    External IO Header connections
    pytrackpin
    9 Posts 6 Posters 3.2k Views 6 Watching
    • E Offline
      Emmanuel Goudot
      I am trying to understand connections of pytrack (mine is labeled "V1.0") as shown here: https://docs.pycom.io/pycom_esp32/_downloads/pytrackPinoutComp.pdf
      Ext IO header pin 2 labeled "PWR_EN" should be connected to LoPy (or other) pin P3 (PWR_EN), but it is not the case.
      Ext IO header pin 9 "EXT_IO_4" is in fact connected to P4 SD_CMD
      Ext IO header pin 10 "EXT_IO_5" is in fact connected to P8 SD_DAT
      pytrackPinoutComp.pdf is quite misleading and components are also not as received board.
      Would it be possible to get updated and correct documentation ?
      G 1 Reply Last reply Reply Quote 2
      • B Offline
        bucknall
        @Emmanuel-Goudot Verifying this with the team - will make the corrections asap! Thanks!
        Developer Evangelist - Pycom
          this.wiederkehr
          @bucknall, is there an update on this topic?
            jcaron
            As discussed here:
            https://forum.pycom.io/topic/1673/pysense-pinout/4
            The documentation is quite incorrect.
            On the Pysense:
            • pins 3 and 4 are reversed (pin 4 is the power to the board, pin 3 power to the module)
            • pin 5 (EXT_IO0) is connected to P2 / G23 / RGB_LED
            • pin 9 (EXT_IO4) is connected to G11 / P4 / SD_CMD
            • pin 10 (EXT_IO5) is connected to P8 / G15 / SD_DAT
            Pins EXT_IO4 and EXT_IO5 are NOT connected to the PIC.
            Pins EXT_IO0, EXT_IO1 and EXT_IO2 are connected to the PIC. However they are all connected to port C, which does not allow interrupts. So the sentence:
            Interrupts EXT_IO0, EXT_IO4 & EXT_IO5 are connected to a PIC and are accessible via Pycom Libraries
            is completely incorrect. No interrupts, wrong pins.
            The situation seems to be quite similar for the Pytrack.
              jmahesh
                jmahesh @bucknall
                @bucknall Any update on the topic..?
                I wanna connect a Buzzer with IO Header.
                Please suggest a topic to refer..
                  gregcope @Emmanuel Goudot
                  @emmanuel-goudot I have just wasted a load of time working out the same thing.
                  Can someone at Pycom change/improve the pytrack documentation/PINout diag;
                  https://pycom.io/wp-content/uploads/2017/04/pytrackPinoutCompN3.pdf
                    jcaron @gregcope
                    @gregcope Where did you get that link from? The current doc (https://docs.pycom.io/chapter/datasheets/downloads/pytrack-pinout.pdf) linked from https://docs.pycom.io/chapter/datasheets/boards/pytrack.html is correct. You seem to have a link to a previous version of the pinout.
                    @seb: you should probably remove the old document and/or redirect the old URL to the new one?
                      gregcope @jcaron
                      @jcaron Ahhhhhhh. Thanks.
                      I have been using this;
                      https://pycom.io/product/pytrack/
                      "PIN OUT" link
