    P8 as input always high even if pulled low?
    wipy 2.0
    7 Posts 2 Posters 1.7k Views 2 Watching
    • I Offline
      iotmaker
      Ont he Wipy 2.0 I found out yesterday that if i declare pin 8 as input then pull it low.. it will stay high. is this a known problem?
      L 2 Replies Last reply Reply Quote 1
        livius @iotmaker
        @iotmaker
        What frmware version do you have?
        os.uname()
        and do you mean
        p_in = Pin('P8', mode=Pin.IN, pull=Pin.PULL_UP)
        p_in() -- this is high if you wire it to GND?
        • I Offline
          iotmaker
          sysname='WiPy', nodename='WiPy', release='1.6.13.b1', version='v1.8.6-607-g9c8a0e9e on 2017-05-01', machine='WiPy with ESP32')
          p_in = Pin('P8', mode=Pin.IN, pull=Pin.PULL_UP)...this will measure 3.3v because is pull up
          This is supposed to measure a 0 but it still measure 3.3V.
          p_in = Pin('P8', mode=Pin.IN, pull=Pin.PULL_DOWN)
            livius @iotmaker
            @iotmaker
            what about with current firmware?
            `1.7.2.b1'
            i can check it but only in the evening
              livius @iotmaker
              @iotmaker
              I can confirm this issue
              pin P8 is never pulled down
              if we declare it to
              it stay high
              but work as input pin if i wire it to GND it go to low but after wire is removed it go back to high.
              can you report this as issue at:
              https://github.com/pycom/pycom-micropython-sigfox/issues
              • I Offline
                iotmaker @livius
                @livius are you running the up to date firmware on that test?
                thanks for checking the issue...
                  livius @iotmaker
                  @iotmaker
                  yes, current firmware
                  thanks for the report
                  https://github.com/pycom/pycom-micropython-sigfox/issues/19
