    WiPy HTTPS call
    sslwipy2.0
    7 Posts 6 Posters 2.6k Views 7 Watching
      Tineler
      I'm trying to do an HTTPS call, using WiPy, but getting an OSError: -32512 when calling ssl.wrap_socket(s).
      Here's my code
      s = _socket.socket()
          ai = _socket.getaddrinfo("google.com", 443)
          print("Address infos:", ai)
          addr = ai[0][-1]
          print("Connect address:", addr)
          s.connect(addr)
          s = ssl.wrap_socket(s)
          print(s)
          s.write(b"GET / HTTP/1.0\r\n\r\n")
          print(s.read(4096))
          s.close()
      Do you have any idea, what I'm doing wrong?
      • M Offline
        mmarkvoort
        I also get the error message when trying code from Pycom documentation.
        • B Offline
          bucknall
          Hi @Tineler,
          I've just been testing your code - I'm not sure what's throwing the error exactly but I believe that it's coming from trying to wrap an existed and connected socket with ssl. I think this behaviour is unexpected, so I'll report it internally.
          I re-wrote your example but wrapped the socket with ssl before connecting them and it seemed to work without issue. Maybe try to use the example below:
          import ssl
          s = socket.socket()
          ai = socket.getaddrinfo("google.com", 443)
          addr = ai[0][-1]
          ss = ssl.wrap_socket(s)
          ss.connect(addr)
          ss.write(b"GET / HTTP/1.0\r\n\r\n")
          print(ss.read(4096))
          ss.close()
          Let me know if that works for you!
          Developer Evangelist - Pycom
          T M 2 Replies Last reply Reply Quote 0
            Tineler @bucknall
            Hi @bucknall
            This code works for me in general. But doing further investigation, I found out, that I still get the error while running the code within a call back for the Blutooth write event:
            char1_cb = chr1.callback(trigger=Bluetooth.CHAR_WRITE_EVENT, handler=char1_cb)
            • M Offline
              mrainone @bucknall
              @bucknall Hi.
              Hi, I've tried your example, but I still have a "Guru meditation error".
              It seems to be from the use of the ssl library: I tried to connect to google without ssl and I did not have any problems.
              The error appeared when I tried to connect via ssl, as in your example.
              I attach the sources and the results of the two versions.
              Connect to google without ssl, port 80
              ---------------------[start src]
              import network
              import ssl
              WifiNetworkName = "here wifi ssid"
              WifiPassword = "here wifi password"
              wlan = network.WLAN(mode=network.WLAN.STA)
              wlan.connect(WifiNetworkName, auth=(network.WLAN.WPA2, WifiPassword), timeout=5000)
              while not wlan.isconnected():
              machine.idle()
              print("Connected to Wifi\n")
              print(wlan.ifconfig())
              s = socket.socket()
              ai = socket.getaddrinfo("google.com", 80)
              addr = ai[0][-1]
              s.connect(addr)
              print("----------------[start]")
              print(s.read(4096))
              print("----------------[end]")
              s.close()
              ---------------------[end src]
              Results:
              import thttpok.py
              I (22198) wifi: Init ampdu: 0
              I (22198) wifi: mode : sta (24:0a:c4:00:d6:94)
              I (22199) wifi: sleep disable
              I (23079) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:6
              I (24068) wifi: state: init -> auth (b0)
              I (24070) wifi: state: auth -> assoc (0)
              I (24073) wifi: state: assoc -> run (10)
              I (24088) wifi: connected with Vodafone-33852835, channel 6
              Connected to Wifi
              ('192.168.1.5', '255.255.255.0', '192.168.1.1', '192.168.1.1')
              b'HTTP/1.0 302 Found\r\nCache-Control: private\r\nContent-Type: text/html; charset=UTF-8\r\nReferrer-Policy: no-referrer\r\nLocation: http://www.google.it/?gfe_rd=cr&ei=2RkCWeKtBOTBXrS3t4gD\r\nContent-Length: 256\r\nDate: Thu, 27 Apr 2017 16:18:33 GMT\r\n\r\n<HTML><HEAD><meta http-equiv="content-type" content="text/html;charset=utf-8">\n<TITLE>302 Moved</TITLE></HEAD><BODY>\n<H1>302 Moved</H1>\nThe document has moved\n<A HREF="http://www.google.it/?gfe_rd=cr&amp;ei=2RkCWeKtBOTBXrS3t4gD">here</A>.\r\n</BODY></HTML>\r\n'
