    [WiPy 2.0] Pycom-esp-idf example error: undifined reference to 'mp_thread_clean'
    wipyesp32bug
    13 Posts 3 Posters 3.6k Views 3 Watching
    • I Offline
      Innocenzo
      Hi to everyone,
      I try to execute the examples in folder pycom-esp-idf (get-started -> hello world) following this guide:
      https://github.com/pycom/pycom-esp-idf
      After the command (where I do not change any options):
      make menuconfig
      try to execute:
      make all
      but I receive the following error meassage:
      fatal: No names found, cannot describe anything.
      LD hello-world.elf
      /home/aeromechs/pycom-esp-idf/examples/get-started/hello_world/build/freertos/libfreertos.a(tasks.o):(.literal.prvDeleteTCB+0x10): undefined reference to `mp_thread_clean'
      /home/aeromechs/pycom-esp-idf/examples/get-started/hello_world/build/freertos/libfreertos.a(tasks.o): In function `prvDeleteTCB':
      /home/aeromechs/pycom-esp-idf/components/freertos/./tasks.c:4421: undefined reference to `mp_thread_clean'
      collect2: error: ld returned 1 exit status
      /home/aeromechs/pycom-esp-idf/make/project.mk:322: set di istruzioni per l'obiettivo "/home/aeromechs/pycom-esp-idf/examples/get-started/hello_world/build/hello-world.elf" non riuscito
      make: *** [/home/aeromechs/pycom-esp-idf/examples/get-started/hello_world/build/hello-world.elf] Errore 1
      Any suggests?
      Thx
        jmarcelino @Innocenzo
        @Innocenzo
        The pycom-esp-idf is a special modified version to support the MicroPython build from Pycom.
        If you want to use the C APIs use the official ESP-IDF from https://github.com/espressif/esp-idf (which is also more up to date)
        I 1 Reply Last reply Reply Quote 1
        • I Offline
          Innocenzo @jmarcelino
          @jmarcelino Thanks a lot.
          But if I use this repository how many changes I must do in order to use it for my Wipy?
            @Innocenzo
            No changes required! :-) You can use the WiPy as a fully compatible ESP32 device.
            • I Offline
              @jmarcelino This is a good news :D
              Anyway the error persist also using this repository.
                @Innocenzo
                Sounds like you need to point IDF_PATH environment variable to the new ESP-IDF folder.
                export IDF_PATH=/path/to/your/new/esp-idf should do it
                • I Offline
                  @jmarcelino Ok it works with the new repository!
                  But there isn't a way to resolve the problem in the pycom-esp-idf repository?
                  EDIT: There is a function in pycom-esp-idf/components/freertos/task.c called portCLEAN_UP_TCB( pxTCB ); that causes the problem. I've deleted it and everything works.
                  I don't think that is a good solution.
                    @Innocenzo
                    Great! Well the "problem" is Pycom-esp-idf expects MicroPython to be present (the mp_ prefix you see in the error). It was forked and adapted for it.
                    i can't see any other useful purpose to use it instead of the official ESP-IDF repo.
                    • salvoaerodevS Offline
                      salvoaerodev
                      The Hello World example, included in the pycom-esp-idf misses the TCB cleanup function, just defined in FreeRTOS config file. Add it in the .c file, and recompile it. It should works in this way.
                        salvoaerodev
                        The function to add is
                        /* Missing function */
                        void mp_thread_clean (void *tcb) {
                        in the hello_world_main.c
                        • I Offline
                          Innocenzo @salvoaerodev
                          @salvoaerodev well done.
                            @Innocenzo @salvoaerodev
                            The function is defined in pycom-micropython-sigfox/esp32/mpthreadport.c
                            It's interesting it worked by just copying it over but I still don't see why you'd want to compile your C programs using pycom-esp-idf when the official ESP-IDF repo at https://github.com/espressif/esp-idf:
                            • works with the Pycom boards
                            • is much more up-to-date
                            • matches the ESP-IDF documentation at http://esp-idf.readthedocs.io/en/latest/
                            • Gives you support via the official esp32.com forums
                            Is there a reason I'm missing?
                            • I Offline
                              @jmarcelino Because we want preserve the Pycom WiPy firmware ad edit it with some frozen files and custom API C (like SSL and BT that have some problems).
