Capturing console messages to a log
I want to capture all console output such as debug messages and uncaught exceptions to a log file. I created the following code but it's not working. It does grab the console as expected. Also, if I comment out dupterm I can console.write("Some string") and it gets added to the log. But if I raise an exception it just quits the script without adding anything to the log. Please assist.
import time from os import dupterm from uio import StringIO from _thread import start_new_thread def log_console(): console = StringIO() dupterm(console) while True: logH = open('/flash/console.log', 'w+') logH.write(console.getvalue()) logH.close() time.sleep(1) start_new_thread(log_console, ())
Edit: Oops, this question is almost a duplicate. Forgot that I had asked.
@fsergeys same problem here :-(
Check out
sys.print_exception
, that might be able to help with printing out exceptions and traceback
Afraid not.
@BetterAuto: Did you find a working solution? I'm hitting the same problem.
