below/over some threshold, with the deep sleep shield you could (in theory, I don't have it yet) connect those to either P17 or P18 and enable_wake_on_fall (or rise).
                          chumelnicu @daniel
                          @daniel Do deepsleep working ? I try to put my lopy after s.send(data) in lorawan config and after wake up 2 time from deepsleep the program is stop execution.
                          Any solutions for that ?
                          BTW ....I did try deepsleep from machine and alsi try with deepsleep board and DeepSleep from deepsleep.py library, same result
                            daniel
                            @chumelnicu deep sleep works... Can you be more specific around the way your program stops execution? A code example and the REPL output would help us understand your issue. Thanks.
                            C C 2 Replies Last reply Reply Quote 0
                              chumelnicu @daniel
                              @daniel Thx
                              Was about reading HR-04 Ultrasonic Sensor and send data over lorawan.
                              First i did connect Echo to Pin11 and Trigger to Pin12
                              I just move it to Pin21 and Pin22 and seems all is ok
                              Solved ! Thx Daniel
                                Camot @daniel
                                @daniel said in Does deepsleep work at all:
                                Sure? Libs and Lopy updated today. Lopy attached to the DeepSleep board. Not even the first line of the example from Github or documentation works without an error
                                >>> os.chdir('lib')
                                >>> os.listdir()
                                ['LIS2HH12.py', 'LTR329ALS01.py', 'MPL3115A2.py', 'pysense.py', 'SI7006A20.py', 'dth.py', 'bme280.py', 'deepsleep.py']
                                >>> from deepsleep import DeepSleep
                                Traceback (most recent call last):
                                  File "<stdin>", line 1, in <module>
                                ImportError: cannot import name DeepSleep
                                >>> os.uname()
                                (sysname='LoPy', nodename='LoPy', release='1.7.8.b1', version='v1.8.6-724-g2b9ed601 on 2017-07-28', machine='LoPy with E
                                SP32', lorawan='1.0.0')
                                  jmarcelino @Camot
                                  @Camot said in Does deepsleep work at all:
                                  Do you happen to have another file named deepsleep.py in your LoPy root folder by any chance?
                                    Camot @jmarcelino
                                    @jmarcelino said in Does deepsleep work at all:
                                    oops, thank you! How embarrassing :/ . It was still there from my pysense experiments. Anyway, still not working
                                      File "<stdin>", line 7, in <module>
                                      File "/flash/lib/deepsleep.py", line 145, in get_wake_status
                                      File "/flash/lib/deepsleep.py", line 76, in peek
                                    IndexError: bytes index out of range
                                    MicroPython v1.8.6-724-g2b9ed601 on 2017-07-28; LoPy with ESP32
                                    Type "help()" for more information.
                                      jmarcelino @Camot
                                      @Camot
                                      Setting aside the get_wake_status() example for now does a straight up
                                      ds = DeepSleep()
                                      ds.go_to_sleep(30)
                                      put the board into deep sleep for 30 seconds?
                                        daniel
                                        @Camot do you have anything connected to P10? That's the pin used between the LoPy and the deepsleep shield for communication...
                                          Camot @jmarcelino
                                          @Camot
                                          ds = DeepSleep()
                                          ds.go_to_sleep(30)
                                          don't think so, the board become unresponsive for 50 seconds but heartbeat continues and then it reports
                                          >>> ds.go_to_sleep(30)
                                            File "/flash/lib/deepsleep.py", line 156, in go_to_sleep
                                            File "/flash/lib/deepsleep.py", line 105, in calibrate
                                          IndexError: list index out of range
                                          Repeated it 3 times with ds.go_to_sleep(30), alway 50 seconds unresponsive :/
                                          @daniel
                                          no, only the Lopy, the deepsleep shield, the antenna and power with a 3.3V Step-Up/Down Regulator on the Lopy 3.3V pin.
                                            jmarcelino @Camot
                                            That's the problem then, the deep sleep shield only controls - and is powered by - the Vin (labelled 5V) pin not the 3.3V.
                                            Try applying your 3.3V to the Vin pin instead, the LoPy regulator should enter bypass mode and hopefully the PIC10 and extra circuitry shouldn't be affected too much.
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 5
                                            • 1 / 5
