    WiPy 2.0 to send data to dweet.io and then display the data into freeboard.io
    wipy 2.0ethernetpostrest
    1 Posts 1 Posters 884 Views 1 Watching
      dgzgonzalez
      Hi All,
      I'm trying to send data from my WiPy device to the dweet.io site using a "post" call.
      I'm using the following lib: https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
      And I wrote the following code (Note, the indentation does not work here and I used .... instead)
      import urequests
      import json
      myData = {'Value_1': 20, 'Value_2': 300}
      try:
      ....response = urequests.post("https://dweet.io/dweet/for/TheThing", data = json.dumps(myData))
      ....print(response.text)
      except Exception as e:
      .....print(e)
      I'm receiving back the following message
      {"this":"succeeded","by":"dweeting","the":"dweet","with":{"thing":"TheThing","created":"2017-07-19T16:52:41.547Z","content":{},"transaction":"5c436c5d-c772-4ab7-8dbd-b05321a47265"}}
      As you can see the payload ({'Value_1': 20, 'Value_2': 300}) is not passed through and I'm running out of idea on why this is happening.
      Does anyone has an idea or suggestion ?
      Thank you in advance for your help.
      Diego
