Wifi and Bluetooth disable
  • I am wanting to disable WiFi and Bluetooth on my Sipy. How would I then enable Wifi once again to edit my code? Can you use the micro USB port to edit code?
    thanks,
    Chris
  • @chrisi yes, you can use the USB port (as a serial port) and have access to the REPL or to update files using Atom/Pymkr for instance.
    An alternative would be to include code which enables Wi-Fi on some specific event, such as a press of the button on the expansion board or Pysense.
