TTN LoraWan GW not 100% stable
Hi everyone,
I'm experiencing issues with the LoraWan GW TTN code provided in the example, the GW crashes after several hours. When I reset the GW is seen again and I cannot find the route cause. (My LoPy is updated to latest firmware). Is there someone in the community that is running a TTN GW lopy based that is super stable ?
@jmarcelino OK I will try this in order to get more information when a crash is happening. To what I've seen I'm not the only one having similar issues.
@PiAir
Remote logging would be excellent but unfortunately once it crashes all remote stuff is off the table.In my case I'm using an OpenLog https://www.sparkfun.com/products/13712 (actually a clone) to record the serial output from the LoPy to an SD card.
Mine isn't stable either, but more like crashing (showing up as disconnected on TTN) once every couple of days, maybe a week or so. Since I use it for development, it wasn't / isn't really an issue.
Don't know about options to add logging to the micropython script on the server so at least we can get a better idea of what it causing the disconnection.
@blackansible said in TTN LoraWan GW not 100% stable:
his was an isolate problem.
I will continue to investigate to find the route cause, maybe someone at pycom can help?
I experience this problem yesterday after 2 hours. . I thought this was an isolate problem.
