    IMPORTANT: New Firmware Update Tool Released (version 1.1.2.b1)
    firmware
    24 Posts 10 Posters 10.5k Views 9 Watching
      daniel
      We have released a new updater tool for all 3 Operating Systems (Windows, Linux and Mac OS) v1.1.2.b1. This new tool is required to flash firmware versions 1.7.7.b1 (to be released later today) onwards. Using the previous tool to flash firmware will result in the module being temporally bricked (flashing them again the proper way will solve it).
      From now on, the old tool won't work anymore as our software server only replies to request of the new tool.
      Please make sure to get the new version before upgrading your boards again. Thanks!
      The firmware update tool is available here: https://www.pycom.io/downloads/
      Cheers,
      Daniel
        robert-hh @daniel
        @daniel What is the difference requiring this change? And please make the new version of the firmware available in the Github repository.
          daniel
          @robert-hh yes, will publish code today as well (for sure). The difference is that before we were flashing the device using qio mode. With the latest IDF, we need to do it using dio mode, otherwise the board doesn't boot. After booting the flash is changed to qio mode just as before so there's no performance impact at all.
            daniel
            @robert-hh the github repo is updated ahead of the release: https://github.com/pycom/pycom-micropython-sigfox
              robert-hh @daniel
              @daniel Thank you.
                jmarcelino @daniel
                @daniel
                Wow some pretty good changes there!
                I love Fridays ;-) Thanks
                  jcaron
                  When downloading the macOS version, the .dmg is indeed numbered 1.1.2.b1, but the "Pycom Firmware Update" it contains is still numbered 1.1.1.b1.
                  Is the version number incorrect, or the updater?
                  Also:
                  • in some situations, upgrading at 115200 bps just doesn't work. An option to select 57600 would be great.
                  • are there any changes required if using updater.py on the command line (which allows changing the bps) as opposed to the GUI?
                  Thanks!
                    daniel
                    @jcaron good point about the version numbering for Mac OS. We'll get this fixed next week, but it's just that the version number was not increased, the updater is the correct one.
                    No, all the scripts have been properly changed, so using them on the command line is also fine.
                    Cheers,
                    Daniel
                    • R Offline
                      rdixey
                      I deleted all previous versions of the Update Tool from my Ubuntu system. Then downloaded the New Firmware Update tool v1.1.2.b1 from pycom.io Pycom upgrader Linux link.
                      When I run it as I have dozens of times in the past I get the messages:
                      • Connecting to the device to get it's information, please wait.
                      • Something failed trying to connect to the device.
                      Looks like the .update bash script throws this message when updater.py can't establish the serial connection
                      I'm using /dev/ttyUSB0 through which I routinely connect to the Lopy with Screen at 115200 baud.
                      I don't understand why the new update tool can't establish the connection as it had so easily with the prior update tool?
                        robert-hh @rdixey
                        @rdixey Same here. It stops after changing the baud rate to 921600. Updating a self-built firmware with esptool.py initiated with "make flash" works.
                        OS Debian 8
                          daniel
                          @rdixey I just tried the Unix it on Mac OS. Works as normal. I'll try this on Ubuntu tomorrow, and see if there's an specific issue there.
                          • FridaF Offline
                            Frida
                            Works ok here on Linux Mint 18.1 64 bit
                            os.uname()
                            (sysname='WiPy', nodename='WiPy', release='1.7.7.b1', version='v1.8.6-715-g5fa16c2c on 2017-07-20', machine='WiPy with ESP32')
                            • R Offline
                              rdixey @daniel
                              @daniel Did you find any specific issue with Update Tool 1.1.2.b1 on Ubuntu?
                              • B Offline
                                b3da @robert-hh
                                @robert-hh exactly the same for me on Ubuntu: Changing baud rate to 921600 - Failure!
                                • E Offline
                                  Emmanuel Goudot
                                  Same issue on ubuntu: cannot update LoPy/SiPy anymore...
                                    daniel
                                    Hello everyone,
                                    Thanks for reporting this issue with the linux updater. We haves just fixed it and released version 1.1.2.b2 for unix. It's available here:
                                    https://software.pycom.io/findupgrade?product=pycom-firmware-updater&type=all&platform=unix&redirect=true
                                    Apologies for the inconveniences...
                                    Cheers,
                                    Daniel
                                    robert-hhR R 2 Replies Last reply Reply Quote 0
                                      robert-hh @daniel
                                      @daniel tried it, got a little bit further, up to the message:
                                      " Something failed trying to contact the server."
                                        daniel
                                        @robert-hh can you please try again? The issue reported before was caused because of the slow baudrate (38400) used before for the initial connection with the board. Increasing it to 57600 fixed it. We just trying again on our Ubuntu machines where it was failing before and now it's all fine.
                                        @Emmanuel-Goudot @b3da @rdixey could you please try and let me know? Thanks!
                                        robert-hhR E 2 Replies Last reply Reply Quote 0
                                        • R Offline
                                          rdixey @daniel
                                          @daniel 1.1.2.b2 worked on my Ubuntu 16.04 Thanks....
                                            robert-hh @daniel
                                            @daniel Now it works.
                                            • 1
                                            • 2
                                            • 1 / 2
