pytrack accelerometer pitch/yaw/roll read wrong values
  • Hi, I'm playing with the wipy2 + pytrack. both updated to the lastest firmware.
    I used the turorial script from github to get the accelerometers data in a while loop:
        print("{} {:>10.3} {:>10.3} {:>10.3} ".format(li.acceleration(), li.pitch(), li.yaw(), li.roll()))
        utime.sleep_ms(500)
    I think I got some bugged response
    laying on the bench it seems all regular:
    (-0.015625, -0.0007324219, 1.014038)      0.884    -0.0414     -0.883
    (-0.01708984, 0.001098633, 1.014404)      0.967      0.062     -0.965
    but if I roll the pytrack, both pitch and roll reads some values:
    (0.9797363, -0.1525879, -0.07019043)        -86      -8.83       80.3
    (1.001099, -0.1734619, -0.1179199)      -83.4      -9.76       78.2
    if I pitch the pytrack, pitch and yaw reads some values:
    (-0.03173828, 0.994873, -0.08068848)      -85.4         85      -1.82
    (-0.01452637, 0.9941406, -0.07385254)      -85.8       85.7     -0.835
    if i yaw the pytrack ( Holding it vertically), it's pitch and yaw again
    (0.1431885, -1.013672, 0.03063965)       88.3      -81.8       8.04
    (0.1501465, -1.015625, 0.03515625)         88      -81.4        8.4
    but if i turn it 90°, yaw decreases and roll increases:
    (-0.9949951, -0.1469727, -0.04418945)      -87.5      -8.39      -81.2
    (-0.9726563, -0.09790039, -0.04040527)      -87.6      -5.74      -83.8
    is that a known bug or I do I have to parse the output data or else?
  • @livius
    os.uname()
    (sysname='WiPy', nodename='WiPy', release='1.7.5.b2', version='v1.8.6-694-g25826866 on 2017-06-29', machine='WiPy with E
    SP32')
    pytrack firmware: pytrack_0.0.3.dfu
    yes I git-pulled the lastest library
  • @ozeta
    what i your firmware version?
    os.uname()
    \and what is your file version 2 or 3?
    pytrack_0.0.3.dfu
    and do you updated libreries?
    https://github.com/pycom/pycom-libraries