              This is another version of the same software, using the ssl connection, like in your example, I have “Guru Meditation Error: Core 0 panic'ed (abort)”:
              Connect to google with ssl, port 443
              import network
              import ssl
              machine.idle()
              s = socket.socket()
              addr = ai[0][-1]
              ss.connect(addr)
              ss.close()
              Results:
              import thttps2.py
              I (34325) wifi: Init ampdu: 0
              I (34325) wifi: mode : sta (24:0a:c4:00:d6:94)
              I (34326) wifi: sleep disable
              I (34455) wifi: n:1 0, o:6 0, ap:255 255, sta:1 0, prof:6
              I (35443) wifi: state: init -> auth (b0)
              I (35446) wifi: state: auth -> assoc (0)
              I (35449) wifi: state: assoc -> run (10)
              I (35464) wifi: connected with Vodafone-33852835, channel 1
              Connected to Wifi
              I (45450) wifi: pm start, type:0
              abort() was called at PC 0x4014c133
              Backtrace: 0x40085692:0x3ffc4f60 0x40086470:0x3ffc4f80 0x4015023c:0x3ffc4fb0 0x4015057f:0x3ffc4fe0 0x40150706:0x3ffc5060 0x4014bba2:0x3ffc5080
              /////wAAAAAAAAAAAAAAAFwz+z8AAAAAAQAAAAAAAAAAAAAAQDj7PwAAAAAAAAAA
              AAAAAAAAAAAAAAAAAAAAAPYMCICAPP4/+Dn8PyxK+z8AAAAAAAAAAEw4+z8AAAAA
              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
              Rebooting...
              ets Jun 8 2016 00:22:57
              rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
              configsip: 0, SPIWP:0x00
              mode:QIO, clock div:2
              load:0x3fff9010,len:8
              load:0x3fff9018,len:248
              load:0x40078000,len:4056
              load:0x4009fc00,len:920
              entry 0x4009fde4
              I (1548) wifi: wifi firmware version: 90b1b8b
              I (1549) wifi: config NVS flash: disabled
              I (1549) wifi: config nano formating: disabled
              I (1564) wifi: Init dynamic tx buffer num: 32
              I (1565) wifi: wifi driver task: 3ffd63f4, prio:23, stack:3584
              I (1565) wifi: Init static rx buffer num: 10
              I (1567) wifi: Init dynamic rx buffer num: 0
              I (1571) wifi: Init rx ampdu len mblock:7
              I (1575) wifi: Init lldesc rx ampdu entry mblock:4
              I (1579) wifi: wifi power manager task: 0x3ffdb7b0 prio: 21 stack: 2560
              I (1586) wifi: sleep disable
              I (2575) wifi: wifi timer task: 3ffdc844, prio:22, stack:3584
              I (2591) wifi: Init ampdu: 0
              I (2591) wifi: mode : softAP (24:0a:c4:00:d6:95)
              MicroPython v1.8.6-593-g8e4ed0fa on 2017-04-12; LoPy with ESP32
                danielm
                I am having similar experience with Guru meditation errors when doing HTTPS requests: https://forum.pycom.io/topic/1061/https-post-using-urequests-py-and-guru-mediation-error
                Daniel promised to find a solution for this issue.
                • I Offline
                  Innocenzo
                  I have the same problem: https://forum.pycom.io/topic/1056/ssl-socket-communication-between-wipy-2-0
                  But if I try to connect with the wipy to a secure Server with ssl
                  #client side
                  import usocket as socket
                  import ssl
                  from network import WLAN
                  wlan = WLAN(mode=WLAN.STA)
                  wlan.connect('TP-LINK_2.4GHz_E113DF', auth=(WLAN.WPA2,"***********"))
                      machine.idle()
                  s = socket.socket(socket.AF_INET, socket.SOCK_STREAM, socket.IPPROTO_TCP)
                  # Require a certificate from the server. We used a self-signed certificate
                  # so here ca_certs must be the server certificate itself.
                  ssl_sock = ssl.wrap_socket(s,cert_reqs=ssl.CERT_REQUIRED,ca_certs='cert.pem')
                  ssl_sock.connect(('192.168.1.125', 10023))
                  ssl_sock.write(b"boo!")
                  data = ssl_sock.read()
                  print(data)
                  ssl_sock.close()
                  It works without problems. Try to use:
                  instead of
                  s = socket.socket()
                  But if I try to set a WiPy as a Server, I receive a Guru Meditation Error. More datails are in the topic linked early.
