    Send data from WiPy to LoPy with BLE
    blewipybluetooth
    8 Posts 5 Posters 4.3k Views 6 Watching
      amartinez Pybytes Beta
      I' m trying to send data (I just need to send a temperature value) via BLE from WiPy to LoPy with the example posted on the offical documentation.
      The boards connects properly, but when the Client tries to get the services list (services = conn.services()) it doesn't succeed.
      LoPy (Client):
      from network import Bluetooth
      bt = Bluetooth()
      bt.start_scan(-1)
        adv = bt.get_adv()
        if adv and bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'WiPy':
            try:
                conn = bt.connect(adv.mac)
                print(services)
                for service in services:
                    print(service.uuid())
                    time.sleep(0.050)
                    if type(service.uuid()) == bytes:
                        print('Reading chars from service = {}'.format(service.uuid()))
                        print('Reading chars from service = %x' % service.uuid())
                    chars = service.characteristics()
                    for char in chars:
                        if (char.properties() & Bluetooth.PROP_READ):
                            print('char {} value = {}'.format(char.uuid(), char.read()))
                conn.disconnect()
                break
            except:
                print("Error while connecting or reading from the BLE device")
                break
            time.sleep(0.050)
      WiPy (Server):
      bluetooth = Bluetooth()
      bluetooth.set_advertisement(name='WiPy', service_uuid=b'1234567890123456')
      def conn_cb (bt_o):
          events = bt_o.events()
          if  events & Bluetooth.CLIENT_CONNECTED:
              print("Client connected")
              print("Client disconnected")
              pycom.rgbled(0x7f0000) # red
      bluetooth.advertise(True)
      srv1 = bluetooth.service(uuid=b'1234567890123456', isprimary=True)
      chr1 = srv1.characteristic(uuid=b'ab34567890123456', value=5)
      char1_read_counter = 0
      def char1_cb_handler(chr):
          global char1_read_counter
          char1_read_counter += 1
          events = chr.events()
          if  events & Bluetooth.CHAR_WRITE_EVENT:
              print("Write request with value = {}".format(chr.value()))
              if char1_read_counter < 3:
                  print('Read request on char 1')
                  return 'ABC DEF'
      char1_cb = chr1.callback(trigger=Bluetooth.CHAR_WRITE_EVENT | Bluetooth.CHAR_READ_EVENT, handler=char1_cb_handler)
      srv2 = bluetooth.service(uuid=1234, isprimary=True)
      chr2 = srv2.characteristic(uuid=4567, value=0x1234)
      char2_read_counter = 0xF0
      def char2_cb_handler(chr):
          global char2_read_counter
          char2_read_counter += 1
          if char2_read_counter > 0xF1:
              return char2_read_counter
      char2_cb = chr2.callback(trigger=Bluetooth.CHAR_READ_EVENT, handler=char2_cb_handler)
      L Nagarjuna ReddyN 2 Replies Last reply Reply Quote 0
        livius @amartinez
        @amartinez
        Will be better if you post textual data not images
        to post code you can surround it by triple ```
        link to other possible formatting
        http://commonmark.org/help/
          amartinez Pybytes Beta @livius
          @livius done, sorry.
            amartinez Pybytes Beta @amartinez
            I've updated the WiPy (Server) code with Alex's help, but it still not working.
            pycom.rgbled(0x00007f)  # Blue
            def conn_cb(bt_o):
            char1 = srv1.characteristic(uuid=b'ab34567890123456', value=25)
            temperature = 27   #Temperature value
            char1.value(temperature)
            srv1.start()
            • B Offline
              bucknall
              Hi @amartinez,
              I've been testing this out this morning and it appears to be a bug in the connecting device code - I've just been speaking with Daniel and he's going to debug it today. I'll keep you in the loop and you can see the github issue here - https://github.com/pycom/pycom-micropython-sigfox/issues/15.
              Developer Evangelist - Pycom
                amartinez Pybytes Beta @bucknall
                @bucknall Thank you so much! I' m a bit desesperated with this!
                • Nagarjuna ReddyN Offline
                  Nagarjuna Reddy @amartinez
                  @amartinez
                  hi
                  i have same problem like
                  services=conn.services() is not started how to solve if you get a answer.
                  Ch.nagarjuna reddy
                    st3ty @Nagarjuna Reddy
                    @nagarjuna-reddy same here
