    FiPy + PyTrack + DC Geared Motor
    getting started
    5 Posts 3 Posters 1.9k Views 3 Watching
      druhoi7
      Dear all,
      I will briefly introduce my self.
      I am a software programmer that as in mind a personal hardware project.
      Basically i want to create a GPS tracker and locker at the same time.
      I found PyCom and I think it's a wonderful product, but ... I am not sure if it does what I want.
      No doubts about geolocalization but I was wondering if it can support a geared dc motor like this: https://www.alibaba.com/product-detail/sharing-bike-lock-motor-3v-5v_60611666381.html?spm=a2700.7724838.0.0.WWrfXh
      and basically what I need to make them work together.
      It's really my first experience with these kind of devices, and probably I am completely out of mind.
      Thank you. Hope to receive your answer!
        livius @druhoi7
        @druhoi7
        You must be more precisly
        1. Do you need to run motor and stop?
        2. Do you need to control also motor speed?
        3. Do you need to control also motor direction?
        for some tips look here
        https://learn.adafruit.com/adafruit-arduino-lesson-13-dc-motors/overview
        or with H-Bridge
        http://www.instructables.com/id/Arduino-How-to-Control-DC-Motors-With-L293D-Motor-/
        But remember about voltages all pins ans e.g. PWM signals are max 3V3.
        And remember about voltage pic when motor stops - you need e.g diode to protect board.
        And also is good to have separate power source for board and DC motor.
          druhoi7
          Thank you for the answer.
          I will try to explain me and first of all read your documents.
          Yeah, normally the gears are just moving a "pin" inside and outside. So basically I don't need for sure the speed (it will be constant at every unlock), I am not sure about what you mean for "motor direction".
          I need to use the output pins, right?
          This I don't think is a problem.
          This I can effort, I think. My question is, why?
            livius @druhoi7
            @druhoi7 said in FiPy + PyTrack + DC Geared Motor:
            I mean, rotate clockwise and then under clockwise (or basically left right)
            yes, and if you need to control speed (but you say not) you need PWM
            It is a problem, you can broke board if you have not protection
            http://static.elektroda.pl/attach/dioda.png
            Only stability of power and noise which can hang your board.
            And of course voltage level which is near to always higher for DC Motor 6V, 12V, 24V .. (but not always)
              jmarcelino
              I recommend playing a bit with motors and motor drivers on some cheap Arduino clone. Get a 3.3V (volts) version, like the Arduino Pro Mini 3.3V - these can be had for less than $5 on Ebay and AliExpress - before moving to tests on an expensive FiPy.
              Once you have the logic figured out it should be easy to move to Python.
              With your input, this post could be even better šŸ’—
