    Cannot prevent WIFI console output
    Scheduled Pinned Locked Moved Enhancements
    wlanwifinetwork
    8 Posts 4 Posters 2.3k Views 4 Watching
      Andrea Filippini
      Hi all,
      I'm using the network.WLAN module to connect to my WiFi router using the LoPy but I'm really annoyed by the fact that the status output on the console cannot be shut down.
      It would be nice if there could be a "verbose" parameter to be set during the initialization
      • B Offline
        BluCode
        I completely second this, especially after the REPL console starts up.
          jmarcelino
          It's not easy because those come from the low level ESP-IDF C API (the "operating system") where that's a compile time option.
          You can recompile the firmware yourself and disable but then there's no dynamic way to turn them back on again.
          That said if you access the console (REPL) over telnet instead of the serial port you won't see them.
          • B Offline
            BluCode
            What is the compile time option exactly?
              jmarcelino @BluCode
              @BluCode
              CONFIG_CONSOLE_UART_NONE=y in sdkconfig
                robert-hh @jmarcelino
                @jmarcelino Which file is to change where. The only sdkconfig file I have here in the sdk is:
                $MYPATH/pycom-esp-idf/tools/unit-test-app/sdkconfig
                  jmarcelino @robert-hh
                  @robert-hh
                  Ha yes, slightly different setup on my side sorry.
                  You should add #define CONFIG_CONSOLE_UART_NONE 1 to your pycom-micropython-sigfox/esp32/sdkconfig.h
                    @jmarcelino Thanks. I think I tried that this morning, but w/o success. I'll retry this evening.
