    LowRa gateway with Pi
    Scheduled Pinned Locked Moved Projects
    raspberry pilopy wipy
    3 Posts 2 Posters 3.0k Views 3 Watching
    • R Offline
      robmarkcole
      Hi all, found this tutorial using a raspberry pi to create a lowra gateway https://www.hackster.io/laserbrain/a-lorawan-the-things-network-gateway-for-windows-iot-core-441210 Would be interested to hear how people have set up their own gateways!
        jmarcelino
        Unlike that solution, the LoPy NanoGateway code supports downlinks so I suggest you use it instead :-)
        This is important because TTN is planning to drop support for gateways that don't support downlinks:
        https://www.thethingsnetwork.org/forum/t/the-future-of-single-channel-gateways/6590
        • R Offline
          robmarkcole
          @jmarcelino said in LowRa gateway with Pi:
          LoPy NanoGateway
          Great! You build the NanoGateway with https://www.pycom.io/product/lopy-twin-pack/ ?
          UPDATE: Found it https://www.hackster.io/bucknalla/lopy-lorawan-nano-gateway-using-micropython-and-ttn-a9fb19
