    Pytrack GPS API
    Scheduled Pinned Locked Moved Enhancements
    pytrack
    51 Posts 13 Posters 16.8k Views 20 Watching
    • N Offline
      Neuromystix @stefan85e
      @stefan85e Hello,
      You have to do something like this inside your code, and you'll get the number of satellites used for fix:
      gps_data = l76.coordinates1()
      n_sat = gps_data[5]
      Or you can use the @andrethemac library which will get you all the data ;)
      Researcher @ UALG, Portugal
        stefan85e @andrethemac
        @andrethemac
        (2018, 4, 17, 11, 29, 12, 564887, None)(None(53.33632, 12.53262)
        (None, None) Got when I add this:
        n_sat = gps_data[5]
        Did also try to use this lib:
        https://github.com/andrethemac/L76GLNSV4
          stefan85e @Neuromystix
          @neuromystix said in Pytrack GPS API:
          num_satellites
          Does this work:
          return(lat_d, lon_d, gps_time, gps_altitude, valid, num_satellites)
          I want num_satellites...
          • N Offline
            @stefan85e If you are using my code (and just my code, not the one from @andrethemac), when you call gps_data = l76.coordinates1() it will return a list gps_data with latitude at first position (gps_data[0]), longitude at second (gps_data[1]), and so on till the sixth position where you get the number of satellites (gps_data[5]). So, number_of_satellites = gps_data[5].
              andrethemac @stefan85e
              @stefan85e An example on how to get the number of satelites with my library
              from pytrack import Pytrack
              from L76GNSV4 import L76GNSS
              py = Pytrack()
              L76 = L76GNSS(pytrack=py)
              print("test L76")
              # returns the info about sattelites in view at this moment
              # even without the gps being fixed
              print(L76.gps_message('GSV'))
              # returns the number of sattelites in view at this moment
              print(L76.gps_message('GGA')['NumberOfSV'])
              # returns the coordinates
              # with debug true you see the messages parsed by the
              # library until you get a the gps is fixed
              print(L76.coordinates(debug=True))
              #L76.getUTCDateTime(debug=True)
              #L76._read_message(debug=True)
                @andrethemac
                Got this
                I see that you have a 180 timeout in the code:
                -> L76GNSV4 - So how do I know how many sattelites i have then :) just so I look at right nr :)
                def init(self, pytrack=None, sda='P22', scl='P21', timeout=180,debug=False):
                  @stefan85e The timeout is to prevent the library to wait for ever. 180 seconds (3 minutes) is (for me) most of the time enough to get a fixed location. (that is after a cold start)
                  the GGA sentences contains the number of messages seen by the GPS, In the dict that GGA returns, this is the "NumberOfSV' fied.
                  with this you get this number -> L76.gps_message('GGA')['NumberOfSV']
                  In your screenshot the line that prints the number of satellites has scrolled out of view
                  but if you make this line the last you get the number:
                  or remove the 'debug=True) from the coordinates line (the debug spews out a lot of information)
                  I'm still working on the library to make it faster
                  best regards
                  A S 2 Replies Last reply Reply Quote 0
                    andrethemac @andrethemac
                    @andrethemac published a new version of the Library to github
                    If you find some errors or have a request, please ask.
                    best regards
                      @andrethemac
                      The program stop after 180 sec and if I do this:
                      #print(L76.coordinates(debug=True)) it will not do anything :)
                          @andrethemac
                          (I dont get any nr due to I done get a signal from the GPS, I have to go outside to get it)
                          When I do this the program keeps running:
                          #print(L76.gps_message('GSV'))
                          print(L76.gps_message('GGA'))
                          And when I doing this then this happens:
                            @stefan85e Hi Stefan
                            sorry for the delay. you better put the the two firsts lines following the while(true): before. you don't need to init the library every run . I'll guess it's generating the error's.
                            the commands stop when the timeout runs out (default aflter 180 seconds). you can change that if needed.
                            The timeout occurs if the gps itself can't get a fix because it can't see (enough) sattelites.
                            best regards
                              andrethemac
                              some tweaks to my library https://github.com/andrethemac/L76GLNSV4
                              methods returning multiple values now return them as a dict;
                                @andrethemac Like this?
                                  @stefan85e yes.
                                  maybe of interest. I have 2 pytrack board and testing them side by side I found out that 1 takes way longer to get a fix, almost double as long.
                                  So you need to tweak the timeout parameter to get the best results for your module.
                                  best regards
                                    @andrethemac Okay thanks... what time are you using!?
                                      @stefan85e I'm up to 5 minutes now (timeout=300)
                                      when your outside you'll get a fix a lot faster
                                          johncaipa @andrethemac
                                          @andrethemac Hi, Is there any way to have the accuracy value of each GPS fix? when my pytrack is stationary the accuracy of each point is very different
                                          bmarkusB 1 Reply Last reply Reply Quote 0
                                          • bmarkusB Offline
                                            bmarkus @johncaipa
                                            @johncaipa said in Pytrack GPS API:
                                            Do you mean HDOP?
                                            • 1
                                            • 2
                                            • 3
                                            • 2 / 3
