    Pycom boards as mass storage devices
    usbstorage
    3 Posts 2 Posters 1.4k Views 2 Watching
      dbrgn
      The pyboard supports a configuration where it is recognized by the OS as a mass storage device. You can then view and edit the files on the flash memory. This is configurable with the pyb.usb_mode command.
      Is there anything like that on the LoPy & other boards? It would simplify development a lot, since I usually turn off WiFi (it's a low power project).
        jmarcelino @dbrgn
        @dbrgn
        Not a real mass storage device because there's only a UART avalable for the connection, but you could use one of the tools that let you upload or download files serially over REPL:
        https://github.com/PMunch/mpfshell
        https://github.com/SmileyChris/uterm
        D 1 Reply Last reply Reply Quote 2
          dbrgn @jmarcelino
          @jmarcelino I see. Thanks for the links, mpfshell seems to support recursive uploading and appears to be generally awesome :) I'll give it a try.
