    Free memory issues ?
    wipy 2.0
    10 Posts 3 Posters 2.9k Views 4 Watching
      duffo64
      Ok guys, my Python skills are nearly 0.5, but this is driving me nuts...
      I did a small script that scans for BLE advertisers and pushes their data thru mqtt. Every scan cycle I also change led color and test free memory, asking for gc() if mem falls below 30000.
      WDT is enabled and feeded after any advertisement received. What i cannot understand is why free memory falls often well below 30000 (seen even only around 1K free), and after a while WDT kicks in and wipy 2 restarts. Why ? What stupid thing am I doing ?
      Thanks for everyone assistance
      Claudio
      from network import Bluetooth
      from binascii import hexlify
      from network import WLAN
      import utime
      import gc
      import os
      import sys
      import ujson as json
      from umqtt import MQTTClient
      from machine import WDT
      def settimeout(duration):
           pass
      # json.dumps()
      fwver  = os.uname()[2]
      ipaddr = WLAN().ifconfig()[0]
      mymac  = hexlify(machine.unique_id()).decode()
      bt = Bluetooth()
      pubmsg = ""
      free = 0
      wdt = WDT(timeout=20000)
      client = MQTTClient(mymac, "10.168.193.10", port=1883)
      client.settimeout = settimeout
      client.connect(clean_session=True)
      if machine.reset_cause() == machine.WDT_RESET:
          pubmsg = "{\"ts\":" + str(utime.time()) + ",\"fw\":\"" + str(fwver) +"\",\"ip\":\"" + str(ipaddr) + "\",\"mac\":\"" + mymac + "\",\"why\":\"WDT_RESET\"}"
          client.publish("/stat", pubmsg, retain=True, qos=1)
          try:
              free = gc.mem_free()
              if free < 30000:
                  gc.collect()
              pycom.rgbled(0x007f00)
              utime.sleep_ms(10)
              pubmsg = "{\"ts\":" + str(utime.time()) + ",\"fw\":\"" + str(fwver) +"\",\"ip\":\"" + str(ipaddr) + "\",\"mac\":\"" + mymac + "\",\"free\":" + str(free) + "}"
              bt.start_scan(30)
              while bt.isscanning():
                  pycom.rgbled(0x7f0000)
                  adv = bt.get_adv()
                  if adv:
                      mac = hexlify(adv.mac).decode()
                      try:
                          mfg_data = bt.resolve_adv_data(adv.data, bt.ADV_MANUFACTURER_DATA)
                          manu_data = hexlify(mfg_data).decode()
                      except:
                          manu_data = "no data"
                      name = bt.resolve_adv_data(adv.data, bt.ADV_NAME_CMPL)
                      if name:
                          pubmsg = "{\"ts\":" + str(utime.time()) + ",\"mac\":\"" + mymac + "\",\"cli\":\"" + name + "\",\"manu_data\":\"" + manu_data + "\",\"rssi\":" + str(adv.rssi) + "}"
                          client.publish("/tomqtt", pubmsg, retain=True, qos=1)
                  pycom.rgbled(0x000000)
                  wdt.feed()
          except KeyboardInterrupt:
              if bt.isscanning():
                  bt.stop_scan()
              pycom.heartbeat(True)
              sys.exit()
      /Claudio
      L R 2 Replies Last reply Reply Quote 0
        livius @duffo64
        @duffo64 said in Free memory issues ?:
        bt.start_scan(30)
        what if you feed it after above line?
          duffo64
          Thanks for your reply, Livius.
          Unfortunately, feeding after start_scan causes the wdt to kick in even more:
          {"ts":3,"fw":"1.7.4.b1","ip":"199.0.0.111","mac":"240axxxxxxxx","why":"WDT_RESET"}
          {"ts":3,"fw":"1.7.4.b1","ip":"199.0.0.111","mac":"240axxxxxxxx","free":50960}
          After less than 15 seconds, another reboot:
          ... and so on.
          At this point I cannot understand if it's me, the wdt, the garbage collector, or what.
          /Claudio
          • R Offline
            RichardTXD @duffo64
            @duffo64
            Hi.
            I had similar issues just reading BLE advertising packets and printing them to the console. Nothing clever. After a few minutes or a few hours it would crash. It was somewhat random.
            I did not have a WDT implemented.
            I tried gc in various forms, manual, automatic etc here and there, also watched free memory, various combinations all failed. I think about 3 hours was the best I did with this.
            What worked for me.... I told it to scan for just 10 seconds ( I see you set 30 seconds... I used 10for no good reason... didn't try 30). When it stops scanning, you can detect that, deinitizlise the ble object, reinitialize it and start scanning again. It does this really quite quickly.
            I got the above (sadly not clever) scheme to run for 6+ days without a hiccup on a WiPy 2 and expansion board. We have a lot of beacons in the office, it was getting about 8 to 10 packets a second. That seemed to be the best it would do.
            Hope it helps. Something to try anyway. I've not tried by ble code on the last 2 firmware revisions tho.
            L D 2 Replies Last reply Reply Quote 2
              livius @RichardTXD
              @RichardTXD
              Crash are different thing and should be analyzed deeply by pycom.
              If you have reproducible test case report it here:
              https://github.com/pycom/pycom-micropython-sigfox/issues
              @duffo64
              about WDT - try current firmware 1.7.5 maybe something is changed.
              R D 2 Replies Last reply Reply Quote 0
              • R Offline
                RichardTXD @livius
                @livius
                Thanks - didn't know about the issue tracking. Probably would not have paid it attention otherwise as it says 'sigfox' - maybe that means it is a catch all.
                However, if the Bluetooth crashes the WiPy then the WDT will timeout I presume? Might be relevant?
                He is using different parts of the system tho - it was just my experience with Bluetooth...
                L 1 Reply Last reply Reply Quote 1
                  livius @RichardTXD
                  @RichardTXD said in Free memory issues ?:
                  as it says 'sigfox'
                  Yes, sigfox in name in my opinion is misleading - but not my choice. And yes this repo catch all boards.
                  I guess so too...
                    duffo64 @RichardTXD
                    @RichardTXD
                    and... you nailed it. Deletion and recreation seems the key here.
                    Even if I am not asking for a whole week of uptime, doing at least a clock round would suffice. What's great is that after following your suggestion I am at three hours on 3 different units, and not a single reboot since. Will see...
                    So, big thanks !
                    Claudio
                    /Claudio
                      duffo64 @livius
                      @livius
                      Thanks, will try, but at this point I think that WDT is not to blame. I suppose that watchdog kicks in since the environment becomes clogged due to memory shortage.
                      Updates are always welcome, nonetheless :)
                      (Ops... must wait 10 minutes before posting again).
                      Claudio
                      /Claudio
                      L 1 Reply Last reply Reply Quote 2
                        livius @duffo64
                        @duffo64
                        I have upvoted your post to prevent this ;-)
